Question about HP OfficeJet Pro k550 Printer
Printer says there is a paperjam when there is none
Printer says there is a paperjam but ive checked and there are no obstructions... what should i do?
It's possible that a little piece of paper tore off and is wedged all the way to the right, and is hidden by the print heads. I saw this happen on a 3210. I don't recall how to move the heads to the left side, and I don't have access to the on line docs, because I'm trying to solve a problem with the driver right now, but check instructions for print head replacement.
Posted on Jun 18, 2009
2 Suggested Answers
Stevenslav
  • 65 Answers
SOURCE: paperjam
Sometimes the paper tray or where the ink is may have somethng loged up in there, also try to disconnect the power for 10 seconds and plug back in.
Posted on May 21, 2009
Paperjam siplay no paper in the back
hi open your printer so that you can see the wheels that feed the paper into the printer and check that no paper is stuck in the meconisom is this is soum times wey it says paperjam
Apr 09, 2014 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jam printer
kindly check it what shows in the display:
"paperjam 0" , its related to pick up roller related problem.
"paperjam 1", its related to cartridge unit, kindly re inserted the cartridge.
"paperjam 2", its related fuser unit, kindly open the rear cover of printer, ther you can see the fuser unit. check the one liver from fuser unit to HVPS .
kindly check all these things and contact
Jan 29, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Lexmark pro 700 continuous paperjam
Usually its either guide rollers or an obstruction of some sort. Might try find out if its an obstruction by simply looking around and seeing if there is a torn off piece of paper (usually) or something pooped off. If you are under warranty they will reset the guide rollers and clean the thing out. don't use it or try forcing anything. PS: I don't like Lexmarks and never have, but have repaired a few when collared by associates' pleas.
Mar 18, 2013 | Office Equipment & Supplies
Error printer, see your documentation
Power off the printer and unplug the power cable.
Open the scanner unit and check for any obstructions.
If there's none, try to move the print head to the left side and check for any obstructions on the right hand side of the printer.
If there's none, close the lid and plug the power cable back.
If the error message still pops up, have your printer serviced or call your vendor for the warranty.
Dec 07, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Says paper jam but NO paper is in the machine
One problem i found with those printers is that over time the casting around the paper tray is wearing off and printers starts to show paperjams when there is no paperjam.
One way to fix is try and positions the paper tray better or perhaps raising it a bit with piece of wood or paper.
Cast unfortenately is too expensive to replace so if this doesnt work and you are sure there is no paperjam and nothing obstructing the sensor then replace the printer.
Nov 02, 2009 | HP LaserJet 2200D Printer
My printer says there is a paperjam but I don't see a paperjam.
its a mechanical problem ...
check the rollers of the printer ..and the paper pick mechanism ..maybe it can't caught the paper in the tray that why it display an error of jammed..
May 24, 2009 | HP DeskJet 3653 InkJet Printer
Paperjam
May 21, 2009 | HP DeskJet F4280 All In One Printer InkJet
Printer keeps stating paperjam but there is no paper in it
Check the back of the printer. There should be a removable rear panel. Just Pull back on the lever (I believe on the right side) The rear panel will come off. See if any paper is lodged along the paper feeder wheels, if so, just remove it.  Also check back in the front of the printer and make sure there is none lodged along the feeder there where the paper normally comes out.
Power the printer back up and try to print again.
Hope this helps
-enov8
Mar 07, 2009 | HP Deskjet D1420 InkJet Photo Printer
PaperJam
I found that the little plastic hinge guide that supports/aligns the scanning area with the printer (stage 4 on the internal paper jam problem) was misaligned. I just removed it and the printer now works OK
Aug 28, 2008 | Samsung CLX-2160N All-In-One Printer
Printer
Sometimes just a teensy bit of paper stuck inside will make it say paperjam. I would check very well.
Dec 11, 2006 | Canon I900D InkJet Photo Printer
HP OfficeJet Pro k550 Printer Logo
237 people viewed this question
Seeker5211
Seeker5211
