Centurion manuals Hi, we have a D10 unit. The screen on top of the gate motor says Limits not set. How do we re set these
  • 188 Answers
SOURCE: I need to program a centurion gate motor receiver
Your gate controller reciever only has one code. You must set all the remotes to that code?
Posted on Jul 23, 2009
  • 28 Answers
SOURCE: Steps to program additional remotes for Centurion gate motor
hi
are the remotes sorted
Posted on Feb 23, 2010
  • 28 Answers
SOURCE: Need to program Nova remotes on a Centurion D5 Motor.
Hi
Have you managed to program the remotes
SOURCE: I have bought an additional
Steps to Programming Centurion Nova Remotes
1. Unlock the motor cover with your Centurion Key, remove this cover.
2. Inside the perspex enclosure there is a small Receiver Board (approx size of a matchbox), identified by wording CENTURION CP9Z, also has the wording J1-Learn; J2-Erase.
3. There will be a small 'shunt' placed on one of the pins labelled J1, J2 or the centre pin - these are the 'Learn' pins.
4. Remove this shunt and place it over (or bridge) the J1 and centre pin together. The red LED Status light, to the left of the Learn Pins will illuminate.
5. Remove the new Remote/Transmitter from its packaging, hold down the required button once and the red LED Status light on the Receiver Board will flash once indicating that the button has been learned. As soon as the light has flashed, remove your finger from the button.
6. If further Remotes/Transmitters are to be added to the system, repeat step 5.
7. Ensure that you now remove the 'shunt' and place it back onto the blank or J2 pin - do not leave it bridging two pins.
8. Close the enclosure, place the motor cover back onto the motor and lock in place.
Posted on Nov 03, 2010
SOURCE: Hi, I have a centurion
I have the same problem, i have replaced the bevel gears twice and that solved the problem for a short time. Take a look at the play on the bearing housing where the beve gear goes in. It most probably is worn.
Posted on Jan 13, 2011
How to program a ET BLU MIX remote on a older type centurion d5 gate motor
Ask the shop what to do when their suggestion does not work.
Oct 02, 2014 | Televison & Video
These gates have the ability to adjust opening, closing distances and speed. Your manual has the instruction. I would recommend a qualified technician make the adjustments as you have to get inside case(where high voltages are located).
Mar 12, 2014 | Televison & Video
Trouble shooting Centurion D10 gate motor
look for a loose wire and faulty earth check for wires shorting out to earth
Jul 14, 2013 | Cars & Trucks
Reset my centurion gate motor but when i push test button the gate stops half way
Hi there. When you reset the gate motor, did you remember to push the test button at the end of the procedure to confirm the travel limits? Did it complete the setup without a hitch, stopping in the pedestrian position? It might be helpful to check whether the status LED is flashing as this will give you an indication of what the problem could be. If you'd like to provide your number, I can get a support technician to give you a call and run through some diagnostic procedures with you.
Jan 11, 2013 | Cars & Trucks
How to programme a nova 4 button remote on a gemini gate motor
It's important to know that the Nova remote controls are not compatible with the Gemini gate motor. In order to get these remote controls to work with your Gemini gate motor, you'll need to install a Centurion receiver first (see http://www.centsys.co.za/upload/product_link_files/CS37_Nova_Receiver_Instructions_1031.D.05.0012_4.pdf). Once the Centurion receiver has been installed on your Gemini gate motor, follow the programming instructions as per the leaflet that accompanied your brand new Nova remote control, or download the instructions from http://www.centsys.co.za/upload/product_link_files/English_Transmitter_InsertCS37_1031.D.02.0027_1_Nova.pdf
Feb 22, 2012 | Televison & Video
Hi
Sep 07, 2009 | Televison & Video
Jul 15, 2009 | Home Security
Televison & Video Logo
339 people viewed this question
Top Televison & Video Experts
