Question about Jensen VM9314 Car Video Player
Screen went black and won't show nothing on the screen
Jensen vm9314 car video player... i was opening the screen and finger bumped the screen and when it came all the way open the screen went black and it wont show nothing unless you close the screen and open it again it will show for a second then go back black
SOURCE: Jensen VM9410 problem
two things might be wrong is there 12 volts and is there a good ground . hope this might help.
Posted on Jan 07, 2006
backinblack
  • 11 Answers
SOURCE: monitor wont come out
I have the exact same problem on mine. If yours is like mine, It clicks a little when it tries to open and close. If that is the case, The gears that open the dvd player might be stripped or just need to be adjusted.
Posted on Feb 22, 2008
  • 54 Answers
SOURCE: Jensen VM9311ts. Touch screen starts to open and then goes back
There is a tiny micro switch on the screen tray inside the radio that is bad best to take it to repair shop as switch is small and hard to locate if not familiar with circuit boards.
Posted on Oct 23, 2009
SOURCE: it just shows a blue screen and says no video on jensen uv10
yes
Posted on Feb 28, 2010
SOURCE: Jensen vm9412 screen is blank
Black screen
Posted on May 17, 2011
Jensen vm9314 unlock code
If you still have the remote, you can try the basics, First try 012345 sometimes thats all it takes I know on my 9312 that will overide the rest of the radio and allow me into the sub menu to fiddle with the radio. if that dosent work then enter 00000, 11111, 99998, 55555 or something along those lines most default codes are as simple as that. if that dosen't work, you will need to contact the installer and see if they had put in an anti theft code, and find out if trhey keep records of it
Nov 23, 2011 | Jensen VM9314 Car Video Player
Jensen VM9314 remote does not work...not the battery
Your remote may be faulty.
I would either take it to an autozone and check it is working there ( they have an infrared remote check on their keyless remote battery center that will show the IR signal being sent).
OR
you can point it at almost any of the security cameras in production and view the 'IR flashlight' on the video screen/ monitor.
If the remote is in fact not producing a light , I will assume the unit needs replacement batterys or remote.
Alternately , you can disassemble the remote and check the IR emitter with an Ohm/Volt meter.
should the signal be present on the meter and yet no 'light' is being emitted , then replace the emitter with a new one (avail. at radio shack...)
If the remote does emit a signal , chances are the reciever is bad.
My Jensen came with two remotes... did you try the other one ?
Oct 04, 2011 | Jensen VM9510 Car DVD Player
Jensen 9314 lcd repair. Can this be done. the screen got damaged the outer screen is ok but it looks like it shattered internally, a very small part of the screen shows
It can probably be repaired, but you will more than likely have to send it to Audiovox to get it repaired. Audiovox owns Jensen. You can get a hold of them at audiovox.com.
Aug 15, 2011 | Jensen VM9314 Car Video Player
Jensen vm9314, how do you bypass the parking break safety feature to watch videos any time?
Try connecting the PINK wire of your head unit to a ground/chassis of your car. That should solve your problem. happy viewing but drive safely. dreamsystems
Feb 15, 2011 | Audiovox Jensen Vm9314 Dvd Video Bypass...
Jensen MVB85 A8.5 dvd player
Problem: All DVDs would not play in Jensen MVB85A overhead 8.5 DVD player. Error code: "Incorrect Region Code"
FIX:
1. Use the remote to power on DVD player
2. Ensure there are NO DVDs in the drive
3. When you see the DVD logo screen, press 9653 on the remote
4. A hidden menu will open stating the region code. My region code was set to 0 and my I was receiving the error.
5. Press the "OK" button to change the Region Code to "1".
Once the region code was set to 1 all DVDs were playing.
Key words: Jensen Audiovox MVB85 incorrect region code
Nov 13, 2007 | Jensen 8.5'' Overhead DVD Player Package...
No video, only sound from tv tuner.
You need to plug the male yellow wire into one of the female wires that says media control...... something along those lines..... youll figure it out
Oct 06, 2006 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jan 03, 2006 | Jensen VM9410 Car DVD Player
Jensen VM9314 Car Video Player Logo
57 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
