Question about Whirlpool WTW6600SW Top Load
WHIRLPOOL CODES F-54
MY WHIRLPOOL WASHER MACHINE SHOW CODES F-54.
3 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: CODES F-54
Unplug the unit for 15 minutes then plug it back in. IF that does not work then it is a problem in the main board and the main board will need to be replaced. This is a very uncommon error code. You can go to repairclinic.com and order the part that will fit your machine
Posted on May 21, 2009
  • 58 Answers
SOURCE: F-54
F-54.. Motor Control Overcurrent. The machine motor controller is detecting high voltage at the motor.
This is usually caused by something lodged between the inner and outer tub. The first thing to do is see if the tub moves freely & smoothly by hand. if not, Then you need to open the top of the machine and remove the splatter guard and turn the drum till you see the obstruction then fish it out. If on the other hand it is free and smooth then there are tests that need to performed to determine the source of the code... Hope this helps... Bill
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Cabrio washer wtw5500xw0 loud spin and grease on floor
    FIXED Cabrio has loud noise during spin - ApplianceBlog
    www.applianceblog.com/.../16339-Cabrio-has-loud-noise-during-spin
    Aug 21, 2009 - 10 posts - ‎5 authors
    Help Jake I have a Whirlpool Cabrio model WTW6600SW2 it is almost 2 ... a week just started making a very loud noise only during spin sounds like ... size washer (110.297) (loud whirring and grease splatter) and am trying to ...
    How to tell if your bearings are bad on a Whirlpool Cabrio ...
    ? 1:01
    https://www.youtube.com/watch?v=5rHn13lKjzc
    Jan 19, 2012 - Uploaded by RenewAppliance
    http://washerdryerrepairhelp.com/whirlpool-cabrio-maytag-bravo-and-kenmore-oasis- ... My floor under the washer machine hasgrease/oil marks. ... and make the suspension bad when it spinsmine has been like this for about 2 months now ... Noisy WhirlpoolCabrio washer during spin - Duration: 0:54.
    Jan 16, 2016 | Washing Machines
    Door won't open on front load washer
    How to Unlock a Whirlpool Duet Washing Machine ' Home ...
    homeguides.sfgate.com > Mortgages > Mortgage Options
    If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
    How to open a washing machine door that won't ... - YouTube
    ? 3:57
    https://www.youtube.com/watch?v=-65_eoT6zuk
    Aug 22, 2013 - Uploaded by how-2-repair.com
    Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
    Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
    Cabrio clothes washer codes f68 f84 f32 are shown
    Before you do anything, Contact Whirlpool service with your model and serial number. There and many recalls on their Cabrio washers for control board problems.
    Feb 28, 2015 | Whirlpool WTW6400SW Cabrio Washer
    It starts and then stops and then F28 flashes
    http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
    Not good! Probably motor control board or motor or wiring harness from control board to motor.
    This leads to a Kenmore Video
    Whirlpool, Maytag, Kenmore. Same machine different name different trim.
    Whirlpool Duet f28 YouTube
    Sep 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
    F- code does not show code in book what and how to remedy the problem?
    Hello there again here is some more info for you
    Whirlpool Washer Troubleshooting: Error/Fault Codes Whirlpool Washer Troubleshooting has been made easier since newer Whirlpool washers generally display a consistent range of error codes (or fault codes) when problems develop so that owners and service personnel can quickly troubleshoot the problem and fix it easily. The Fault codes address a wide range errors that occur with Whirlpool washers, everything from water and power problems to basic maintenance routines. We have put together a comprehensive list of Whirlpool Error Codes for some specific and general Whirlpool Washer models to help you with your Whirlpool Washer Troubleshooting task.on next post
    Oct 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Alarm which we do not have before. normal cycle. also on a rinse cycle. ocasionally loud banging noise.
    You didn't mention if the machine was giving any error codes. Do the following steps to get any stored error codes and post them back to me.
    Select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
    Jan 31, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
    Hello my washer is giving me a f11 code
    I'm judging you have a front load Duet washer. The F11 code means there is no communication between the central control unit and the motor control unit. Whirlpool has some poor quality control on it's circuit boards and there's cold solder joints that cause F codes like yours to show-up. All the relays and spade connectors on the upper circuit board need to be touched-up.
    Oct 18, 2010 | Whirlpool Washing Machines
    F-54
    May 21, 2009 | Whirlpool WTW6600SW Top Load
    CODES F-54
    Whirlpool WTW6600SW Top Load Logo
    220 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
