Question about Linksys Wireless-G WRT54G Router
Need help with router limited connection
Need some help i can see my computer with the router but i get a limited connection and does not connect
  • julmot Feb 20, 2008
    before all were connecting but now all my computers connected to wireless are giving limited or no connection
    Scholar:
  • 110 Answers
Is that connection wireless, if so if is pass protected? (WEP,WPA,etc)?
Thanks,
Cam
Posted on Oct 19, 2007
Computers have limited connection to linksys wrt54g although signal is full strength
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Also try resetting the wireless router by turning off the power to the wireless router for a few minutes and the boot up your computers.
Oct 28, 2012 | Linksys Wireless-G WRT54G Router
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
If your connection remains non-functional, run the Windows Network Repair utility on your computer.
If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Linksys E1000 Wireless Router limited or no connectivity
What is the operating system on your computer?
Are you trying to connect to the wireless network?
on Windows XP computer you will get this message when the computer is not able to connect to the wireless network.
There are 2 reasons. You might have entered incorrect password or your computer is not getting IP address.
Read Limited or no connectivity
Oct 03, 2011 | Cisco Linksys E1000 WirelessN Broadband...
My router wont work when it is connected to the modem. the message that on there says limited access
If you already verified that your modem works if computer connected directly to it, try powering down router and modem. Start modem first and wait at least 2 minutes before starting router.
if this doesn't help you will need to verify that your wired connection to router works first before you can attempt to use wireless.
With your computer connected to the router try to open router setup page. Based on router type you should be able to access it from browser using: http://192.168.1.1 or http://192.168.0.1 you will need to login using default admin/admin account or according to router user manual. Configuration page will allow you to verify if you have Internet connection and configure other settings including wireless connection.
Mar 15, 2011 | Computers & Internet
No connection, cant install the software
You said that when you connect the computer to the modem, you get limited or no connectivity. make sure that your computer will be able to go online when you connect it the modem directly.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 07, 2010 | SMC Barricade 7004VWBR Wireless Router
Limited connectivity error
You need to enter the security code on the router to tell the router it is safe to communiate with your computer. This is to prevent others from hijacking your signal from the router.
Aug 12, 2009 | Computers & Internet
LImited or no connectivity on wireless router after reset
hi
go to the router wireless settings and check to see if the wireless connectivity has been disabled as a part of default settings
cheers
Pls rate if this was any help
Jul 04, 2009 | Microsoft Wireless Network Adapter Xbox...
"limited connectivity" message
If it's limited or no connectivity, you might have typed the wireless network key incorrectly. It's case sensitive. If you don't have wireless security enabled, you can simply delete the preferred networks on your wireless connection window then disable any firewall you have like windows firewall, norton, mcaffe, zone alarm and the likes. Also try to change the channel on your router to 11 and that will solve your issue. Restart the computer after that.
Jun 24, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Your router may be configured to "connect on demand". Enable the setting called something like "Keep Alive"
Jan 02, 2009 | Linksys Wireless-G Broadband Router
The router is not communicating with my pc
Hi there!
The limited or no connectivity problem is commonly caused by some of these factors:
1. router not giving out an IP address (no DHCP)
2. Incorrect network key or passphrase if you enabled wireless security
I want to help you out and I need to ask you these:
1. How many computers do you have?
2. Do you have a wired or wireless computer?
3. Is it laptop or desktop?
May 04, 2008 | Hawking AR740 ADSL Router with Modem
Linksys Wireless-G WRT54G Router Logo
158 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
