Sharp aquos 52 vcr auto mode
Can not get out of vcr auto mode. Can not change input or see menu.
  • 53 Answers
SOURCE: My Sharp Aquos 46" LCD
Digital inputs on Aquos TV's are "always on," usually the HDMI inputs and DVI inputs. As opposed to analog inputs 1, 2, or 3, are only activated once something is plugged in.
Try plugging in another HDMI sources into input4 or 5, if its still not working, the TV needs a new Main Board. Try calling Sharp 1-800-237-4277 and locating a local service center in your area.
Posted on Mar 14, 2008
  • 1779 Answers
SOURCE: Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Posted on Feb 28, 2009
SOURCE: 52 INCH sharp aquos lcd REMOTE NOT WORKING
Make sure your remote lock is set to off.
Posted on Apr 22, 2009
dsacco86
  • 1077 Answers
SOURCE: Sharp Aquos Resolution
According to the manual for the TV, you need to change the resolution on the computer itself first.
The computer resolution should be 1024 X 768 at 60Hz or 1360 X 768 at 60Hz.
After the adjustment made on the laptop, then try the resolution change option.
Posted on Jun 12, 2009
SOURCE: Sharp 52" Aquos LCD Will Not Turn ON-Blinking LEDs
I had a similar problem. Fleeting video, then audio only for few seconds and then nothing except the green power LED blinking on and off.
I changed the power inverter board, backlight inverter boards and power supply board but still the problem is not gone.
Just 18 month old TV and out of warranty.
Posted on Sep 20, 2009
Can't find the DVI-D hookup on our sharp aquos 52' tv
The Sharp Aquos 52 inch model LC-52D62U doesn't seem to have a DVI-D input. Make sure your model is designed with a DVI-D input. If you provide me with your model # I'd be more than happy to find out specifically for that model.
Jul 18, 2011 | Sharp Televison & Video
The demo mode apears every 30 minutes. I can't really stand it. How can I shut it doen for ever? Sharp aquos LED 40"
I'm not certain of the specific model number of your set, but this should be the same for all Sharp Aquos models.
First, navigate to TV input, and select menu
Next, enter setup and select, "ez setup"
In the ez setup menu, select "home", not "store", for television location.
This should turn off the demo mode and solve your issue.
Jun 10, 2011 | Sharp AQUOS LC-40C32U 32 in. LCD TV
We have a 52" Aquos
Go into the user menu and set the default to full. If this does not correct your issue, then take it to a service center. You are still covered under Warranty.
May 12, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
View mode changes when switching tv off then on
If this is the correct tv model number LC42D62U and if you are connecting it to something with an hdmi cable, and it is on one of the hdmi inputs then you need to change the settings. Press the menu button--->scroll to setup on the right--->scroll down to hdmi setup and press enter to select--->If auto view is not highlighted already highlight it then press enter--->disable it then press enter--->press exit or menu menu to exit
Apr 23, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
PIcture does not fit on TV
TV must be set to zoom, take the zoom setting off
Mar 06, 2010 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
I bought a Sharp 52" LCD stuck in demo mode
Hi jmartinezua,
Here is how you fix this:
Go to menu--> setup --> reset
This will reset your TV to factory settings. The Demo Mode will cease.
JJ
Feb 23, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Jun 11, 2009 | Sharp LC-32D64U LCD TV
480i to 1080i?
It depends on which input you are using, but the HDMI inputs are auto detecting. Most likely whatever device you have connected is not putting out a 1080i signal, and needs to be configured to do that. Once you do, you should see the input icons on the top right briefly come up, and below the input number, you should see "1080i"
Feb 01, 2009 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Jun 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
Electro Med Services...
