Question about Samsung Dryers
Samsung FE error - Samsung Dryers
Why would a Samsung gas dryer, model DV400GWHDWR-AA cutout and show a FE code after about three seconds after pressing the start button?
Samsung Dryer Error Code = FE
Error Condition = Power supply out of range (frequency)
Check and or Repair = If the dryer is getting the power it requires then replace the electronic control panel board.
Parts For Replacement = Electronic Control Board
Sep 26, 2016 | Samsung Dryers
I get an FE code on my samsung WD0704RQQ short time after setting the machine on dryer mode. Please help as my manual doesnt have the code and its meaning.
http://appliancejunk.com/forums/index.php?topic=17042.0
I SUGGST REMOVING POPWER, SHUT OFF BREAKER, THEN RESET, IF IT DOESNT HELP IT WOULD NEED SERVICE
Apr 14, 2016 | Samsung Washing Machines
Code FE on samsung dryer??
Hello. The FE error indicates a problem with the incoming AC power. It means the frequency of the power (which is normally 60 Hz) is incorrect. Check the wiring to the dryer, also, is this unit from a foreign country where the power is 50 Hz? The dryer has line filtering built in--make sure the incoming power is correct and that the wiring to the dryer is correctly connected! Get back to me on what you find.Thanks!
Oct 31, 2015 | Samsung Dryers
How do I fix a fe code problem on a Samsung dryer
According to the Samsung website, here is the description of your problem:
FE
  • The FE code indicates a problem with the power source. Loose or incorrect wiring probably exists where the dryer connects to the power cord, or the power cord is the wrong type. If the dryer is hard-wired, it is possibly improperly wired. These kinds of repairs are dangerous for a novice, so contact an electrician or repair center.
Read more : http://www.ehow.com/list_7103891_samsung-dryer-error-codes.html
Dec 31, 2014 | Samsung Dryers
Samsung washing machine
Based on my experience, the same thing happens to me as you have mentioned that it happens every end of a cycle. I doubt if it was a fan error or a frequency error. for me, its just a simple overload for the autodrying. for example on my model. the manual says autodrying cotton-cupboard dry must be max 3 kg. since you cannot measure your wet clothes and it sometimes exceed the 3kg autodrying, that is when the FE comes out. but when i remove some clothes or spin the laundry again and put it into drying, everything works fine. when i use the machine with minimal clothes say 2kg dry, the whole cycle up to drying work fine without FE errors.
So i believe its just an error for drying overload. also the manual says nothing about FE nor Error code for drying overload.
Hope this help.
May 31, 2012 | Washing Machines
What cause FE error on a samsung dryer
We did some extensive research and somehow found a service manual for our Samsung unit online. According to its section 4-1 "Error Items and Diagnostic Codes" the following is the problem:
(code) FE - (description) Power source frequency error - (Trigger) Invalid power source frequency - (Action taken) Check for: (a) Not using regular power source frequency (b) Invalid power frequency sense circuit.
In other words, either the thing you have plugged your machine into is faulty, the electricity itself is of poor quality where you live, or the sensor within the unit is faulty and giving an erroneous error code.
In our case, we had our machine hooked up to a cheap surge protector; which we thought might be the likely source of our problem in the light of the error code description above. So I tried connecting it to a commercial extension cord (I still got an FE code). So I tried moving the extension cord to another room's circuit, thinking maybe it was localized in the laundry room (I still got an FE code).
So, I am guessing we either have a bad "power frequency sensor" or the problem is due to the terrible electricity we have where we live (i.e. that the power frequency fluctuates too much due to our local power company's poor system).
Regardless, I hope this answer helps somebody with the "FE code" problem, now that you know what the code means.
Oct 26, 2009 | Samsung WF203ANW Front Load Washer
I have an error code "FE" apperaing in my samsung washer dryer, it appears in the spin cycle and is not in the manual. waht causes this error
We did some extensive research and somehow found a service manual for our unit online. According to its section 4-1 "Error Items and Diagnostic Codes" the following is the problem:
Oct 05, 2009 | Samsung WF203ANW Front Load Washer
Samsung WD-J1255 Front loader Washer/dryer combo
I have a similar problem with the FE Code. All i have manage to ascertain is that if you set the spin at 400 it will complete the cycle
Nov 01, 2008 | Washing Machines
Dryers Logo
14 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
