Question about Sanyo DS24205 24" TV
MY TV FALL DOWN FROM THE TABLE AND THE ELECTRIC CORD DISCONNECTED FROM THE INSIDE
  • 65 Answers
You need to unplug the cord from the wall. Unscrew the backcover and find the part that disconnected and connect it back, or get a soldering iron from radioshack and solder the wires that disconnected back. Good luck.
Posted on May 21, 2009
I tripped on the cord of my TV and it fell no visible sign of promblem but when I turn it on I have sound and alot of lines across the screen
Check inside to see if some wire or ribbon cable got disconnected. TV sets do not take kindly to falls.
Feb 22, 2017 | Televison & Video
Goes up but not down
Is the pedal air or electric? I fit is an air pedal, then one of the bladders inside the motor housing is busted and it will not activate the down switch. If it is an electrical pedal, then there is a problem with power or a bad switch inside the motor housing. If you are not familiar with electrical, I would suggest hiring someone to look at it. Possibly trade out a visit with an electrically inclined patient. If you have more questions, contact me through my website, www.chiropracticconsignment.com.
Apr 16, 2014 | Chattanooga Triton DTS Chiropractic Table
Dryer (electric) cord and outlet get extremely hot when dryer is on. I even think it is melting the prongs to the cord.
for some reason the dryer is drawing too much amperage. maybe the cord connection inside the dryer is loose or falling off? i assume this is an electric dryer?
Apr 05, 2014 | Dryers
What's color code for wires in back of dryer
Yes, here you go.
You should have 3 or 4 wires on/in the electric wire from the socket to the back of the dryer.
Open the plate and look at where the wires go to be hooked on.
You will see 3 screws or nuts in a row, left to right.
Carefully loosen these nuts or screws, be SUPER careful not the get them too loose, or they will fall off, sometimes down inside the machine.
Your electric cord has 2 hot wires, they are black and red.
These hot wires go on the right and the left screws, or nuts, but absolutely NOT in the middle!
The hot wires are interchangeable, the can go to the right or to the left.
You should also have a white wire in the cord, and that one, which should be in the middle of a 3 wire cord, attaches in the middle.
It is a ground.
If you have a 4 wire cord, you will have another wire, maybe blue or green.
That attaches to the case or the body of the dryer.
If your dryer has an extra green wire that comes from the inside and is fastened under a screw, that is where the 4th wire goes.
Be blessed.
Mar 03, 2013 | Maytag Neptune MDE5500AY Electric Dryer
I need a power chord for a westinghouse 27" television
Hello
For the United States and Canada
In the United States and Canada the male plug is a NEMA5-15 style UL Listed, and CSA
Labeled. For LCD TVs that are placed on a desk or table, type SVT or SJT cord sets may be used. For LCD
TVs placed directly on the floor, only SJT type cord sets may be used. The cord set must be selected
according to the current rating for the LCD TV. Please consult the table below for the selection criteria for
power cords used in the United States and Canada
If the cord size is SJT take 14AWG _ 12Amps
If the cord size is SVT take 17AWG _ 12Amps.
The specific power cord for this LCD TV is enclosed and has been selected according to the country of
destination and must be used to prevent electric shock
Check the socket confuguration of your wall socket and select proper pluged cord.
OK.
Jul 02, 2011 | Westinghouse LTV-27w7 7 in. LCD HDTV
My bosch 4000 will not run at full speed. Not using ext cord and electricity in my home is working.
This is common "affiction" for all table saw... and easy to fix, it applies to all power/hobby table saw in existence regardless of brand, manufacturer or model, if electrical problem is excluded, something is holding the blade:
1. switch off power
2. remove power cord from the socket
3. lift panel in the centre of the table (you did not supply exact model
4. remove nut holding the blade and the blade, pay attention to the direction of the teeth
5. clean bottom of the blade groove from all debris and especially long pieces, slivers, of offcut timber
6. put blade back in place and tighten the nut, check if it is moving freely, check if it is not slipping or wobbly
7. put table panel back, find these two pesky little philips screws which run somewhere on the floor and mount them back as well...
8. connect power and switch on and instantly off, check the blade again for slippage/wobbliness
9. mount back protection gards, try test cut
10. if test cut was successfull, use normally till next sliver fell in...
If test cut was unsucessfull - if this is open motor, check for debris inside ot the motor or even fan, then check brushes on the rotor if they are not carbonised too much or even burnt.
Do remember that this is not a toy, always disconnect physically at power point if you do any maintenance, blade will cut through timber, ocassional nail and through your fingers...
Do always wear googles or face shield, saw produce chipping and splinters while it works, you have two eyes but no spares.
Hope this advice will solve your problem, please do not hesitate to leave note how did you went :-)
Aug 17, 2010 | Bosch Saws
Laid tv face down on new rug to install legs,set back on table,sound,no picture.had picture 10 min prior
You should be seeing a validation that the TV is getting power. Like the lights are coming on, or you are hearing clicking when you plug in or power up the TV.
Make sure you have the TV’s power cord plug inserted all the way into the TV.
Also, make sure the TV's cord is plugged into a good power outlet. You may want to plug something else into the power outlet to be sure the outlet is good.
I don’t see how laying down the TV would cause this issue. Unless the TV was kind of dropped and or twisted to cause a board inside the TV to fracture/break.
I hope this information has helped you.
Good Luck.
May 23, 2010 | Sylvania 6842THG 42 in. Plasma HDTV
I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Jan 21, 2010 | Maytag MER5775Q Electric Kitchen Range
My laptop inspiron 6400 just fall from a table and now I when I power it on just the dell screen appears got freeze and won't go up to windows
Yeah you should first reseat the ram module. Or have it clean with soft eraser only its edge connector. But first you should power it it down completely, disconnect from any power source and disconnect it battery.
If this doesn't help. Boot your unit in DOS mode by starting it in a bootable drive. If you got a command prompt. You might consider the corruption of files in your harddrive or it actually gets damaged by the fall.
Apr 23, 2009 | Computers & Internet
Sanyo DS24205 24" TV Logo
51 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
