Question about Fein 14V Handymaster Cordless Drill/Driver with Nimh Batteries - Abs 14 Nimh
Batteries will not charge
Batteries will not accept to fully charge
How long should the battery charger to get a full charge
It depends on the level of discharge of the battery and the rate of amperage charge generated by the charger. If possible check the fluid level (acid/water) in the battery. If it is too low the battery will not accept a charge. If you add water (distilled) to the battery you charge at a low amperage charge rate if possible. A fully discharged battery may take 12 - 24 hours to reach full charge.
Oct 11, 2016 | Health & Beauty
NIkon cool pix 5400 will not turn on. Battery is fully charged.
A couple of possibilities. The battery is bad and not accepting a charge. Replace the battery. The battery terminals are dirty. Using cotton swab and some isopropyl alcohol, clean then fully dry the metal contacts on the battery and inside the battery compartment. Before turning it back on, be sure everything is fully dry.
Jun 26, 2016 | Nikon Coolpix 5400 Digital Camera
Lenova tab s8 wont charge help
Hi, it maybe possibly your battery to drained flattened to the point where it cannot accept a charge from the wall charger. the best thing to do is to try and trickle charge your tablet from a low voltage/amperage connection. Either a powered on PC USB port to the charging connector on your tablet, or from a low power phone charger (5v/500ma). It has been pretty well documented that lithium batteries do not like to be drained fully & it may be that the battery in your tablet has drained so low that it cannot accept a charge from the Lenovo a/c charger.
Try a trickle charge for 8-10 hours (or longer) on your tablet & see if that gets enough charge into your battery to enable it to recognise & accept a charge from the a/c charger.
Else it replacement of charger or some hardware failure in your tablet
Oct 04, 2015 | Computers & Internet
When charging the red light will cycle 7 seconds on then 2 seconds off and constantly repeat this cycle. However, the instructions state when charging the red might will stay on until fully charged. What...
Sounds like battery is no good There should be symbols on charger. Normally solid light charged. Blinking. Charging. Lights back and Foward battery. No Good won't accept charge
Mar 25, 2015 | LG HBS-700 Bluetooth Headset
My bettery was law fast everytime why?
Rechargeable batteries do not last forever.
They only accept about 1,000 charge cycles before becoming a brick.
so if you charged it everyday, that would be less than 3 years.
In addition, as the battery ages, it's ability to fully charge is lessened. That is why it is important to fully discharge the battery before connecting it up again. Some MFRs have software installed to "calibrate" the battery which you should run periodically which will lengthen the life of your battery.
Aug 31, 2012 | HP Compaq Presario V3000T Notebook
I charge my laptop 100% but my battery is low everytime why?
Actually my mobile battery is draining very fast even i am not using my mobile just except accepting the calls on my phone Even im closing all the applications properly im fully charging my mobile it shows...
Does the phone usually gets hot before the battery runs down?
Try changing the battery, maybe the battery cell is weak.
Let me know what happens after changing the battery, so that I might direct you further.
Take care.
Nov 20, 2009 | Sony Ericsson W700i Cellular Phone
I turn it on, logo comes on, and it turns off. I've tried holding the on button 8 sec, no luck.
With the limited information provided, a simple first step is to make sure the internal battery is either fully charged or is in a condition to accept a charge. When the internal battery's charge is allowed to below a certain level, it will no longer be capable of accepting a charge via the car charger.
The battery can be conditioned to accept a charge easily, however. This is done by connecting the GPS to the computer via USB port, NOT the car charger. Some Garmin GPS units come with a 120 volt charger that connects to the USB port of the GPS - this method is also an acceptable charge / condition method. Leave the GPS connected for 8 hours or longer (over night) and try to power up again.
I hope this helps!
Oct 24, 2009 | Garmin nuvi 205W GPS Receiver
Fein 14V Handymaster Cordless Drill/Driver with Nimh Batteries - Abs 14 Nimh Logo
163 people viewed this question
Top Fein Drills Experts
Are you a Fein Drill Expert? Answer questions, earn points and help others
