Question about Radio Shack Pro-96 Scanner
I have a Pro 96 that when I turn it off and turn in back on the screen says '"DSP LOAD PC / IF Port Flash Men" I've tried turning it on and off a couple times and also tried resetting it a few times and It Still reads the same thing please help thanks Jim.
  • Radio Shack Expert
  • 509 Answers
Do you have something plugged into the side of the radio where the PC/IF port plug is? It sounds like it's looking for an update, and you need the RS cable a the 96 software in order to do that. Google it on radio reference.
Posted on May 01, 2017
2 Suggested Answers
  • 1274 Answers
SOURCE: pro 96 scanner says "dsp load pc/if port flash
Hello kazellir,
Welcome to FixYa.
My name is John, and I will be assisting you with your issue today.
Pay that no mind.
I will help you with the issue!
Reply on the comment page at the bottom.
John
Posted on Feb 24, 2011
My dell laptop inspiron 1100 won't start up. When I turn it on it go's to a screen that says it's now installed firmly in to the port bay and I can't get past that screen. I've tr
Turn off the computer. Hold the Fn key and power key to boot the computer in diagnostic mode. Follow the onscreen instructions to see if you have any hardware issues. This sounds like bad sectors on the OS boot partition.
Jun 28, 2017 | Dell Inspiron 1100 Notebook
Pro 96 scanner says "dsp load pc/if port flash
Hello kazellir,
Welcome to FixYa.
Pay that no mind.
John
Feb 24, 2011 | Radio Shack Pro-96 Scanner
Macbook Pro wont connect to Vizio tv
disconnect hdmi cable and shutdown pc, completely power it off. plug your hdmi cable back in to your pc and power it up. it should properly detect your tv. i use projector mode. tv must stay on while performing this procedure.
Feb 11, 2010 | Apple MacBook Pro Laptop Computer with...
My behringer ub2442fx pro has the numbers 88 flashing red in the display and a clicking sound every time they flash. any idea what the problem is?
A high likelyhood of a power supply problem.
I had a similar thing on a GX110 and it was an electrolytic cap that filters for the 5 volt regulator on the DSP board.
As the DSP starts up, the load on the supply sucked it below the operating point and caused the DSP to keep reseting. The display did flash.
The unit will have to be opened and trpunbleshooting done to find and repair the problem.
Dec 20, 2009 | Behringer Music
My ethernet port adapter is not working, i bought those electrical ethernet port conectors and my port can't seem to turn on
Try to find out what network connection software you need. I know how to do it for Windows network connections and in your case it will say disabled. Will get what information you can and do a search for it. Compaq site should have it also. Mine installed automatically but you might have to install it to the hardware with the Device Manager. Files you are looking for, Ex: nc100 or pro 100 ve
Sep 15, 2009 | Compaq Computers & Internet
Alas, another PRO-96 problem. I bought this at a
the most common problem with handheld scanners with no receive is a broken solder joint where the center pin of the antenna connects to the circuit board inside. It is a very small connection to solder. you can press it lightly with a toothpick to see if it responds.
Mar 25, 2009 | Radio Shack Pro-96 Scanner
Info
Is the power light on? If not, recicle the monitor. If it is on, then maybe the back lighting is the culprit.
I have a similar problem, and the repair is more expendive than buying a new one.
Sep 18, 2008 | HP vs15 15"LCD Flat Panel Monitor
SanDisk u3 micro 1 GB Cruzer
hi turn off your pc put the card into the usb then turn on your pc let the pc find the drives for it and load on if this dose not work try the same in another usb port ok
if it works you must format the 1 gig stick befor you use it
ok hope this helps
May 23, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
Window's will not load... desperate need of help
Try this, hook up an external monitor to this PC, usually the F8 key allows you to enable the port to extend video to an external monitor, it varies on each PC. Either way try an external monitor see if the image comes up on that. My suspcion is that the Backlight for the LCD monitor is bad and needs repair. Get back to me please. I would like to no... I am pretty certain that is the case here!
Nov 26, 2007 | Panasonic Toughbook 48 Notebook
Radio Shack Pro-96 Scanner Logo
77 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
