Question about Corioliss K2 Vapour Infusion Iron with Argan Shine Oil
Broken infusion tank on my corioliss ks hairstraightener
I need a replacement tank for my corioliss k2 hairstraightener and also argan oil.Can I order them online?
I'm afraid you cannot get a replacement tank for it unless you call and ask customer service. I'm sure they'll send you another one for a small fee.
Argan Oil:
http://www.amazon.com/Poppy-Austin-Argan-Oil-Responsibly/dp/B00D3M0CRS
or
http://www.uk.corioliss.com/argan-oil.html
Sep 19, 2013 | Corioliss K2 Vapour Infusion Iron with...
Need a unlock code for samsung i997 cell phone and instructions
You can get the Unlock code for SAMSUNG I997 from here Simpleunlocking.com/samsung-i997-infuse-4g/rs16wp9/ and follow the instructions below and unlock it step by step...
Samsung i997 Infuse 4G Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung i997 Infuse 4G mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung i997 Infuse 4G mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Samsung i997 Infuse 4G with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung i997 Infuse 4G is locked to.
CODE: Its the unique Unlock Code for your Samsung i997 Infuse 4G.
Each Samsung i997 Infuse 4G mobile phone has an unique unlock code. You can buy the unique unlock code for your Samsung i997 Infuse 4G mobile phone using the form above.
Feb 18, 2012 | Cell Phones
Unlock code for samsung infuse
I will help to know how to get the Unlock code for SAMSUNG INFUSE 4G,You can buy the Unlock code for SAMSUNG MOBILE INFUSE 4G model at here Mobile-unlocker.com/samsung-i997-infuse-4g/rs2wp9/ and unlock it.
Dec 11, 2011 | Samsung Infuse 4G Smartphone
I want to ddownload my itunes music, movies, etc... My sell phone is a samsung innfuse from T&T. Can you help me?
Hello Jane! Welcome to FixYa!
First you need to download the itunes agent for your Samsung Infuse.
To download it CLICK HERE
After download it you need to install it on your PC, After installing it, Open the itunes agent and go to the itunes Store. You can download it your desired music music and movies, Or you can also free download the Movies and Music from HERE
When you will download the music you need to transfer it on your Samsung Infuse follow the given procedure:-
1. Plug the Samsung Infuse 4G into your computer's USB port and mount it2. Touch the USB icon that appears in the menu bar at the top of the display, and drag it down to expose the Android Notification Pane. Tap on USB Connected, and select Mount. Create a folder on the mounted Infuse 4G called Music and the music and movies which you downloaded before, Copy and Paste then into that folder.
The second section, below, details how to create a configuration for the Infuse 4G in iTunes Agent's Preferences
  1. Right-click on the iTunes Agent icon in the system tray
  2. Click Preferences
  3. Leave all defaults checked and click the New button
  4. Give the device a name (Infuse 4G in this case)
  5. Leave Synchronize pattern: set to iTunes
  6. Click the Choose button and select the Music folder you created on the Infuse 4G
  7. Click the Create button and select the Music folder you created on the Infuse 4G
  8. Click Save and then Close
The final section explains how to add music to your Infuse 4G
  1. Launch iTunes and you will see a playlist folder called My Devices, under which you will see the Infuse 4G
  2. Simply drag the music you wish to synchronize from your iTunes library to your Infuse 4G into this playlist
  3. Finally, right-click on the iTunes Agent icon in the system tray and selectSynchronize devices
Music is now copied to your Samsung Infuse 4G and can be played using the Infuse 4G's Music application.
I hope you have a clear picture in your mind, Feel free to let me know if you have some confusion.
Sir, If you consider my service helpful for you then please Don't forget to Rate my Service as FIVE STARS and give the Words of Appreciation as Feedback for me
Thank You for taking my service
Concerned: Muhammad Uzair
Team : FixYa
Dec 10, 2011 | Cell Phones
Can't remove infuser to clean it
Turning off the power with the button is not enough. Instead, to remove the infuser: unplug the machine, wait a few seconds, plug it in again and turn the machine on. Even though you are technically turning it on, the machine will sense it was not turned off in an ok way, so it will "properly" shut off (and unlock the infuser).
May 06, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Won't pick up the water
REPLACED Front Nozzle PART NO: 2036678
CLEANING Tank Lid - Black Infusion and Tank Filter
Jan 22, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Delonghi magnifica coffee machine...infuser jammed in machine. Needs to come out for cleaning. Can depress red buttons but it wont come out..looks a but squint
Remove base plate and turn pulley clockwise (probably for several minutes) until infuser arm returns to vertical position and the infuser itself drops to the low position. You should here a click when it reaches this point. The infuser can then be removed as normal.
Nov 02, 2009 | DeLonghi DCM485 Coffee Maker
DeLonghi Magnifica always asks "Insert Infuser Assembly"
DeLonghi "Insert infuser assembly" error
Easy Fix - Delonghi Coffee machines which have built-in coffee grinders often suffer from a problem that produces an error, "Insert infuser assembly" that appears at random times.
The problem is usually caused by distortion of infuser lifting mechanism limit switch mounting (Orange colored plastic)!
The mounting is very close to the water heater so with heat and pressure from the infuser lifting mechanism the mounting gets bent over time. The switch mounting (Orange colored plastic) gets permanently distorted so the striker arm on the lifting assembly only just presses the micro switch button causing the error message "Insert infuser assembly".
To easily fix the problem on ESAM 5500 machines and should work on other similar machines:-
    1.Unplug the machine and remove the rear cover screws and remove.
    2.Slide out the two side covers.
    3.Remove the grinder lever screw in the top cover coffee bean compartment.
    4.Carefully lift the top cover pushing it slightly back so it does not stick under the front cover (you may have to loosen the 4 front cover screws on the side).
    5.The limit switch is clearly visible on the top (see photos).
    6.Wedge some insulated material (wood, plastic etc, I used bamboo) between the heater assembly and the switch mounting so the switch is in a VERTICAL position. The thickness of the packing is around 3-4mm (see photo).
    7.Re-assemble the machine and enjoy your coffee. JTS
    Alwar, Rajasthan
    India
Apr 01, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
The machinge keeps asking to insert brewing unit but it seems to
The infuser does go in at a slight angle "11:45" ish. Be sure the tabs on the sides of the infuser "pop" back out when it's in place. Try unplugging the machine if all else fails and it will do a self diagnostic. You could also call Delonghi tech support.
Jan 02, 2009 | DeLonghi EAM3400 Espresso Machine
Corioliss K2 Vapour Infusion Iron with Argan Shine Oil Logo
104 people viewed this question
Top Corioliss Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Corioliss Health and Beauty Expert? Answer questions, earn points and help others
