Question about Tablets & eReaders
How to reset ipad - Tablets & eReaders
My sister forgot her Apple ID on her iPad and she's 55 and can't remember her password what to do?
Under this circumstance you may have to reset the iPad if you forget both Apple ID and its password.
To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your tablet. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad . In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
Mar 19, 2017 | Apple iPad Tablets & eReaders
Tip
Restarting and Resetting iPad
Restart iPad: Press and hold the Sleep/Wake button until the red slider appears.
If you can't turn off iPad or if the problem continues, you may need to reset iPad. This should be done only if turning iPad off and on doesn't resolve the problem.
if the problems still not resolved Reset iPad settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media aren't deleted.
Reset all settings: Choose General > Reset, then tap Reset All Settings.
Reset network settings: Choose General > Reset, then tap Reset Network Settings.
Reset the keyboard dictionary: Choose General > Reset, then tap Reset Keyboard Dictionary.
Reset the Home screen layout: Choose General > Reset, then tap Reset Home Screen Layout.
Reset the location warnings: Choose General > Reset, then tap Reset Location Warnings.
on Sep 27, 2010 | Apple iPad (16 GB) WiFi Tablet PC
Re set ipad mini
Generally speaking, you need the Apple ID to reset your iPad. iPad needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPad, you need to enter the Apple ID when your iPad reboots.
But if you have no Apple ID or passcode, you will have to reset your iPad without Apple ID. To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your iPad. The following steps will show you how to do that.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad. In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
Jan 01, 2017 | Apple Tablets & eReaders
How can i get passcode
Unfortunately there is no way to get your pass-code back.
You can reset your iPhone using your i-tunes on your computer. Unless you have a restore date that is before the pass-code existed you will have to reset your phone.
You could also try to reset your pass code through find my iPhone on icloud.com but this may result in a temporary unusable phone.
you can follow this link to reset your phone:
https://support.apple.com/en-us/HT204306
Hoped this helped my best wishes to ya.
May 24, 2016 | Apple iPad (16 GB) WiFi Tablet PC
How do I fix IPad 2 freeze up?
Make a new back-up of your ipad, do a factory reset and then restore from the back-up.
The two most common reasons for resetting an iPad to the factory default settings are to prepare the iPad up for a new owner or to overcome a problem with the iPad that simply rebooting the iPad won't solve.
settings -> general -> reset
Jan 08, 2015 | Apple iPad 2 Wifi 16GB
How do i reset my Apple iPad to factory settings iPad 3
you need to connect your iPad to your computer and open iTunes software - there the iPad will show up and you can do a reset.
without a computer you cannot reset an ipad... Use iTunes to restore your iOS device to factory settings reset-apple-ipad-factory-settings-ipad-3-m4xgx2guitusdoftp1eyswas-1-5.jpg
Jul 09, 2014 | PANDIGITAL 7270FW Tablet
Reset ipad
You need to connect the iPad with an USB-cable to a computer and open iTunes software. there you will see your iPad showing up and you can do a restore:
reset-ipad-of1o0fkyrymqaiqlgkygvvrr-3-0.jpg reset-ipad-of1o0fkyrymqaiqlgkygvvrr-3-2.jpg Restore iPad to new factory condition
May 18, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Reset my ipad
How to reset you IPad completely:
1.Go to settings and select general.
2.Scroll to the bottom and there will be a separated Reset button.
3.At the top hit reset all settings.
It will reset your IPad to factory defaults and it will start up like a brand new ipad.
Warning:
The things you had on the IPad will never come back unless you back it up to icloud (witch I highly suggest).
Dec 14, 2013 | Tablets & eReaders
How to reset ipad
To reset iPad press the home button and the sleep/wake button at the same time for at least 10 seconds.The iPad should then reset itself.
Sep 09, 2012 | Apple iPad (16 GB) WiFi Tablet PC
How do i reset the passcode
If you forgot or lost your password for your iPad, you'll have to restore the iPad. Plug the iPad into your computer using the cable, and open iTunes. Click on your iPad in left pane and click the 'Summary' tab. Click 'Restore.' This will wipe all data from your iPad and effectively reset the device to factory settings, but it's the only way to reset the passcode.
Feb 26, 2011 | Apple iPad 64 GB 3G Tablet PC
Tablets & eReaders Logo
866 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
