Question about Ruud Heating & Cooling
Ignition not turning on - Ruud Heating & Cooling
Ignition of ford edge will not turn completely off..it is stuck in position 2 in auxillary power
1-
My ignition key will not turn to off. I can remove the key, but it stays in the accessory mode. What's the fix?
My ignition key will not turn to off can remove the key but it stays in...
2.
Ignition key is stuck and does not turn Inspection Service & Cost
Ignition key is stuck and does not turn Inspection Service Cost...
3.
Ignition key won turn
Aug 24, 2016 | 2012 Ford Edge
Key won't come out of ignition on 1999 vw jetta
IGNITION KEY WILL NOT RELEASE
It can be faulty ignition lock cylinder. I suggest to wiggle the steering wheel a bit and see if the key gets released out. If that is not helping then first turn steering wheel to right and try removing the key, or next turn steering wheel to left and see if you can remove the key.
Spray wd-40 in the ignition key hole and let it remain there for few minutes, after that once again try to remove the key and see if that helps.
But if that is not helping then ignition lock cylinder has to be removed out and key has to be manually removed.
For more troubleshooting on these types of issues, I suggest you to refer the help links mentioned below. Its the accurate solutions mentioned in it. That will help you to narrow the problem: -----
Click the link below: ------
1999 Toyota Camry: Key Will Not Come Out Of Ignition?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-key-will-not-come-out.html
2001 Toyota Tacoma: Ignition Locked?
http://technoanswers.blogspot.in/2012/04/2001-toyota-tacoma-ignition-locked.html
Ignition Switch Will Not Turn Off?
http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
Car will not turn the ignition to start?
http://technoanswers.blogspot.com/2012/01/car-will-not-turn-ignition-to-start.html
Ignition Key OFF but engine still running?
http://howtobyme.blogspot.in/2012/03/ignition-key-off-but-engine-still.html
Chevrolet Malibu: Key Stuck in ON position?
http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
2012 Dodge Ram: Ignition Key will not release?
http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
Ignition locked up on Mercury Villager?
http://technoanswers.blogspot.in/2012/01/ignition-locked-up-on-mercury-villager.html
Key won't turn in the ignition on Toyota land cruiser?
http://technoanswers.blogspot.in/2012/02/key-wont-turn-in-ignition-on-toyota.html
How to remove ignition switch on VW Car models?
http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-ignition-switch-on-vw-car.html
How to Replace Ignition Switch on Chevrolet Caprice Classic?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-ignition-switch-on.html
1995 Ford Taurus: Ignition switch not turning OFF?
http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
Ignition Problem Troubleshooting
http://whoisbyme.blogspot.in/2012/07/ignition-problem-troubleshooting.html
These will help.
Thanks.
Feb 15, 2013 | 1999 Volkswagen Jetta
I have a 98 Chevy Malibu Ls and the ignition won't
Inspect the old ignition cycle which is out.Is there any problem noticed of Ignition cylinder getting worn out.
Because when issue of ignition not turning off,its faulty ignition lock cylinder or faulty ignition switch.I suggest re-inspect the new ignition cylinder.
For more help,click the help link mentioned below:----
These will help.
Thanks.
Feb 04, 2013 | Cars & Trucks
2010 corolla key stuck in ignition
It can be faulty ignition lock cylinder.I suggest to wiggle the steering wheel a bit and see if the key gets released out.If that is not helping then first turn steering wheel to right and try removing the key,or next turn steering wheel to left and see if you can remove the key.
Spray wd-40 in the ignition key hole and let it remain there for few minutes,after that once again try to remove the key and see if that helps.
For more troubleshooting on these types of issues,i suggest you to refer the help links mentioned below.Its the accurate solutions mentioned in it.that will help you to narrow the problem:-----
Click the link below:------
http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html-----------
http://technoanswers.blogspot.in/2012/01/ignition-locked-up-on-mercury-villager.html-------------
------------------These will help.Thanks.
Nov 28, 2012 | 2010 Toyota Corolla
Doors wont lock when you turn on ignition.And the radio doesn't stay on when you turn the ignition off.
Your radio is connected to ignition instead of accesories. Not all car locking sytems lock doors with ignition. Check with the supplier if known or with nistallers.
Sep 25, 2012 | Cars & Trucks
Resetting the passlock
1. First, insert the ignition key and turn the ignition switch to the "On" position (Do not start the engine). Leave the switch on for 11 minutes. The security light may flash or be on steady during this 11 minute period. Make sure the light is no longer on or flashing before proceeding to #2 .
2. Turn the ignition switch off for 30 seconds.
3. Turn the ignition switch to the "On" position (as in step #1) for 11 minutes again.
4. Turn the ignition switch off for another 30 seconds.
5. Turn the ignition switch to the "On" position for 11 minutes a third time.
6. Turn the ignition switch off for 30 seconds one final time.
7. Turn the ignition switch to the "On" position one final time and wait 30 seconds.
8. Attempt to start the engine. If the engine starts and runs normally, the relearn is complete. If the engine does not start, Go to this link for info
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Sep 08, 2012 | 2000 GMC Yukon Denali
How can i reset the service warning on a 2000 tdi golf?
  • Turn on ignition.
  • Hold down Right trip button and continue to do so whilst turning off ignition.
  • Still with Right trip button held down turn ignition back on.
  • Release Right trip button.
  • With ignition still on turn Left trip button to the Right and release.
  • Turn off ignition.
Nov 27, 2009 | 2001 Volkswagen Golf
Reset ANTI-THEFT DEVICE FOR OLDSMOBILE ALERO
Three cycles of ON-OFF:
Turn ignition ON, wait for 10 minutes.
Turn ignition OFF
Turn ignition OFF
Turn ignition OFF
Your system is reset and has been relaernt.
Hope this helps,
Please rate the solution,
Jun 30, 2009 | 2003 Oldsmobile Alero
SQUARE KEY STUCK IN THE IGNITION
try pulling the key out at every position of the ignition switsh. just turn ignition key slowly while pulling at the same time. if that doesnt work then there may be a broken piece inside the ignition
Jun 17, 2009 | 2002 Suzuki XL-7
Ignition key wont turn
is it correct key? key and ignition barrel could be worn wiggle key around in ignition while turning? gently but fast wiggling.try lube in key slot also.
if not replace barrel and key
May 31, 2009 | 1995 Toyota Camry
Heating & Cooling Logo
99 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
