Ge washer wcre6270k2ww
I stopped the wash cycle to add clothing I change the load size Now the machine won't restart the new cycle
jsrock516
  • 5911 Answers
SOURCE: Washing machine stops in rinse cycle.
Okay...I asked you a question in your other posting before I saw this one. This is a common symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plunger on the lid itself. Make sure the plunger is not broken off. This will also keep the switch from not working. On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and agitate, but will not start the rinse or drain cycles. If you wish to attempt the repair yourself, the switch costs about $35 and is fairly simple to replace if you follow the steps below:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions please let me know by posting comments.
Posted on Feb 11, 2008
SOURCE: GE Front Loading Washing Machine seems to be holding water....
manual
Posted on Mar 21, 2008
johnychel
  • 796 Answers
SOURCE: spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Posted on Mar 23, 2008
SOURCE: GE front load washer
Remove the front lower panel (3 screws on lower lip - lay on floor to see). Panel come right off. there is a round "dial" to the front housing. Put down a bath towel on the floor and unscrew dial - then pull it out.
Posted on Aug 28, 2008
  • 3600 Answers
SOURCE: Brand new GE Profile leaves clothes soaking wet
It is under warrenty call the store where you bought it and have them look at it. If you mess with it it will void your warrenty, belt may not be working or transmisson may not be shifting. The house call will be at no charge.
Posted on Sep 10, 2009
Testimonial: "thankyou for the help, I thought I had just made a bad buy. They sent someone out right away and it turns out this particular machine had a bad part."
I pressed the pause button to add a garment to my Whirlpool frontload washer. After doing so, I pressed the hold to start button, but the washer would not restart the cycle.
Switch the power off from the power outlet for a few minutes , then switch on and reset the wash cycle . Front loaders are not designed to add clothes mid wash.
Mar 18, 2015 | Whirlpool Washing Machines
The spin cycle on my GE Profile Harmony washer has gone violent, what can cause this?
probably unbalance load inside, try to stop, move what's inside and restart, or maybe there is not enough inside and cannot balance ( one heavy item, add some item so it can balance them when spinning )
Nov 29, 2014 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
How do you change the setting for the water level after the machine is on?
you need to restart the machine and change your load size switch then let it fill further and restart the cycle,or you can manually add water to the unit with a separate water bucket or hose
Jul 19, 2010 | GE Profile WPRE6100G Top Load Washer
Can I reprogram a front load GE washer so I can add a drain and spin cycle that this machine does not have?.Sometimes my clothes come out too wet and it would be nice to spin and drain them again without...
just add another drain and spin cycle and start it up again with the completion of the first cycle. Washing some items like sleeping bags takes forever because they are so darned absorbent and hold more water than a tiger's sieve of a bladder. Another drain and spin cycle should solve the problem.
Apr 20, 2010 | GE WBVH6240F Front Load Washer
The machine stops after the wash cycle and won't finish.
The code is UE
load too small.
• Load is out of balance.
• The washer has an imbalance
detection and correction
system. If individual heavy
articles are loaded (bath
mat, bath robe, etc.) and the
imbalance is too great, the
washer will make several
attempts to restart the spin
cycle. If an imbalance is still
detected, the washer will stop
and the error code will be
displayed.
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
please rate this help to keep the service online
Aug 20, 2009 | LG Washing Machines
Stiff clothes in my GE front load washer
Add two cups of white vinegar to the tub and run the hottest and longest cycle. this will clean out your machine thoroughly.
After that add one cup of white vinegar to the wash to prevent stiffness
Aug 05, 2009 | GE WSXH208A Front Load Washer
Washer isn't properly draining in normal wash cycle and start/pause button has to be pushed to restart washer 2-3 times to finish cycle. When cycle finally finishes, a 'drain cycle' has to be run to remove...
remove bottom cover ckd pump for possible restriction..most have acess port on front if not remove hoses also pump impeller may be slipping on shaft or have broken fins
Jul 29, 2008 | GE Washing Machines
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
