Question about Dryers
Fisher paykel reset
Where is the reset button
SOURCE: Fisher and Paykel dryer not drying
I've had this problem for 3+ years. There are possibly multiple reasons why your dryer trips the reset switch. My dryer has a design issue with the lint trap, in that it allows lint to build up around what I assume is the heat sensor / thermal switch. It's simple, the temperature is detected as too high in the dryer and trips the switch which cuts power to the heating element. The reset switch access as mentioned in other posts requires either tipping the dryer back or removing the front panel, at least partially, to access the switch. After the reset switch is pushed, you'll need to check if there's lint built up that's causing the reset issue. First, find the reset switch.
To access the switch, there are 4 Phillips head screws that need to be removed. For the first 2, lift the dryer lid and you'll see two half-moon shaped rubber inserts at each of the front corners of the machine. The inserts can be pulled out with your fingers or use a screwdriver, gently. There is 1 screw under each insert that needs to be removed. Once those screws are out, you can put the lid down and lift the plastic top of the dryer that the lid normally rests on. It's attached on the back of the dryer so don't worry, it won't come off...it will lift just like the dryer lid. Be careful of the sharp sheet metal edges. Now there are 2 smaller screws, 1 at each front corner, that attach the sheet metal pieces. Remove each of those screws. To get the front off requires a bit of finesse. You'll see that the front sheet metal panel of the dryer has bends in it to attach it to the sides of the dryer. Gently pull at the top corners, one at a time, to separate the front panel from the rest of the dryer. You'll see that there are u-shaped orange or red plastic pieces inserted into the sheet metal sides that align with holes in the front panel to hold the skin of the dryer together...the front should just pull away from those u-shaped pieces. There is a wire with a clip attached to the bottom of the front panel, probably a ground wire...if it pulls off when you remove the front panel, just reattach it when you put everything back together. The front sheet metal is also integral to the front feet of the dryer, so tilt the top of the front panel toward you and lift. The front panel should pull away. When you put the front back on the dryer, do it feet first by aligning the plastic foot pieces, then align the u-shaped side pieces, then worry about the top corners wrapping back around so the front fits flush.
The reset switch is in front at the bottom right of center and is probably orange. Just push it and you'll hear it click. I would vacuum out the lower part of the dryer at the point, but it's probably not what's causing your problem. I've gotten to the point where I use a yard stick or vacuum extension to push the switch without completely removing the front panel. Then I don't have to detach / reattach the ground wire. You'll see after you do it 3 or 4 times!
Now check to see if lint build up is causing your thermal switch to trip. Pull out the lint trap and you'll see 1 Phillips head screw behind where the lint trap normally sits. Remove the screw, and you'll feel the circular plastic piece the lint trap sits in become loose...pull this round piece out of the dryer from the bottom. If there is a lot of lint behind this circular plastic piece, that's probably what's tripping the heat sensor. Vac it out. Gently feel around the circumference of where you removed the piece to see if the fine mesh lint screen has any holes (if it does, it may be blowing lint into your exhaust and eventually clog the vent to the outside). If the mesh is torn, I assume that larger circular piece needs to be replaced at some point in whole or part. From what I can see, the design of the lint filter and trap is ....****. The system allows lint to enter the area where the heat sensor sits.
The short term fix is to vac out the sensor area regularly and that will keep the switch from tripping, if that is your actual problem. I believe F&P is aware of this issue and will probably remedy it for you. I called them once when this issue originally happened and had to wait for a tech to come out do what I described above. I haven't called them since, but have seen other posts regarding a new part or parts that F&P will provide...hopefully free! Good luck!
Posted on Jan 10, 2009
SOURCE: lint assembly-Fisher and Paykel DEGX1
Pretty easy on the lint assy;
Remove the lint cup;
Find screw (5) in a recess at the bottom of the lint cup area;
This will allow removal of the perforated lint surround, and the 'lint scraper'; Also will expose the moisture sensor (3) hanging off wires at the bottom of the assy;
At the bottom of the surround there is another recessed phillips screw; remove this, then twist the surround (14) counter-clockwise about 1/2" and remove to expose the filter (13).
<img src="http://img50.imageshack.us/img50/9130/outlectductsh4.jpg" alt="FP Dryer Lint parts"/><br/>
Not sure on the reset- I do know the top swivels up after removing the two screw caps and screws at the front of the unit on either side. This exposes the underside of the control panel; there are screws at the back of the control panel also.
Posted on Apr 24, 2008
  • 3 Answers
SOURCE: Cannot find the reset button
You can download parts diagrams here
http://fisherpaykelparts.net
Posted on Feb 03, 2009
  • 353 Answers
SOURCE: where is the reset button on a Fisher & Paykel
reset buttons are usually at back of machine and coloured red just push unplug first
Posted on Jun 30, 2009
emissionwiz
  • 80444 Answers
SOURCE: where is the reset button on my fisher paykel dryer
reset? just unplug it for 5 miinutes.
Posted on Sep 19, 2009
The reset button on my fisher and paykel gas top load dryer does not move when I press it should I try to by-pass this button?
would not recommend any bypassing ,bypassing will only cause more damage to other possible components or safety,i would have it tested for any defect so that you can replace it.
Jan 13, 2015 | Fisher and Paykel Dryers
Fisher paykel dryer resets repeatedly
this indicates it is getting too hot try running without vent attached if it runs ok it is a pluged or crushed vent
Nov 19, 2013 | Fisher and Paykel DEGX1 Electric Dryer
Fisher paykel 5.0 smartdrive washine machine
No reset button in these machines.
Check your lid switch & display board for corrosion.
Apr 20, 2013 | Fisher and Paykel Washing Machines
After replacing a hot water hose on my Fisher & Paykel Smart Drive 603, the machine now needs to be rre-set I think. Where would I find that button please??
Hi just read your posting.Why do you think the machine needs to be reset?Is the machine working?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
May 20, 2011 | Fisher and Paykel Fisher & Paykel Washer
Dryer does not dry, looking for the reset button. Where is the button and how do i get to it?
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Oct 07, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Degx1 dryer where is the reset button on this machine ser# EHN 302448 fisher-paykel
Jul 23, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Reset Fisher and Paykel washing machine
HOw to reset the Fisher Paykel machine. Mine one keyborad working but machine doesn't function. Where is reset button please?
Feb 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Where is the reset button on a Fisher & Paykel DE09 dryer?
Jun 30, 2009 | Fisher and Paykel DE09 Dryer
Dryers Logo
134 people viewed this question
Top Dryers Experts
