Question about Fuses: Cooper AGC Style Fast Acting 1-1/2 Amp Fuse 5-Pack
How to get at fuse box in 2003 toyota corola inside car
Toyota corola 2003
good car
what about it ?
post again
Oct 04, 2016 | 2003 Toyota Corolla
In what location all fuse box
What car you have ?
It can be under the motor plate in the clowbox, next to your steering wheel, infront of gear lever....
Dec 02, 2013 | SECRET AIR INTAKE 09-10 TOYOTA COROLA 1.8L...
98 toyota corola turn signal don't work ,what can be the problem
Could be a fuse inside your fuse box that is bad. Check that first. (cheapest fix)
May 18, 2011 | Toyota Corolla Cars & Trucks
Toyota corola not shifting, out of park.
This may be caused by the failure of the Relay or Circuit that powers the Safety switch, or Failure of the Brake Light circuit Fuse/Relay, which releases the Shifter.
Look in the Power distribution and Fuse Box.
Regards,DT
Aug 29, 2009 | 1994 Toyota Corolla
2003 Toyota Highlander clock resets when I turn off the ignition
Have you checked any fuses? Does the climate control light up? If not then in the under hood fuse box (left of drivers side) check the ECU-B fuse should be 7.5 amp. Check the heater fuse in the fuse box inside the car it should be 15 amp. If the fuses are OK and only the clock is bad check out my site www.autoclockrepair.com I offer a repair service.
Feb 21, 2009 | 2003 Toyota Highlander
Can't find head lamp fuse # 14 on toyota corola 2005!!!!!
its in the engine compartment next to the battery in a black plastic case. It is about 8 inches long 2 inches wide and 2 inches high.
Feb 19, 2009 | 2003 Toyota Corolla
Fuses: Cooper AGC Style Fast Acting 1-1/2 Amp Fuse 5-Pack Logo
24 people viewed this question
Top Bussman Vehicle Parts & Accessories Experts
Coss
RAYMONDO1953
John Mueller
John Mueller
Are you a Bussman Vehicle Part and Accessory Expert? Answer questions, earn points and help others
