Question about Asrock K7VM4 Motherboard
Bios non ACPI compliant - so it says!
When I try to boot up my computer I recieve a blue screen message saying that the bios is not ACPI compliant. I flashed the bios and all seemed to go well but the same message still keeps coming up. What can I do?
From memory I think it's a Athlon AMD 2600 with 512 Mb Ram and 80 Gb HDD. One of my main concerns is losing any data on the HDD. I don't think it is a problem with that though, it seems to get stuck before it gets into windows.
  • kenh63 Feb 16, 2008
    Thanks Haltech,
    I seem to have sorted the problem. A friend suggested checking internal connections. It may (stress MAY) have been a loose connection with the CPU fitting into the motherboard. After checking some of the connections and finally taking out the CPU chip and replacing it back in the system, it seems to work again.
    Cheers Ken.
  • garun21 Jan 04, 2009
    Blue screen error while installing windows XP STOP error code oxooooooA5. Please help
  • 33 Answers
Try this, go to CMOS/BIOS setup and disable APM and legacy USB support. See whether the BSOD is coming back or not. Hope this help.
Posted on Feb 07, 2008
The bios in this system is not fully acpi compliant
Guess your computer is not compatible with Windows 7. Reinstall windows XP run compatibility test from Microsoft
May 16, 2014 | Dell Inspiron 15 (N5050)
ACPI Problem while installing Windows 2003 server Enterprise Edition in Toshiba i5
hi, you have to boot you laptop normally before installing new windows,
go to toshiba website, update bios to latest version for your laptop model, and then try again.
Dec 08, 2013 | Toshiba Satellite Computers & Internet
Asus eee pc bios in this system is not fully acpi compliant
These errors can be misleading. Try setting the BIOS to default.
Remove all USB attached devices.
Test one DIMM at time. One slot at a time. To eliminate possible bad RAM. Unplug PC. Opening case. Remove all RAM. Use static precautions!
Re-install Windows. Clean install works best. All data will be lost.
Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Oct 09, 2012 | ASUS Eee PC 1015PEB 10.1 Netbook 1.66GHz...
Can't find updated ACPI Bios for toshiba satellite m45 s331I am Getting blue screen Bios in this system not fully ACPI compliant.
Upgrading the bios it will not fix the issue ..cause the blue-screen is either a unsupported setting is a operation system issue ..So ..if you get the blue-screen when you boot up ..and does not let you to get into bios..It may be the ACHI (not acpi ..cause the acpi is the power management ) being enabled and not having the driver installed..and in this mode will not be able to boot and will give you that blue screen ..
To fox it ..just go to bios ..and look for the hard disk ..and in teh same category you will see the achi function ..and just disable the mode..and let it run as IDE..This way it will boot fine ..
Indeed the achi mode for a hard disk faster and if you do want to use it ..try to boot without the achi enabled..and install the achi driver in the system ..and after that enable it again and see if it works..
If it still does monkey business than it will have to be reinstalled ..and if you still want achi for hdd have to install the driver during the installation a 3rd party driver ..
In short ..try to make it run ..and do not mess with the BIOS ..cause you may end up with a broken laptop ..
Feb 17, 2011 | Toshiba Satellite M45-S331 Notebook
Blue screen of death says acpi bios noncompliance. Help!!
Did you change something in the bios? Enter the BIOS and check the Power Management or just Power settings and disable ACPI. This should solve the problem.Windows would again find new hardware and then should work normally.If ACPI not found under power it could also be under Advanced tab. Did you install any new hardware?.The hardware might be non ACPI compliant hence the error.
Jan 21, 2011 | HP Compaq Presario SR1303wm PC Desktop
It's possible that the BIOS setup has been accidentally set to non ACPI mode. Check in the setup to ensure ACPI is enabled.
Other possible causes that have been pointed out are memory expansion, overclocking and incompatible driver software. Check out what you have recently installed or updated on your computer
removed RAM from one slot and boot
or check the bios update
good day and rate solution if it helps
Nov 22, 2010 | Intel D845GVSR Motherboard
Netbook bios not fully acpi compliant
you are experienceing the blue screen of death, if these happened to yo have your netbook check by a qualified laptop tech to avoid any hardware damages
Nov 22, 2009 | ASUS Eee 4G Notebook
ACPI BIOS not fully compliant
w8000 a very old PC not supported by HP.
windows 2000 support ended like 15 years ago.. W2k. is gone. w2k only runs on very old pcs with very old ACPI
(power controls is that)
this PC is only supported with XP
never 2000.
HP tells you that if you looked.
park the 2000 disk or use it as frezzbee. IMO
id get w7 disk and use that, it might work.
but will cost you a license from MS,
about 5 times the value of w8000
why not just go here, and get used $20 w7 pc
save a bundle of case and grief messing with any legacy junk....avoid legacy junk and win.
a usa answers.... always...
Jul 19, 2017 | Compaq Computers & Internet
Dell Inspiron 1100 Bios and ACPI
Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
Manually install the Standard PC hardware abstraction layer (HAL):
1. Reboot the computer to restart Setup.
2. When Setup starts again, press F7 when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL. You should also contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant
Mar 16, 2009 | Dell Inspiron 1100 Notebook
Asrock K7VM4 Motherboard Logo
1,119 people viewed this question
Top Asrock Computers & Internet Experts
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
