Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Solo's problem hello i asked about the solo's. if i do buy the 4ohm drop each to 2ohm then hook them both to the amp pos+pos and neg+neg straight to the amp will the two drop each other down to 1 ohm ?
    Problem Solver:
  • 7 Answers
Posted on May 21, 2009
How to wire a 12inch 4ohm dvc sub to 2ohm
Take two wires, equal length. Reach from positive of 1 coil and hook too positive of 2nd coil, now do the same with negative, neg to neg.. Then pos of sub to amp. And neg of sub too amp.
Jan 03, 2013 | Rockford Fosgate T1d212 12" Power T1 2-ohm...
I'm wanting to get the most power from my amp for the sub. Its a 2ohm dvc. If you say series or parallel I'll be confused. Need exact explanation. Thank you.
series is a straight line and parallel is is a big x. come into the connection pos and neg from there hook that to the pos and neg on one side of the dvc.on the speaker take the pos to the open neg and the neg to the open pos
Sep 12, 2010 | Car Audio & Video
I got 2 pcs of kicker 12L7, one is 2ohm and the other is 4ohm DVC. in there any chance i can run them together with one amplifier? i got a venom VD2600S and venom 1600.D, will it be ok if i use each...
Run the amp in stero Run the 2ohm to one chanel, Wire the dvc 4ohm to run 2ohm + to + - to - to the other chanel and you should be fine.
If you had a 1ohm stable amp you could run both speakers wired 2ohm to a mono amp and have a 1ohm set up and double the power!
Feb 04, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How to connect dual vouice coil to amp
Hey well your gonna need to give more info. is the sub dual 2ohm dual 4ohm. if you have a dual 2 ohm you wire one + to one- (like a jumper wire)and then your other +.- go to your amp as 4ohms, if you have a dual 4ohm model and your amp can handel 2ohm stereo then wire your +to+ to +on the amp and the same for your -. it will bring a 4ohms to 2 ohms by connecting pos. to pos. and neg.to neg. then to your amp.
Jan 18, 2010 | Kicker CVR12 Car Subwoofer
How do i wire it to a dvc woofer
if you hook pos to pos and neg to neg if each voice coil is 4ohm then your amp will see a 2ohm load
Dec 31, 2009 | Car Audio & Video
How do i bridge 2-4ohm dvc's to a mono block
If you have a DVC 4ohm speaker, and you are using both voice coils, the amp is seeing a 2ohm load.
If you bridge the amp, you CAN run both subs as long as the amp is Two Ohms Stable.
Wire each subs voice coils in parallel.(Positive to positve, neg to neg.) (2ohms) each.
Then wire the two subs in series.(Neg from amp to neg of sub one, pos of sub one to neg of sub two. then pos of sub two to pos of amp.
If it sounds too hard, leave it as you are already running the amp at two ohms.
Sep 13, 2009 | Car Audio & Video
Wiring options
Yor best bet is to wire each one positive to neg to get 8ohms then pos-pos and neg-neg to get 2.66 ohms. Otherwise series parallel. If you wire them all pos-pos and neg-neg you will be running .66ohms and will most certainly fry your amp or it will overheat and shut down all the time
Sep 07, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Bad sound while playing at low volume, tested both voice coils and they are both are around 4 ohm.
do you have it wired down to 0 ohm or 2ohm if u have a mono block amp wire it to where a pos. from one side goes to a neg on the other side and then use a pos an neg from diff sides coming from amp
Jul 30, 2009 | Kicker Solo-Baric L5 Car Subwoofer
CORRECT CONNECTION TO AMP BEING A FOUR TERMINAL SPEAKER
Hello i_starling,
The Kicker L7's come in either 2ohm or 4ohm dual voice coil (DVC) versions.
Whatever amp they are connected to, you need to know both the impedance of your L7's and the impedance of your amp. The L7's dual voice coils can be wired to provide a total of four different loads:
2ohm coils in parallel = 1ohm load
2ohm coils in series = 4ohm load
4ohm coils in parallel = 2ohm load
4ohm coils in series = 8ohm load
Your best connection would be the one that results in a final impedance load that is supported by the amp.
Hope this helps.
May 01, 2009 | Car Audio & Video
Can i kook up 4ohm dvc sub to a kac-x810d amp?
No, the sub is dual 4ohms...meaning if you parallel the positive speaker terminals and the negative speaker terminals you will have a 2ohm sub. Conversely, if you series the pos and neg you will have an 8ohm sub. if you wirte to just one set of terminals on the sub you will have a 4ohm sub.
Apr 12, 2009 | Kenwood KAC-8101D Car Audio Amplifier
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
74 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
