Question about Mainstays 3-Piece Office Set, Black
Instructions I cant fine the instructions for my 3 piece office set
How do you complete step 3 on revell instructions for F-14D Super Tomcat 1/48?
Examin both pieces for locater holes and thry to dry fit them if you cant find them Try to replicate the fit from the Revell Instructions
Jul 31, 2014 | Revell F-14D Super Tomcat 1/48
Assembly instructions for aspen Barolo 6 piece modular office
most modular desks have a groove around the top of the base unit that small clips lock and pull the top to the base when the screws are tightened
Jun 09, 2013 | AspenHome Aspen Barolo Modular Home Office...
How do i set up eye pieces and focus lenses?? Instruction manual came in chinese with no translation and we are begiiners!
During the day:
1. Point to a far (1000 meters or more) object
2. Insert the lowest power (highest number) eyepiece e.g. 25mm
3. focus on the object.
4. Align finder to match what you see in the scope.
At night.
1. Put scope out and let it reach the temperature of the outside.
2. Point finder to the moon (1st object you should always use to check scope and finder alignment)
3. Use the same low power eyepiece.
4. If everything seems fine, switch to a higher power eyepiece and enjoy the view. You may have to slightly adjust the finder to align with the main scope.
If the views are blurry, the telescope may be out of collimation. Look on the internet for generic collimation instructions.
If this still did not help. Throw the scope out! Its probably a piece of junk and will only discourage you.
Dec 12, 2012 | Optics
Cant get my lexmark platinum pro905 to print from tray 2 using microsoft office products
If you're unable to print on Tray 2 using MS Office 2010, please follow the instructions in this article from the Lexmark website to fix the problem.
- Unable to Print on the Tray 2 Using Pro900 Series Printers from Microsoft Office 2010 and Internet Explorer 9
I hope this helps.
Jan 09, 2012 | Lexmark Platinum Pro905 multifunction...
I cant set up office 2007 cause of this file so tell me what to do
Hopefully , you have the original installation disk. Access Add/Remove programs , located in your control panel . Scroll down to the office 2007 application and uninstall it completely . Then use your original Office 2007 disk to reinstall it. If it was a web purchase , revisit the site and download it again making sure to follow the download / install instructions exactly.
Nov 19, 2010 | Computers & Internet
Microsoft office 2007 product code
hello gardnerlana your product code should be located on a large stiff piece of paper inside of the dvd case your Microsoft office 2007 came in. if you have lost or damaged it please follow these instructions please rate
Nov 16, 2010 | Microsoft Office Computers & Internet
I cant figure out how to use the clips for a Franke topmount granite sink. No instructions came with the sink. It is a formica countertop.
We can't figure it out either! It seemed to come with undermount pieces (its not an undermount sink) and some blurry IKEA-style instructions. Been working on this 3 hours!
Anybody...???
Aug 04, 2010 | Franke Home
Brother 2040 paper light .. continuous red
If you removed a piece. But more remains it must also be removed. Look closely along the paper path for something that will release to provide access to the path.
May 03, 2017 | Brother HL-2040 Laser Printer
The ear loop attached to my logitech F-0399A bluetooth headset has broken into 2 pieces. Logitech says since I didnt save my receipt, they were at a loss to do anything. Earphone works, I just need...
Ok, You can purchase an replacement part for the next generation logitech travelller Blue tooth. They fit fine .
If you cant find a replacement for the logitech travelller BT set, ask support to send you one and say you will pay up.
If you do buy , get a couple more
Else buy some gorilla glue and follow instructions to make a solid bond,
Bond one piece, Set aside for 12 hours,
Bond another piece and set aside for another 12 hours or over nite... The two pieces should now be solid bonded
Oct 12, 2008 | Logitech 250 Headset
Mainstays 3-Piece Office Set, Black Logo
15 people viewed this question
Top Mainstays Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Mainstays Office Equipment and Supply Expert? Answer questions, earn points and help others
