Question about HP DeskJet F4280 All In One Printer InkJet
Paperjam printer says there is a paperjam but ive checked and there are no obstructions... what should i do?
  • 65 Answers
Sometimes the paper tray or where the ink is may have somethng loged up in there, also try to disconnect the power for 10 seconds and plug back in.
Posted on May 21, 2009
Paperjam siplay no paper in the back
hi open your printer so that you can see the wheels that feed the paper into the printer and check that no paper is stuck in the meconisom is this is soum times wey it says paperjam
Apr 09, 2014 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jam printer
kindly check it what shows in the display:
"paperjam 0" , its related to pick up roller related problem.
"paperjam 1", its related to cartridge unit, kindly re inserted the cartridge.
"paperjam 2", its related fuser unit, kindly open the rear cover of printer, ther you can see the fuser unit. check the one liver from fuser unit to HVPS .
kindly check all these things and contact
Jan 29, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Lexmark pro 700 continuous paperjam
Usually its either guide rollers or an obstruction of some sort. Might try find out if its an obstruction by simply looking around and seeing if there is a torn off piece of paper (usually) or something pooped off. If you are under warranty they will reset the guide rollers and clean the thing out. don't use it or try forcing anything. PS: I don't like Lexmarks and never have, but have repaired a few when collared by associates' pleas.
Mar 18, 2013 | Office Equipment & Supplies
I've got a paperjam HP Deskjet 3050A--no instructions on how to fix. Please help! I have an impending deadline!
check paper loading area and printing area is there any paper jammed? remove any viable objects, If printer in warranty surrender to HP. check paper path sensor...
Jan 30, 2012 | HP Office Equipment & Supplies
Says paper jam but NO paper is in the machine
One problem i found with those printers is that over time the casting around the paper tray is wearing off and printers starts to show paperjams when there is no paperjam.
One way to fix is try and positions the paper tray better or perhaps raising it a bit with piece of wood or paper.
Cast unfortenately is too expensive to replace so if this doesnt work and you are sure there is no paperjam and nothing obstructing the sensor then replace the printer.
Nov 02, 2009 | HP LaserJet 2200D Printer
My printer says there is a paperjam but I don't see a paperjam.
its a mechanical problem ...
check the rollers of the printer ..and the paper pick mechanism ..maybe it can't caught the paper in the tray that why it display an error of jammed..
May 24, 2009 | HP DeskJet 3653 InkJet Printer
Printer says there is a paperjam when there is none
It's possible that a little piece of paper tore off and is wedged all the way to the right, and is hidden by the print heads. I saw this happen on a 3210. I don't recall how to move the heads to the left side, and I don't have access to the on line docs, because I'm trying to solve a problem with the driver right now, but check instructions for print head replacement.
May 21, 2009 | HP OfficeJet Pro k550 Printer
Kyocera paperjam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Office Equipment & Supplies
PaperJam
I found that the little plastic hinge guide that supports/aligns the scanning area with the printer (stage 4 on the internal paper jam problem) was misaligned. I just removed it and the printer now works OK
Aug 28, 2008 | Samsung CLX-2160N All-In-One Printer
Printer
Sometimes just a teensy bit of paper stuck inside will make it say paperjam. I would check very well.
Dec 11, 2006 | Canon I900D InkJet Photo Printer
HP DeskJet F4280 All In One Printer InkJet Logo
104 people viewed this question
Seeker5211
Seeker5211
