Question about Seiko 300 Lap Memory Stopwatch
Chane flat battery - Seiko 300 Lap Memory Stopwatch
Hello, could you please halp me. I chaned the batery on gucci 7700 watch but it want start working. chrono is working but the time does not. thanks
Please make sure the stem on the watch is pushed all the way in sometimes the stem can be out just a little and it will cause the analog to stop working. The only other explanation i can think of would be there is another battery inside you missed. Some watches have 2 to 3 batteries and they can be hidden underneath one another. If these two suggestions do not work you may have to go to your local jeweler! thank you! hope this helps!!
Sep 19, 2011 | Gucci 7700 Ya077513 Watch for Women
My skagen wrist watch has stopped .why?It has lifetime warranty
Your watch has lifetime warranty - not the battery. Battery should be replaced as soon as it goes flat. Do not leave flat battery in watch - it may leak and destroy the movement. Pop in your nearest watch repair shop and ask to replace battery. Rate me please.
Feb 28, 2011 | Skagen 528SSLG Wrist Watch
I want to change out batteries
1. Lay the watch upside down on top of a towel or cloth on a flat workspace. Use a small flat head screwdriver or blade to pry under the watch backing, then lift the backing from the watch. Slide the battery cover to the side to access and remove the battery.
2.Take the battery to any electronics store to purchase a replacement. Bringing the old battery will ensure you install the correct type of battery in your Fossil watch.
3. Replace the battery and the battery cover. Apply pressure to the backing until it "pops" back into the watch.
THANK YOU FOR VISITING FIXYA
Aug 05, 2010 | Fossil Dress - Analog Glitz Red Dial Watch
I cannot change the settings for the day, date
The depressing the top left buttom will move the watch between functions. Once on the function you want to chane, the bottom left button will select the group to change within that function and the bottom right button will adust the numbers. Hope this helps
Mar 14, 2010 | Field and Stream F58GGS e by Field &...
BAtt flashing on digital screen although I only
Yes, the flashing battery icon tells you it's time to change the battery.
Despite of that the watches are fitted with brand new batteries when they are leaving manufacturer, there can be a significant period of time till they reach their new owners and the watch battery can be flat (or allmost flat) at the selling point.
I suggest you visit sellers shop again a.s.a.p. and ask for the brand new battery to be fitted under the warranty.
Rate me, please.
Mar 24, 2009 | Tissot T-Touch T33759851
Dont know battery type for ecclissi watches?
Measure your original watch battery (diameter and height).
Compare with the cross reference list and find exactly what you want.
List is here: www.battery-info.co.uk/watch-battery-cross-reference.html - 19k - Cached - Similar pages
Dec 20, 2008 | Watches
I need to adjust Timex 1440 sports watch. could you help me please. I have top left as mode, top right start/stop,bottom left indiglo and bottom right is set. Thank you jyo
Go to the time mode,hold down the set button, it may take a couple of seconds and it will start blinking , then go to your mode button to move from seconds to hour to min etc.etc,etc. It probibly is your start/stop button for chaning the numbers. If that dosn't work, hold down the mode button on the time mode for a few seconds, and go from there.
Jun 29, 2008 | Timex Watches
Chane the batteries
good day dear cherished customer.
my name is eltoyosi and am here to help you.
You an change the batteries of your field and stream wrist wach by going to the back and gently getting the flip covering the backside of the wrist watch and there you will see the battery which needs replacement, you know replace the old battery with a new one recommended for field and stream F116GWBS
thanks
hope to hear how it went.
Apr 11, 2008 | Field and Stream F116GWBS Wrist Watch
Seiko 300 Lap Memory Stopwatch Logo
11 people viewed this question
Top Seiko Watches Experts
Vernon Taylor
Are you a Seiko Watch Expert? Answer questions, earn points and help others
