Question about Panasonic Lumix DMC-TZ2 Digital Camera
When the camera is turned on to take a photo the image turs a purple colour
When i look through the view to take a photo it looks like it is running down the scene as it is melting, the colour is weird also. When I view the photo it is all different colours eg. pink, blue, purple,...
Hi you have either ccd unit (image sensor) or main circuit defective. Also circuitry connector loosen is possible. your local repair shop would charge $35 to 85 depend on what they really want to charge. Thanks and best regard!
May 25, 2011 | FUJIFILM FinePix AV100 Digital Camera
Purple veiw screen and photos. Canon A70
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Jan 03, 2010 | Canon Cameras
Image saves as random purple/ green patterns
Your CCD chip in the camera is defective. There is a lot of information on the web regarding this phenomenon. Here's a link to much of that info, http://www.imaging-resource.com/NEWS/1128958202.html
Note that the info is getting a little outdated now, as this problem has been identified and rectified. It only appeared in cameras that are now about six years old.
Sep 01, 2009 | Fuji FinePix S7000 Digital Camera
Purple screen
It appears your camera has a bad image sensor (CCD). Based on the model, it should still be under warranty. This is a warranty issue, that Fuji should look after. There is nothing you can do, yourself, to fix it. Even out of warranty, Fuji fixes many of these, as they acknowledge that the sensors were improperly manufactured. Take your camera and proof-of-purchase paperwork to the place of purchase, or directly to Fuji's national supplier.
Jun 09, 2008 | Fuji FinePix Z10fd Digital Camera
LCD screen shows weird colours
Gimbo again. Think LCD damaged will need to repair. Pics. as normal when viewed or printed.
Why has nobody commented?
How much to replace screen? Any ideas?
Feb 16, 2008 | Cameras
PURPLE LINES SHOWING ON SCREEN WHEN ATTEMPTING TO TAKE PHOTOS
Your camera likely needs a new CCD imaging sensor. It is a cute little thing and is very expensive to replace. I've seen deals to repair any digital camera on eBay and I would check for a local repair person in your area. You can use the search on this site to see who might be close by. I have an A310 doing the same thing.
Jan 04, 2008 | Fuji FinePix S5000 Digital Camera
White background in real world turns purple or magenta in digital photo
If you go to www.canon.co.uk. Go to technical support, then follow the links to your camera, a notice should pop up about the problem you are having. They are offering free repair for: Abnormal colours Distorted image Abnormal image It says its a CCD problem https://self-service.canon-europe.com/uk/pages/
May 02, 2007 | Canon PowerShot A85 Digital Camera
Pink Edges in Photos
It is called 'purple fringing' or chromatic aberration. It is quite common with digital cameras, especially those with small sensors. Sending the camera in for repair would not help at all. It can be removed, quite labouriously, in photoshop. Usually it is very seldom so obvious that it would require corrective work. When it is, it is often only in a small part of the image making it not that time consuming to fix in photoshop.
Sep 14, 2005 | Canon PowerShot A70 Digital Camera
Panasonic Lumix DMC-TZ2 Digital Camera Logo
42 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
