Question about HP Office Equipment & Supplies
I can not figure out if this printer has a paper tray or only manual feed. Does anybody know?
Is there a paper tray for a HP color laserjet Q3964A?
  • 65 Answers
  • 749 Answers
It's a big printer used for volume printing... surely there is a paper tray... just try to open the from cover downwards and would act as its tray.
fixya rate pls. thanks.
Posted on May 21, 2009
My CP2025 HP Printer toner is smearing on cardstock when I run multiple copies, but I can't figure out how to change the options for heavier paper. Where do I find it?
The easiest way to set the paper types, if you are connected via network is to access the embedded web server of the printer. simply type the IP (network address) of the printer into the address bar of your browser and a page will open that controls all functions of the printer. Setup you paper types as required. I would suggest that you feed the heavy stock through the manual tray not the standard paper tray.
Feb 20, 2015 | HP Color Laserjet Cp2025 Printer Laserjet...
Hp Color Laserjet 1600 says Jam in tray 2 bt there is not paper jams
Open the paper feed area and the printer, examine the paper feed path and make sure there isn't a page or piece of paper jammed in the path somewhere.
Aug 21, 2014 | HP Color LaserJet 1600
We have an HP color laserjet 3500 printer; we want to print 4x6 paper; how do we do this?
You will need to feed the paper through the manual tray and you will need to set the paper size in the driver for 4X6.
Apr 27, 2011 | HP Color LaserJet 3500 Printer
HP color laserjet 4600 dn printer How do I set
From the control panel of the printer, do the following:
1. arrow down once to highlight the 2nd item: "paper handling".
2. press the check button (turquoise color) to select this option.
3. arrow down 2x's until you highlight the "tray 2 size".
4. hit the check button to select this item.
5. You should see a size that is "letter" and there should be a ' * ' asterisk which means that is the default setting. If you see other paper sizes as well, then arrow up or arrow down to highlight the preferred size, and then press the check button to insert the asterisk ' * ' which will set that as the default.
6. you change the paper type as well as paper size for the other trays in the same fashion. Most HP printers will select paper according to the SIZE as well as the TYPE. The printer can "sense" the paper size in the paper cassette tray by the stops that hold the paper. Therefore the printer will choose that paper based upon the SIZE and what you define as its type.
Sep 24, 2009 | HP LaserJet 4600dn Color Printer
13.01.00 paper jam tray 2
The pickup rollers are worn out. Replace them and your problem will be gone. While you are sourcing them, use some alcohol. This may give them a little more life.
Jul 23, 2009 | HP Color LaserJet 3500 Printer
HP COLOR LASREJET 3500 41.3 ERROR
hi ray, it's chris. i called your cell phone, but figured you might see this. replace the registration clutch. after some research, this seems to be the solution given that should solve the issue in that printer, and it's an independant part from the paper pickup assembly...
RK2-0247-000CN
chris
May 27, 2009 | HP Color LaserJet 3500 Printer
Hp laserjet 4650 crumples leading edge of paper
When you open the paper tray assembly you will see that on each side there is a silver bracket on each end of the paper tray that the paper sit under. You can bend these away from the paper in a sidways just a little and that will fix your problem. The paper is hanging on these plates as it feeds and is bending the paper as it feeds.
Oct 01, 2008 | HP LaserJet 4650 Color Printer
Hp color laser jet 4700n
Go to the paper menu set tray 1, Letter size and "any" for paper type.
Set tray 2 Letter and paper type "Plain"
Oct 10, 2007 | HP LaserJet color laser printer
47 people viewed this question
Seeker5211
Seeker5211
