Question about Dishwashers
Whirlpool 6adp5540wh flow meter f7 fault
Fault light flashes seven times. I have removed inlet and outlet hoses and supply and return seem ok. Washer fills and empties. Any suggestions?
  • 14 Answers
SOURCE: Inlet/outlet light comes on
Machine is possibly not filling with correct amount of water if this light comes on early in the cycle
Posted on Sep 13, 2007
SOURCE: error code
just been told the code means heater failure. Just have to find out how to change it now.
Posted on Oct 29, 2007
gwshaw71
  • 83 Answers
SOURCE: Inlet/Outlet light flashing
check your overflow level switch wich is located behind front kickplate on right hand side
Posted on Feb 24, 2008
  • 1073 Answers
SOURCE: whirlpool adp 8540 - 7 flashes
replace the control board in the console
Posted on Apr 10, 2008
  • 65 Answers
SOURCE: whirlpool dishwasher
Do a "key dance" between normal and heated dry , going bak and forth six times. this will rester the heater fault. That is the clean light flashing code. Now you have to find the cause. Most likely is that there were suds in the last cycle or the door doesn't close smoothly. If the door sttrikes the cabinet in any way it will cause that problem.
Posted on Nov 03, 2008
Whirlpool adp 4404/5. Green light flashes 7 times !! Any idea ?
F7 - Flow-meter failure
Symptom: water inlet valve (WV1) is switched on and the water indicator (WI) is on (level reached).
Could be:
1. Water tap closed during water inlet
2. Water inlet hose blocked
3. Water inlet valve (WV1) defective
4. Flow-meter (FM) sends too few / much pulses (less than 10 imp.in 10 sec.)
Flow-meter counts wrong (or the sump is full in less than 30 sec. Causation: Hose felt down and slipped the disc of the valve. The effect is a displacement of the valve tappet).
5. Aquastop defective
6. Flow-meter defective
Dado
Jul 26, 2015 | Whirlpool Dishwashers
What does the F7 code mean for my whirlpool dishwasher ADG6230
F7 or 7 times flashing
Flow meter failure
Symptom:
Water inlet valve (WV1) is switched on and the water indicator (WI) is on (level reached).
Reason:
  • Water tap closed during water inlet
  • Water inlet hose blocked
  • Water inlet valve (WV1) defective (mesure resistor ca 3,5 kOhm)
  • Flow meter (FM) sends too few / much pulses (less than 10 imp. in 10 seconds). Flow meter counts wrong (or the sump is full in less than 30 second).
Causation: Hose felt down and slipped the disc of the valve. The effect is a displacment of the valve tapped.
  • Aquastop defective
  • Flow meter (FM) defective
Dado
Feb 17, 2015 | Whirlpool Dishwashers
I have a adg7560/1. the cycle starts but ends after a few minutes. the light flashes four times
Run the dishwasher through a test mode
Test Mode
Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
Open the door and set the program to the first program. (Normally rinse).
Turn the power off.
Press and hold the start button and while holding turn the power on.
After a little while the start button will flash, release the button.
Press the start button once and close the dishwasher door.
The machine will now run through a diagnostic routine.
Should take about 20 mins.
The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the programme.
To exit diagnostics at any time just press and hold the start button till the programme is cancelled
Error codes
F1. Single flash. NTC Break. NTC open circuit/short circuit or ambient temperature less than 3 Celcius
F2. 2 Flashes. Water leakage. Floater switch LS6 in drip tray has switched.
F3. 3 Flashes. Heating system defect. Heater or relay on control board defect. Chack also cabling.
F4. 4 Flashes. Draining failure. Drain pump, control board OWI or water indicator defect.
F5. 5 Flashes. Sprayarm Blocked (not present on VBL version. On 1 digit display will show as F and flashing start led).
F6. 6 Flashes. Water valve (WV1) is switched on but flow meter (FM) senses no impulses (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
Water Valve Closed. Water inlet hose blocked.
Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
F7. 7 Flashes. Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
F8. 8 Flashes. Water level failure. Sieve strongly dirty or big amount of foam inside to less water.
F9. 9 Flashes. Continuously Water Inlet. Water inlet valve mechanically not closed or control board defect.
FA. 11 Flashes. OWI failure. Dirty OWI lens. OWI defect or control board defect. Check cabling.
