Question about Toshiba Computers & Internet
Won't stay on when the charger is not plugged in
Problem with Toshiba laptop
It stays on with Battery? Has the AC jack been damaged due to pulling on the cord while plugged in? Have you tried another cord/charger with the EXACT same power specs? Does the cord/charger charge the Battery? Charge LED lights? It sounds like a Graphics Adapter? If you connect to a external monitor is it the same. Your question/statement indicates multiple issues. 1 , Power, 2, Graphics. Can you clarify "color blank"?
May 22, 2013 | Toshiba Satellite PSLD8U-00G001 L355-S7831...
Toshiba satellite l355
If it works on batter for a while, it is not either the motherboard or the cpu
May 22, 2013 | Toshiba Satellite L355-S7831 laptop ac...
My PS3 headset won't charge it stays lit for 3
If there was no change using a new charger, I would suspect the battery is shot
Apr 23, 2013 | Radio Communications
How can I fix my hp61 of it won't start screen
You say the battery is charging? Have you tried another Cord/Charger with the EXACT same power specs? Has the AC jack been damaged due to pulling on the cord while plugged in? Any damage? Drop? Do you leave the Laptop plugged in while not in use?
Apr 13, 2013 | Computers & Internet
Battery won't stay charged
Bring the power cord/charger to a pc shop and have them test it. It might need to be replaced. Otherwise you need to replace the battery.
Jul 21, 2012 | Acer Aspire 55155879 Laptop Charger...
I have a jawbone jambox. The charger plug will not stay in the jambox, it just falls right out, therefore, it won't charge. Where can I get this fixed?
Dont know what these people are talking about.. but I have the same issue. Dropped it, now the charger wont stay in. I've taken mine apart, thinking I could fix it myself, only to find that the actual jack the charger plugs into has been broken off the circuit board. Not good. I'm pretty sure it's not fixable, thought I'm trying my best to find a way to replace the circuit board, as it's not very big. Email me if you've found a solution.iamlucasking@gmail.com
Oct 24, 2011 | Motorola Cell Phones
I accidentally left my camera on, and the battery died. Later, when I plugged it in to charge, the charger light just binks orange continuously. The camera won't turn on at all, and I can't get the...
I think the battery was already damaged,a rechargeable battery once you use it,it needs to recharge again so that the battery memory will stay longer.use a new one,regards....
Jul 03, 2011 | Samsung SL102 Digital Camera
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
Jul 22, 2010 | RIM BlackBerry Pearl 8100
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Computers & Internet Logo
13 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
