SOURCE: Elna walking foot
If your SU is an Air Electronic model i.e. 80's model, Elna didn't make a walking foot to fit. However, if you've got a walking foot that is the same height from sole plate to the screw fitting as a standard Elna foot then you could give it a try. The walking foot connects to the presser bar with a screw but the needle bar also needs to hook into a secondary lever on the side of the walking foot to make the foot actually move. Probably sounds very confusing . Check the movement of the foot manually by hand turning the fly wheel to see how it works before you actually use with the motor to minimise any problems if the foot doesn't fit.
Also you'll probably only be able to do straight stitch with this foot due to the clearance around the needle plate.
SOURCE: have a 1970's elna su supermatic but cams don't work
There are two types of discs - single and double.
For the thinner single discs do as follows:
1.Turn stitch width knob to "0"
2. Turn stitch length knob to "0"
3. Insert the single disc
4. Turn the top selector to "A"
5. Make sure the needle selector is in the centered position.
6. You may now choose any stitch length or width you wish. I usually try "3" for the width and 1/2 for the length to start.
For the thicker double discs do as follows:
3. Insert the double disc
6. You may now choose any stitch width.
7. The stitch length must be put on "A" - this is the difference between the single and double discs!
I hope this helps!
SOURCE: What make of walking foot
You need a low shank style walking foot. Even back in the 80's when your SU air electronic was new, the walking foot sold by Elna was an after market one, and not made by Tavaro. Same with the ruffler attachment, it was after market and actually fitted quite a few makes of machine.
I would just ask the dealer/shop if they will refund your money if you find it doesn't work just in case.
There is a low shank one on sewingpartsonline.com
http://www.sewingpartsonline.com/walking-foot-low-shank-p60444.aspx and they list the SU as compatible with it.
Take off the foot holder on your mache, and you need to fit the little open ended arm over the needle bar and the foot bracket onto the foot with your machine's regular thumb screw. The up and down movement of the needle bar operates the walking foot.
SOURCE: elna su flywheel won't turn.
I'd suggest if its been in storage for a while, then a good clean and service would be benficial to the machine. However, just double check that the clutch is engaged, either a button on the flywheel (carina) or hold the outside of the flywheel and turn the inside wheel towards you to unlock, away to lock.
