Question about HP OfficeJet 7410 All-In-One InkJet Printer
Carrage making sound in hp all in one,there is also a message paperjam
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
If it only happens when it is moving back and forth then the rail needs to be lubricated.
open and put some wd40 on acloth and wipe the silver bar to lube.
Posted on Oct 23, 2007
Our HP Officejet Pro L7780 All-in-One have had a paperjam. I have removed all the paper, but the printer shows the whole time there's a paperjam again. The printer makes a sound when you turn on the...
Try unplugging the power cord of the printer from the back of it while it's turned on and then plug it back in.
If you still gave the message try pressing ok and see if you get rid of it.
Here are some work arounds for that issue:*Try removing and reinserting the cartridges and make sure they are properly fitted in. *Remove and reinsert the duplexer *Try cleaning the rollers infront of the printer and from the back of the printer. *As for the rollers try, moving them and turn them around with your fingers. *Turn the power off and then on
This is a hardware issue already so if all else fails for your printer. It's better to just call tech support. If the printer is in warranty they will be able to replace it. If it isn't they might let you in on a good deal.
Feb 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Epson sx600fw displaying paperjam, No sign of any jam
did it happen after physically cleaning/flushing the head? I've had this a couple of times and clearly no jam. I removed the cartridges again, ran the rollers backwards and forwards a few times using the white gears, and powered up .... it recognises no cartridge present so went through the replacement again and the fault then clears. I think the s/w gets its knickers in a twist Printer is a heap of poo, and clearly designed to use asmuch ink as possible as it needs cleaning far too often. Wasted too much time on gettingit to print
Jan 15, 2010 | Epson Office Equipment & Supplies
Can the Carrage be fixed or replaced on an HP DJ 6122 ?
yes you can replace the carrage buy that from any computer shop and they will fit it
Nov 18, 2009 | HP DeskJet 6122 InkJet Printer
My HP 1020 will not print. I get a message that there is a paperjam and there is not a paperjam. The printer has hardly been used. Can anyone helP?
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 09, 2009 | HP LaserJet 1020 Printer
HP designjet 430, the data and media light come on at power up
The sad part unfortunatly is that the sensor on the carrage is below minimum specification. The only solution is to change the carrage as a unit P/N C4713-60039 and its going to be expensive. Normally the carrage belt would be replaced at the same time.
Dave
Feb 21, 2009 | HP DesignJet 450c InkJet Printer
HP 755 CM CARTRIDGE MISSING ERROR
This normally points to a worn ribbon on the carrage. Make sure the ribbon where the cartrige makes contact is really clean, if cleaning make sure the plotter is turned off. Sometimes a build up of ink can cause problems. The bad news is that if the ribbon on the carrage is worn it firstly comes with the carrage as a unit, and secondally the carrage is no longer available from HP
Jan 13, 2009 | HP DesignJet 750c plus InkJet Printer
Cartridge jam won't clear HP 5610v
I had the same problem and just got it to work. go to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00577763&lc=en&dlc=en&cc=us&lang=en&rule=22243&product=441125
go to the section "Moving the carriage" turn on printer and then unplug power. If you still cant move the carrage then remove both toner cartridge and all the trays. Then completely disconnect printer and stand it upright (so paper feed and cartridge tray is on top) Look thru the paper feed area to the left side of toner carrage and you will see a little plastic tab around the bottom back of the carrage. That tab is suppose to be inside a track on the bottom of the carrage. I think that when we put in or took out toner we must have pushed it to hard and that piece jumped out of the track and has "locked" the carrage. I just pushed the carrage up carefully and used a letter opener to move the plastic tab back into place (tab is spring loaded) print working fine now. Hope this solves your problem
Jan 03, 2009 | HP Officejet 5610 All-In-One InkJet...
I keep getting an error (81:01)
The problem refers to basically a paper jam. I thing your problem could however be the carrage movment. There is a special oil required for the carrage, but failid this use a very thin oil such as sewing machine oil. The trick is to not use too much oil, only a drop or two over the entire length of the carrage. Also needs to be oiled is UNDER the rail towards the back. Look carefully at the back of the carrage where it has the back slider. This rail needs to be clean and lubricated. Probable easier to clean and lubricate if you remove the encoder strip.
Regards
Dave
Dec 10, 2008 | HP DesignJet 500ps InkJet Printer
Hp 2115
issue with carrage , try cleaning ink carrage .
first
*unplug the power cable and press and hold power button for 1 min
*press and hold # and 6 , while holding # and 6 plug the power cable back in
*release the button after 10 sec
*wait for some time
*open carrage access door
*cleane printer carrage see for any dust in carrage
*pull the carrage to left
*turn off printer and turn it on
then try pressing OK and cancel at the same time
check for test page
Feb 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
HP OfficeJet 7410 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