FB. 12 Flashes. Motorised Diverter Valve
FC. 13 Flashes. Water Hardness Sensor Failure
A fault with no fault code indication = faulty module
Read more: http://www.diynot.com/forums/viewtopic.php?t=200838#ixzz2zKhYFHxt
Apr 19, 2014 | Whirlpool Dishwashers
My dish washer has started to flash Err 7 on the screen and will not work. I ahve cleaned everyhting out, put drainO down the drain, turned it off for 1 week then back on again, checked that the hoses
F7--7 Flashes--Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked
make sure water is getting to your machine, its possible that the hose is kinked and not feeding water sufficiently to the machine.
alternatively, Unplug the appliance.
Take it out of it's position.
Take the left side panel off.
In the large plastic tank on the left side of the machine is the flow meter.
It's a small pcb with a 2 wire plug on it.
Pull the plug off and push it on again.
Do this several times to clean up the connection.
Ensure the connection is dry and tight.
Try the machine again.
If it still doesn't work, you'll need to obtain and fit a new flow meter to try and cure the problem.
Apr 03, 2013 | Dishwashers
What does erroe f7 mean?
Hi
This error indicates a fault with the water flow meter. F7 means inlet flow meter malfunction
Remove the left panel and check the flow meter, try to unplug it and plug it again.
If not OK, change the part, If you have checked the sump filter at the bottom of the dishwasher, then close the door and turn on the power. Then hold the start button with the + and - buttons under the LCD display, until the drain pump starts. This should then reset the dishwasher.
Pease get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 04, 2011 | Whirlpool Dishwashers
Code F1, does not stop filling, water pours out of soap tray
Are you sure it's not an F/H error?
The F/H code means the unit isn't detecting water fill at the flowmeter. The flowmeter sits just in front of the inlet valve and is attached via a hose, and off to the left of the CCU. Part link to the flow meter==> http://www.repairclinic.com/PartDetail/Flowmeter/1381535?modelNumber=GHW9250MW2
If your washer is filling ok, check the wiring from the flow meter to the control board; I've seen this harness jiggle loose and cause problems.
Read more: Whirlpool Duet / Kenmore HE3/4 Washer: F11 and FH Fault Codes ' Washer Repair ' Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2006/04/09/whirlpool-duet-kenmore-he34-washer-f11-and-fh-fault-codes/#ixzz1GVNXRInv
Get appliance parts at http://parts.fixitnow.com
Mar 13, 2011 | Washing Machines
Whirlpool adg 7550 starts cycle then beeps and flashes 6 times whats wrong?
6 flashes indicates water intake fault ie machine is saying it has not filled with water within the required time.
-Check inlet hose not kinked or blocked.
-Next, check inlet valve is OK (check with ohm meter-should read approx 4k ohms). If no circuit thru valve, replace.
-Could also be fault with water indicator switch (much harder to access and diagnose- located underneath sump on right hand side).
-I have also had this occur because of a faulty flow meter. Flow meter measures the volume of water as machine fills. Flow meter is large plastic chamber located on left hand side of machine (accessed by removing left hand side panel). It has a sensor on the bottom with 2 blue wires. Unfortunately again, very hard to test this component without specialist equipment.
Hope this is some help- not sure how technically minded you are, but checking inlet hose for kink/obstruction is a good place to start, then advise calling service technician unless you are a confident DIYer
Aug 10, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Dishwasher adp 4601 when switched on the pump activates.and after 2 mins start lamp bliks and pump goes off
The number of flashes indicates the fault. Reset machine by holding down the start button for 3 secs, then start a new cycle. If fault reoccurs, the number of flashes indicates fault eg 3 flashes, stop, 3 flashes stop, indicates F3 fault.
Faults listed below- advice on repair depends on which fault your machine is indicating, but may give you an idea of what to look for
1flash=NTC (temperature sensor) break- NTC outside normal range.
2flash=water leakage-float switch in base activated.
3flash=heating fault(check element.NTC,control board).
4flash=drain error-blockage in pump or drain system,or faulty water indicator switch.
6flash=water inlet fault-check inlet valve, check inlet hose not kinked
7flash=flow meter failure (flow meter measures water intake volume-large plastic weir located on left hand side of machine-reomve side panel to access)
These a most common faults, but further advice on repair requires counting flashes when fault occurs.
Aug 09, 2009 | Whirlpool Dishwashers
Start light flashing wont start cycle, what does it mean
count the number of flashes- this indicates fault ie will flash 4 times stop, flash 4 times stop. To clear fault, hold start button for 3 secs. Try running another fast cycle- if fault reoccurs count flashes: Number of flashes:1=NTC fault, 2=Flood switch activated, 3=Heating fault, 4=drain fault, 6=water inlet fault, 7=flow meter fault, 8=water level fault
Aug 06, 2009 | Whirlpool Dishwashers
Dishwashers Logo
27 people viewed this question
Top Dishwashers Experts
