Question about Kenmore Washing Machines
Kenmore wash machine model #110.20022011 overfills
  • 1462 Answers
SOURCE: Hotpoint Washing Machine Model # VBXR1060T4WB Filling Problem
problem could be the pressure stat which is a switch which detects water level or the pipe leading up to this switch or the air chamber the pipe goes to.
take top off. locate the pressure switch - has a small diameter pipe going to it. remove pipe and fit a similiar one. put on fill and pressurise this pipe by mouth and water fill should stop. if it doesn't, then switch is faulty.
if this is ok, examine carefully the small diameter pipe for splits and blockage. also check the air chamber for build up of gunge
Posted on Nov 16, 2008
  • 1122 Answers
SOURCE: kenmore 70 series washing machine overfilling with water
try it just on cold water let run,turn off if water stops it not the water valve,do the same thing on hot,if either one does not turn off it is the water valve,if they both turn off then you need to check the water level hose from the switch to the tube,if both ends are secure then the water lelvel switch is bad,let me know what you find-mike
Posted on Apr 09, 2009
TheMobilian
  • 8220 Answers
SOURCE: Washing machine overfills
Grab the tube off the water level switch that comes from the bottom of the tub and blow it out so that the sand in the bottom won't be blocking the operation,pump out the water, secure the tube tightly to the pressure switch and retry.aff8f03.jpg
Posted on Jun 10, 2009
Maytag317
  • 1136 Answers
SOURCE: Kenmore series 80 washing machine overfills
Hi, The first part to check is the inlet valve. If you shut the washer off, will the water stop? If the water continues when the power is off to the washer, change the inlet/mixer valve.
If the water stops filling when the power to thee washer is shut off, the water level switch needs checked.
Please let em know if either of these help so I can assist you further.
Vic
Posted on Jun 20, 2009
  • 57 Answers
SOURCE: Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Posted on Oct 10, 2009
My washing machine stops
FL = Overfill
You should check your pump. If the pump is letting the washer overfill, replace it. Look around for some ways to take the cabinet off.
Jun 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite washer model 21082000, won't
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 19, 2010 | Kenmore Elite 21082
Machine stoped after wash cycle tub did not drain and reads F L kenmore elite calypso model #22064 100 type 170 cannot get it to start at all it keeps beeping and reads FL
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%#@$
Feb 09, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
The washer will flash the code FL what dose this mean??? thanks for the help model 21062
fl flashes if any overfill condition occurs.this condition occurs when excessive water in the tub causes the overfill switch to trip.the control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for fl to be displayed.with an overfill condition ,the beeper repeats a warning every 10 seconds with no time-out.the pump is cycled in drain mode for 30 seconds on 30 seconds off untill the overfill switch resets or power is discontinued to the unit.press stop/cancel to clear the display.
Jan 08, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore Catalyst washing machine, model #110.20056 992, that is triple beeping and only allowing one wash cycle type. Is there something I can fix on this?
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Jun 19, 2009 | Kenmore 3.2 cu. ft. Top Load Washer
Washer will overfill on small load and large
If this happens only on small load cycle , then it can be a faulty timer board.
however check also the water level switch, when there is overfilling this part is always the first suspect.
May 21, 2009 | Kenmore Elite 21082
Code FL, won't empty tub on last cycle
FL = Flood condition
This problem i see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
May 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 90 series washer overfills
your pressure switch may be bad or your hose that goes from your tub to your switch may be clogged with gunk
Mar 07, 2009 | Kenmore 22422 Top Load Washer
FL ERROR MESSAGE
Hi and welcome to FixYa,
Initially, "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed. With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Dec 04, 2008 | Kenmore 24902 Top Load Washer
Washing Machines Logo
fordexpert
Mike Squire
Robert Rankin
