Question about Moen Home
How to replace moen 4000 cartridge
I replaced the cartridge on my Moen kitchen faucet and now there is a gap between the handle and the base
2 Suggested Answers
  • 7 Answers
SOURCE: replaced moen teo handle cartridge 1224 now faucet
the lines the cartage attaches to will have seals or teflon tap. if the seal has a small nick, it will leak. Or if the tape was applied in the incorrect dircection or was cut it could also creat a leak
Posted on Jul 21, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Moen 7600 kitchen faucet leaking from around handle
    You will need to replace the cartridge....
    here is tutorial on how to do that...
    http://www.ehow.com/how_7241891_do-repair-moen-7600_.html
    If you find that the cartridge will not come out you may have to purchase a Moen cartridge removal tool... you can get them at Lowe's or many othere plumbing supply houses....
    http://www.bing.com/search?q=moen+cartridge+puller&form=HPDTDF&pc=HPDTDF&src=IE-SearchBox
    heatman101
    May 14, 2011 | Microwave Ovens
    Re: Moen single-lever kitchen faucet like the 7100. When I replace the lever, it only goes up. I can't get it to go down. I'm pretty sure the cartridge is in right, with the U-clip and the other screw-on...
    The water supply should have no bearing on the working motion of the faucet cartridge or handle. On both models of Moen faucet, the handle needs to be hooked under the cartridge's top cam bearing. It is a bit tricky sometimes. Here's the parts view for 7300 and 7310 Moen Kitchen faucet. Parts view for 7100 Moen.
    If you need further assistance please let us know.
    Sep 16, 2010 | Moen 7310 Legend Single-Handle Kitchen...
    Handle won't stay up
    I did the same thing recently, that is replaced the cartridge on my moen kitchen faucet to stop and leak, and I also have the same problem. I called moen back and they sent me another cartridge that was supposed to fit tighter, I suppose. I just put the new one in and it still wont stay up. I'm going to call moen one more time and then I guess I'll have to buy another faucet, but NOT moen!!! Good luck with yours.
    Jun 05, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
    How do I get to the valve cartridge to replace it?
    how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
    Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    Replace cartridge in Moen kitchen faucet and now
    it probably has a plastic cartridge,remove it, and push the center piece out slowly and firmly. wipe this down,not completly this is what carries the wieght of the handle.give this a shot.
    Jan 12, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    Moen single handle kitchen faucet, Hot water and
    Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
    Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Replacing Moen O kitchen faucet O ring
    if it is dripping from the spout then there is a cartridge that needs replaced...1225 for the single handle type and 1224 for the 2 handle type. Moen does not use O-rings in their valves. If it leaking around the base of the spout there is an oring kit that you will need and you will have to pull the spout off to access them. Most Moen faucets use a 117 kit for the spout but there are some different ones.
    Oct 19, 2009 | Moen & Replacement Cartridge
    Moen 7065 leaking at base of lever control in kitchen faucet
    Yes, a cartridge will probably solve it. There are two different Moen cartridges so be sure to take the old one with you so you get the correct one.
    Apr 05, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Home Logo
    71 people viewed this question
    Top Moen Home Experts
    Mike
    john h
    Andrew Bugbee
    Are you a Moen Home Expert? Answer questions, earn points and help others
