Question about Nextar MA71520R Digital Media Player
Charging its plugged in, the display is lit up, but I dont think its charging.. says Ready USB 2.0 Full Speed.. but no evidence the battery is charging, as it turned off on me to day due to Battery low.
  • 1 more comment
  • ajbkfloit Dec 01, 2007
    I'm having a very similar problem with mine as well. It won't seem to start up after a full charge...and when I reconnect it to my computer, it says it has no charge left and has to fully charge yet again.
    Nextar doesn't have any support for this particular mp3 player on their website, either. I'm strongly considering returning mine and getting my money back if I can't find a solution.
  • velisa Dec 26, 2007
    I plug this into the computer and it will come on but will not charge.
  • Anonymous Mar 24, 2014
    it battery is not charged and it shows USB charge and USB update
I have the same problem with mine. Recently I tried plugging in one of those portable, AA Battery cell phone chargers in the USB port and I was able to see the player work as it had before. This as convinced me that the rechargeable Lithium-Ion battery may be the culprit of this problem. I have not figured out if I can find a replacement yet.
Posted on Dec 30, 2007
Just got the syma s032 gyro charged it to full and it wont fly for more than 20 seconds
So your only getting 20 seconds of flight time when your charging for a full cycle?
I purchased the Syma Chanook and it had the same problem , If you keep running into this problem using the remote control charger than I suggest to aquire a new charger . One that is a plug in the wall . I really dont like to rely on the usb chargers they just dont work as well. If not you still have a 30 day moneyback warranty and I would make them replace the battery or better yet the whole unit if the second charger doesn't work!
Dec 24, 2010 | SYMA Toys industrial Syma S032 Ready to...
Toshiba Satellite - black screen only when plugged in
hi
-remove battery pack(if you can romove memory ram aswell) and wait 10 mins
-now start charging laptop without battery pack for 2 mins
-unplUg the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DONT PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILL START ONCE YOUR SYSTEM BE READY SHUT IT DOWN PUT THE BATTERY PACK BACK AND CONTUNUE TO USE YOUR LAPTOP
Jul 07, 2010 | Toshiba Computers & Internet
Charging problem
it can only mean 2 things:
1. your battery is charged
2. your battery is broken or not connected
Jun 10, 2009 | HP Pavilion dv6227cl Notebook
Screen freezes and display faints
Hopefully the usb adapter just confused the battery. Did you use it this time or a regular plug? Its always best to fully discharge a battery and fully recharge it for the next use. They will lose life and malfunction otherwise. Glad you've had some luck, hopefully it will work just fine now.
Jun 02, 2009 | Garmin Forerunner 405 010-00658-20
No power off charge
Sounds like you need a new battery.
Jan 07, 2009 | Samsung V20 XVC 2400 Notebook
Battery on Sony Walkman NWZ-E436F
ok, just tried something with maybe a solution....
I was connected via an usb hub to my laptop, then it said battery is full, it apparently didn't charge.
When i connect my usb cable directly to my laptop it started to charge again!!.
My usb hub is not connected to a adapter so all power comes from the USB port, this may be not strong enough to charge your walkman.
Try this (so directly connect to your desk / laptop) it may work!
regards
me
Jan 02, 2009 | Audio Players & Recorders
Charging problem
I had this same problem, it's really irritating. Not exactly a full solution, but if you leave your phone connected to the usb for around 10 - 15 mins then disconnect it, remove and replace the battery and turn it on, it should have enough power to boot up, the just reinsert the usb and it should charge.
Dec 04, 2008 | LG Secret ? KF750 Cellular Phone
Will not power up
The battery is probably shot. Check voltage. if it is 0.0 then the battery has shut down internally and either needs to be charged for 48 hours, or replaced. Seems these batteries will shut themselves down to protect themselves and sometimes are never able to revive. You can try and charge it from the USB, but I dont think it does that, you need a 5.0V 2A power supply with the proper tip. I think it is a 3mm + center post. You can also remove the battery and check the pins when it is charging, It shoould show some voltage. Also, I dont think you can run it while charging.
Jan 10, 2008 | iRiver PMP-120 Digital Media Player
Screen says battery is full, but wont turn on
I read somewhere that even with a functional lyra, when it displays "battery full", you should keep charging for another hour. This is said to extend battery life and give you an extra 2-3 hours of power. Either this is perfectly normal, or it indicates that the battery reading tends to be inaccurate. In any case, try leaving it charging even after it gives you the message. Another thing to consider is, how long has it been in the box? I'm not sure about lithiums, but most rechargeables I know live longer when used. Live it alone for too long and you shorten it's life. Could be good to get a second opinion on this battery thing though. If there's a warranty, don't let it waste. Good luck
Jun 20, 2006 | RCA Lyra RD2840 MP3 Player
Nextar MA71520R Digital Media Player Logo
63 people viewed this question
Top Nextar Audio Players & Recorders Experts
skyocean
Level 1 Expert
Robert Graf
 Grubhead
Grubhead
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
