Question about Boating
Mercury 60hp 4 stroke - Boating
    New Friend:
Changed water pump impeller can't get transmission work
Posted on May 15, 2016
2013 MERCURY 60HP 4STORKE OUTBOARD FIRING ORDER. REPLACED SPARK PLUGS LEFT PLUG WIRES ON COIL, COIL READ 2 3 1 4, PLUG RUN VERITICAL SO DOES #2 FROM COIL GO TO THE TOP SPARK PLUG ETC
try bottom plug on left bank
remember it is a 4 cylinder engine with the leg attached to the harmonic balancer in a car
the firing order is 1342 from the bottom end of the engine
Oct 09, 2017 | Mercury Cars & Trucks
I have a 2014 60HP Mercury outboard 4 stroke motor, where is the voltage regulator and how do i replace it?
It's on the Port side of the engine. Just above the oil filter. There are some electric connetors bolted at the same time.
It's held on the engine by 2 metric 6 bolts, use a 10mm wrench.
Partnumber 893640T01
Sep 22, 2017 | Mercury Boating
I have a 20 hp mercury outboard serial#06082001.I want to know what year it is and if it's 2 or 4 stroke
If you drop the first zero it would put it at 1981.
http://www.themarinedoctor.com/msn.pdf
this site gives a different answer, as 1980- 81, so close. It SUGGESTS it is a 4 stroke engine.
http://www.boats.net/parts/search/Merc2/Mercury/25%20%282%20CYL.%29%282-STROKE%29%28International%29/parts.html
It is likely a 4 stroke, but I won't give you a definitive answer, due to the damage it can cause with a guess!
A four stroke running with two stroke oil will just smoke, but a two stroke with no oil will seize and leave you stranded on the water with a seized engine!
A four stroke engine has valves operated by push rods or a pulley and a chain, a two stroke just has a head. Take a look at the engine and it should be obvious.
For your first service, I would suggest you go to a marine engineer. Ask all the questions, and get the right answers. When I had my 1986 Evinrude serviced, i typed a list of questions and left the list with him. i asked him when I picked up the boat and wrote the answers down. The first one was 'petrol to oil ratio and which is the best oil'. A basic service will cost you a hundred bucks and you will have some comfort that you are unlikely to break down, 6 miles offshore with only a paddle :)
https://www.google.ca/search?q=20+hp+mercury+outboard+serial%2306082001&ie=utf-8&oe=utf-8&gws_rd=cr&ei=uwm-WKjHK6SUjwSApJLQBw#q=mercury+outboard+serial+number+lookup&*
Mar 07, 2017 | Mercury Boating
Hi there I have a outboard Yamaha 2002 4 stroke 60hp I just want to know what's the reading psi compression Test should be thank you very much cheers
same as a car engine
150-165 psi with a variation of no more than 10% between cylinders
contact a service center and ask them for the compression pressure and how to do the test
Nov 27, 2016 | Yamaha Motorcycles
My Mercury 2cycle, 3 cylinder,60HP outboard run good on 3500-4000 rpm, when I enter no wake zone and run about 1500 rpm motor missfire and makes WOOSH SOUND every few secs. What possibly cause this?
Hmmm... could be build up of exaust pressure in the housing, released after so many piston strokes? Never heard of this. Your exaust is pushed out thru the shaft case.
Aug 04, 2016 | Boating
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Jun 25, 2015 | Mercury Marine 15hp & 20hp 4 Stroke...
Boating Logo
520 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
