Question about Sony Handycam Video Cameras
Camcorder hinge lcd - Handycam Sony Video Cameras
Hi i have a sony dcr-pc55e and when i go to use it the lcd screen falls down and doesn't hold in place, do i need a new hinge or bin the camera?
Sounds like you need to have the hinge assy replaced. This should probably be done by an experienced technician. Amazon is still selling this camcorder for $585 so it is probably worth repairing...unless there is another camcorder with more bells and whistles that you have been wanting, then I would recommend putting that money towards a new one.
Hope this has helped.
www.austintelstarservices.com
Sep 04, 2010 | Sony DCR-PC55 Mini DV Digital Camcorder
My camcorder LCD screen is not on when I am puting on the switch.
you should replace the lcd switch in the hinges area..I got this problem before and seams to be a usual one for the panasonic...some models just display a flip word on it ..when it is not detected open ..
May 30, 2010 | Panasonic SDR-H40 HDD Camcorder
My dvc NV-GS25 lcd screen is not working
Common problem with this model, flat cable that connects lcd assembly to the main board is broken, replacement part comes as hinge assembly witch includes cable and the hinge.
Nov 11, 2009 | Panasonic NV-GS25 Mini DV Digital...
Samsung camcorder nt working
Hi the LCD ribbon has cracked or broken where it passes through the hinge to the screen.. regular fault.. I have posted instructions for home repair, and part number from Partmaster.co.uk.. if you still need help..stefan.
Mar 04, 2009 | Samsung Compact MiniDV Digital Camcorder
No image on viewfinder
There is a short in the wiring were the hinge is at. You can take into a camera store or Best Buy and see what it would cost to replace the wiring in there.
Nov 19, 2008 | Canon DV-MV830i Mini DV Digital Camcorder
Bad colors on Swivel LCD Display
it is more than likely the flex in the hinge for the lcd. the hinge might need changing. suggest the camera be taken to a qualified panasonic tech.
May 31, 2008 | Panasonic PV-DV103 Mini DV Digital...
Panasonic PV-GS35 Viewfinder screen connection problem in hinge joint
the hinge is definetly damaged and is going to need replacing. these hinges do need replacing if used allot because this is a moving mechanical part. This is not a easy thing to do, it needs to be done by a panasonic technician.
Oct 11, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
LCD is not working
Hello, in order to repair this Camcorder you should replace the LCD panel flexible cable FP-185 and the plastic hinge cover. If you need more info please advice. Best regards. Arpi
Apr 26, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Video Cameras Logo
11 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
