Question about Schwinn 430 Elliptical Trainer
My schwinn elliptical is making a clunking noise and changing from light to heavy resistance on its own
3 Suggested Answers
SOURCE: My Schwinn 430 Elliptical is not changing
I think I am experiencing the same problem and have removed the shrouds. Are you experiencing a clicking sound while the unit is plugged in? All of this seems to deal with the servo motor. Don't be fooled by suggestions to replace the rpm sensor...this is NOT the problem. I am trying to find out what the initial setting for the servo motor and the tension cable should be. I found a site where you can order the servo motor, but it tells me that it could be months to receive this part. Sigh...
Posted on Sep 13, 2010
biggerc
SOURCE: My Schwinn 430 elliptical makes a clunking noise when pedalling backwards but not forward. What is causing this?
I have a iron man cdt elliptical that was clunking . I found a shaft on the end of the crank was slipping in and out, inside the bearings. I shimmed it and retightened the retaining washer which prevented it from slipping . Smooth as silk now. It was very frustrating because all seemed tight at first.
Posted on Jan 16, 2013
My cx1055 elliptical resistance is not working how it should. Once I get to resistance lever 4 or higher it starts out with the resistance but then it slips as you step into it. Any suggestions?
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For ...
www.fixya.com/search/p3944353-nordic...cx1055_elliptic/resistance
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For Model Number 285090, ...the bolts that secure the magnet4=if there are slips, the resistance will . ... my schwinn 460 elliptical resistance cannot be changed When I increase the ... Every time I increase the resistance it will go to that level of resistance but within a ...
Need someone to install a new resistance motor on a Nordic ...
www.shopyourway.com > Manage My Life > Questions
Aug 10, 2013 - I bought a CX 1055 Nordick Track elliptical at a garage sale. I noticed that the resistance doesn't really change between levels. ... 100 dollars, but how much would it cost to have someone come out and do the replacement for me? ... I wonder if maybe something shifted when I brought it to my apartment?Missing: slips
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...2...
NordicTrack4. Place the elliptical exerciser on a level sur- face, with a mat beneath it to protect the... The CX 1055 elliptical exerciser is an ... 1055 elliptical exerciser features adjustableresistance ..... press the Odometer button again; the words "My.
Jan 05, 2016 | Exercise & Fitness
Elliptical noise
These motors has plastic gears...gears may be or is getting bad.
Dec 27, 2013 | Nordic Track NordicTrack CX 925 Elliptical...
The digital read out on my 420 elliptical schwinn system blinks on and off. There is no error code
follow this steps and replace batteries too. God bless you
Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
Be sure that you are using the correct adapter that came with the elliptical machine. Because different adapters are able to handle differing amounts of energy, the wrong adapter will not transfer electricity like it should. If the adapter is pinched or damaged, this could also alter its effectiveness.
2 Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistanc
Oct 01, 2013 | Schwinn 420 Elliptical Trainer
My digital screen on my 420 elliptical schwinn blinks on and off
replace batteries and proceed with this steps and fix it. God bless you
  • 2 Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistance.
  • Read more: http://www.ehow.com/how_6149016_troubleshoot-elliptical-machine.html#ixzz2gVxyHBXj
    Oct 01, 2013 | Exercise & Fitness
    My schwinn 460 elliptical resistance cannot be changed
    see the following details. God bless you
    Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced
    Dec 04, 2012 | Schwinn 460 Variable Stride Elliptical...
    Nov 10, 2012 | Schwinn 430 Elliptical Trainer
    My Schwinn 430 Elliptical is not changing resistance when requested. I hear a noise as though it is trying to change, but it does not. The resistance level is shown as changed on the display. Is this...
    Sep 12, 2010 | Schwinn 430 Elliptical Trainer
    When turned on makes clunking noise. I am able to use the machine when not pluged in. when the electrical display is on makes clunking noise
    You may have to disassemble the unit remove the side panels if the foot pedal assembly, arm assembly bearing and bushing are in good shape. You'll have to inspect the flywheel and pulley assembly with the power on & off . It will be a process no doubt.
    Jun 13, 2010 | Schwinn 430 Elliptical Trainer
    Resistance level does not change anymore. What is
    I fixed a problem with my Schwinn Elliptical 430 resistance level not working. When I would change the level anywhere from 1-16, I could hear the motor turning, but there was no change in resistance. If you hear the motor moving, then try this:
    Using a Phillips screwdriver, remove all the screws on the left side of the large plastic cover (left side if you are standing on the machine). When all screws are removed, you can pull the plastic cover off, and move it towards the back of the machine without having to disconnect any of the metal bars. (The bottom two screws are a little tricky to get off. Hold the housing in place, don't let it sag, in order to get them out.
    Look inside the unit and find the magnet, which is a rounded, brake-show like piece that is close to the flywheel, on the top half of the unit. There's a cable from the motor that goes upward and is attached to the magnet housing.
    If you try to adjust the resistance level now, you should see cable move up. This is supposed to allow the magnet to move closer to the flywheel and increase resistance. In my case, the magnet was stuck and wouldn't move upwards. When I gave the magnet a little push with a screwdriver, it popped up to where it should be.
    To solve this issue, you will need two wrenches. You must go to the opposite end of the magnet, towards the front of the machine, and you will see it's connected with a nut & bolt. Using a couple wrenches, hold the bolt, and loosen the nut about 1/4 turn.
    This should lessen the pressure on the magnet housing and allow it to move freely and not bind. Reassemble everything. Lie the elliptical down on it's side to allow the screws to fall into the holes easier.
    Once it's all back together, you should find that the resistance level works again!
    Sep 23, 2009 | Schwinn 430 Elliptical Trainer
    Schwinn 430 Elliptical Trainer Logo
    Top Schwinn Exercise & Fitness Experts
    Steve
    David Payne
    David Payne
    Matt Olenzek
    Matt Olenzek
    Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
