Question about Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw
Chainsaw wen warms up bogs down, wants to die cutting into wood
Hi I got a Stihl 028 woodboss chainsaw and it has a problem with boging down and dying wen the motor warms up as I cut into the wood. So I was sort of thinking ethier the carb and the needle in the carb is sticking or the choke is some how messing up to??.
  • 1 more comment
  • kody_conn May 21, 2009
    Oh and wen the saw is warmed up after laying on the throttle the rps on the motor stay high then slightly drop then go up without touching the throttle and being that the rps are high the chain is still goin with the chain brake off.
  • kody_conn May 24, 2009
    http://www.acresinternet.com/cscc.nsf/ed... hmm could be running little lean cuase this site that im showing is were I got the info on the fuel mixure 40:1 it says but mine is a USA model not a German and aperntly its a 47cc not 43cc hmmm yah that could be it acualy. But yah 50:1 u say? have to go with that i guess.
  • kody_conn May 25, 2009
    Oh ok Yah sorry about not listien my saw under stihl chainsaw ther first time using this site. but forgot to mention about 3 days ago took the carb apart looks fine all through took muffler apart looks fine not cloged the cylnder is good. Um but the one thing that looked like in need of replacing is the fuel line has small cracks near the carb that look like ther deep and could be the cuase of the problem becuase wen saw started acting up and i took the cover thats over the airfilter off the right part of the airfilter was soaked in fuel.
  • 4 Answers
Could be running too lean, Should be runnning 50:1.
Posted on May 23, 2009
  • 1 more comment
  • clintgonemad May 24, 2009
    My bad, you are correct. 40:1. I was thinking Husqvarna.
    Check fuel filter/line, plugged air filter, air leak in carb, could be a hole in the carb diaphram, mixture screw not right??
  • clintgonemad May 25, 2009
    That would/could be it. Fuel line is pretty cheap. Town & Country or Lowes style store carrys it, here its $.87 a foot at T&C. Rotting fuel line is pretty common for saws that have set. Saw repair shops get $20-$40 for 10-15 minutes of work changing them.
    That sounds like that could be it, too much air, fuel not mixing right. Hope it works !!!
  • 4 Answers
Most likely running a bit lean if it bogs down and dies under load, just open up the fast run jet a little. The two carburetor adjust screws are on the side near the pull start, one is "Idle" the other is "Fast run", you will need a small flat blade screwdriver that fits through the hole in the plastic housing, turn the "Fast" adjust screw 1/4 turn at a time anti-clockwise and test performance. if you go too far it will be too rich and will not rev out as fast with no load, find just the right balance. (Too lean it will rev out fast with no load, sounds great but have no power)
Posted on Nov 26, 2014
Stihl chainsaw problems
Adjust the high speed screw on carb
Install a new spark plug
Use fresh fuel
Aug 05, 2014 | Stihl Garden
What oil please
Best to use proper chainsaw oil to lubricate the chain cutting in the wood, but at a pinch you can use multigrade car engine oil. Don't use secondhand oil as the added acids,pollutants, etc., from the engine will break down the oil making it less efficient....and leave staining on the wood.
Chainsaw oil can be readily bought from good garden centres.
Hope this helps.
Jul 14, 2014 | Ryobi 18-inch Electric Chainsaw Chain Saws
Stihl 028 chainsaw runs good for awile then bogs and dies
Check fuel filter, fuel tank vent and possibly clean carb and replace carb diaphrams
Feb 12, 2014 | Stihl 028 Chainsaw Crank & Case
Stihl 028 woodboss runs fine for a tank of gas.
new air filter or wash it out with petrol to remove oil from the filter
Aug 03, 2012 | Stihl Garden
Hi, I currently own a Husqvarna chainsaw and I hate it!! When I purchased this thing I paid over $400 for a lightweight-easy start saw. This thing is tempermental-certain kind of gas-certain kind of...
Howdy, As youhave invited an opinion, here is mine: I live on a small rural island in the Northwest and don't know anyone who doesn't own a Stihl..period. I have an older neighbor who cuts all his own wood and will until he dies. He just got the big stihl electric chainsaw and has a generator on his quad. It cuts all day, quietly, no smell and no buzzed nerves at the end of the day, so that's another way to go. Gas or electric, Stihl has the fewest letdowns.
Here is a link to their website
http://stihldealer.net/locator/
My opinion does not necessarily reflect the opinions of others here at FixYa.com.... But it aught to:)
Regards, Farmerbear at FixYa.com
Sep 09, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chainsaw runs but when I start cutting it dies
you might just neet to clean the air filter and/or the carb.
Oct 06, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
My 345 chainsaw bogs down when it hits wood
There are two idle screws one high, and one low. Your high adjustment idle screw needs to be adjusted.
Jan 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw Logo
2,946 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
