Question about T-Mobile Cell Phones
Black screen with message pervacio diag v1.0.50 what I do?
Why does screen go black or white by itself?
There are 3 step to repair black screen error
If you got black screen error then there is a 94% chance that your computer has registry problems. To repair black screen error you need to follow the steps below:
* Step 1 - Download a black screen error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair black screen error.
Here are the url of black screen error repair tool:http://www.FixError2010.com/ttfix-black_... Source(s): http://www.FixError2010.com/ttfix-black_...
Sep 22, 2015 | Computers & Internet
Previous voltage failure
Did you install any new hardware prior to this message appearing? Like a new video card? If so, the power supply could be overloaded. If not, the PSU could be failing. You can also open up the case and check the motherboard for blown capacitors (do a Google image search for blown capacitors to see what they look like). If the caps are bulging, the motherboard needs to be replaced. Depending on the manufacturer you can also run a diagnostic to determine the issue. Most of the large PC makers (Dell/HP/etc) have their own method/software for diags.
Nov 15, 2011 | Microsoft Windows XP Professional
Windows 7 dell inspiron 1546 error code 2000-0146
HDD Read error, boot to the 32 bit Dell Diags, Custom, HDD, run the diag there. If you get a 0F00:xxxx error in the 32 bit diags then replace the HDD
Jul 23, 2011 | Dell Inspiron17 Notebook 22GHz 500GB 173...
I have a Dell Dimension 3000. Worked fine until we went to turn it on one day and the monitor stayed black. I'm assuming it's the video card that's the problem. I need to know what card is compatible. ...
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
The links in that article will allow you to determine where the failure is on you system (The power LED indications and the Diag LED indications on the back of the system)
Post back with the indications of the POWER and DIAG LEDs on the tower if you need more detailed instructions.
Feb 12, 2011 | Dell Dimension 3000 PC Desktop
SCREEN GOES BLACK WHILE I'M WORKING, I CLOSE THE NOTEBOOK AND REOPEN IT AND THE SCREEN REAPPEARS FOR A CERTAIN TIME
The problem is caused due to a bad inverter cable. To fix the issue you have to reseat the inverter cable or replace the same. For which you would require specialized tools and tech knowledge. To check if the computer has no other problem apart from the LCD. You can run the dell diags on its
1. Shutdown the computer
2. Hold down the Fn key + the power button
3. The diags would get activated
Follow the screen prompts. If the screen blacks out during the tests its bad inverter cable or LCD.
Thanks
Proton
May 25, 2010 | Dell Latitude D600 Notebook
I changed hard drives and now I can't load my programs back on
ok thanks for you prompt reply.
when you say laptop not reading HDD it allows you to see dell logo but after that there should be a msg an error msg saying no boot device been found..or just a black screen?
check BIOS if hdd is detected. if yes then it means windows is problem probably but we need to double check on this. run diags on the hdd alone use the dell diags disc. check if you get erorr code. running the diags is like this. keep tapping on F12 after seeing dell logo then insert disc when you see the options. select cd dvd rom drive then press enter then run diags custom test for hdd.
Dec 08, 2009 | Dell Latitude D505 Notebook
Rainbow screen
Try running hardware diags by turning the computer off, holding down the Fn key then turning the laptop on. If you get an error message, write it
down and call Dell tech support.
Oct 01, 2009 | Dell Inspiron 1501 Notebook
Dell dimension 2400 blue screen fault - page fault in non paged area. bug code 50. did system restore and changed memory board still faulty jim brand
Most likely the computer itself, the mother board in the Dells aren't very good. I would suggest the next time you buy a computer you should get a Mac. You'll have no problems at all, and you'll find that Microsoft Office for Mac runs far better too.
Sep 26, 2009 | Dell Dimension 2400 PC Desktop
Screen reads FACTORY DIAG MODE
I had the "Factory Diag Mode" and was dismayed that I could not find a solution in any of my online searches. But I finally got it to work with only a minor side-effect, so I thought I'd share.
I originally tried the following from the "Live XM" mode:
Go settings, setup, restore defaults, restore setting only.
That didn't seem do anything for me. Then I tried the same thing from the "My Music" mode.
That fixed it!!!
The only thing that I noticed that I lost was my channel favorites (hardly a worry at all). All of my saved songs and playlists are still there!!!
Hopefully this will help a poor soul in need
Apr 06, 2008 | Samsung NeXus 25 MP3 Player
Mymonitor is black and the on button from the monitor is green and is flashing
i havent seen this question asked, and believe me i have searched. i have compaq presario, windows xp media edition 2005, 64 amd processor, model # SR2017CL, with HP 1703 17" monitor. Prob-put computer in hibernate mode other evening, without turning it off. when i woke up, screen had diagonal lines going across it. i rebooted, well manually restarted, since comp would not respond.
Message comes up white with black writing, essentially, prob with active desktop, restore or turn off. i tried to turn off and screen went back to diag. lines. looks like the horizontal hold of a tv screen is asque. tried adjusting monitor to no avail.
tried a few more times, was fine for a few mins then went to same thing. now when i turn monitor on it blinks red, blue, and so on.
just whole screen that color. so i am at the point where i dont
know if its the comp or the monitor. (i am quite a newby)
ty for any help you can give
ellie
Jan 30, 2008 | HP Pavilion F1703 17" LCD Monitor
Cell Phones Logo
95 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
