Question about Janome Sewing Machines
Feed dog won't raise janome
Mc10000
SOURCE: Janome 9000 Feed Dog and On/Off button problems
Manual sliding is not working for me. But I can unscrew the plate and lift the feed dogs with the screwdriver and it seems to run okay (until they drop again - then I still have to lift with the screwdriver
Posted on Aug 26, 2007
mallow1
  • 35 Answers
SOURCE: raising feed dogs
I've always been able to get a free PDF downloadable manual from Janome. They are happy to send you a manual for your specific machine via email, and they've always been very helpful to me. Here's a link to them:
http://www.janome.com/index.cfm/ContactUs/Machine_Support
Hope this helps!
Posted on Aug 16, 2008
SewTechWayne
  • 186 Answers
SOURCE: Raising and Lowering the feed dog on Janome 4900 MC
These machines are known to have this problem. The feed lift cam has a groove worn in it that won't allow the feed dogs to come back up. It is on the lower shaft and needs to be replaced. You can get the feed dogs back up by taking off the needle plate and lifting them up manually while turning the hand wheel. They should stay up until you drop them again.
Some people will not replace the cam and live with it.
good luck!
Posted on Feb 08, 2009
SOURCE: feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Posted on May 01, 2009
  • 6 Answers
SOURCE: Feed Dogs on Janome 1600P
I recently purchased a Janome 1600P-DB and in order to do free motion quilting I had to cover the feed dogs with an index card. I also cut a small section out of the card to allow for the thread and needle to move freely. Standard tape was used.
Posted on Oct 21, 2009
Janome 3050 feed dogs wont come back up
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
  • Shift the drop-feed lever to the right to lower the feed dog.
  • Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
JANOME DC 3050 User Manual Page 9
May 24, 2015 | Janome Sewing Machines
How do I get my feed dog to move forward on Janome model6019
THE FEED DOG IS IN THE DOWN POSITION FOR DOING FREE ARM SEWING. SLIDE THE PARTS BOX OFF. THERE IS A SMALL SWITCH THAT YOU NEED TO SLIDE TO THE ON POSITION.
Dec 24, 2014 | Janome Sewing Machines
Janome/New HomeHF 2022 How do I raise and lower feed dogs
With the straight stitch set to zero the feed dogs should be down. To use a different number will make the feed dogs rise above the plate.
Oct 23, 2014 | Sewing Machines
Janome memory craft 10001 feed dogs are not high enough how do you raise them?
in the manual it should show where the lever is to raise the feed dogs
here is a link for a manual if you do not have one
http://www.sewingpartsonline.com/janome-mc10001-manual.aspx
Jun 12, 2013 | Sewing Machines
Feed dogs won't raise and lower on my memory craft 9500, how can I fix this problem?
when your machine on your machine movable arm pushing a switch liver which will raise your feed dogs you can do one thing when your arm moves to the normal possision just given your finger to the upside movable are you see one long switch bar is there just push and see machine feed dogs will come out actualy that action to be done by arm only,you call one MC expart to resoved your problem permenetly.
Apr 21, 2012 | Janome Memory Craft 9500 Computerized...
My feed dods have droped down how can we ajust them to raise them.
Usually when you slide the knob to drop the feed dogs they drop immediately. But when you switch the knob back to raise the feed dogs, they won't come up until you rotate the handwheel one revolution in the forward direction.
Apr 25, 2011 | Janome Memory Craft 9000 Computerized...
Feed Dogs won't come back up!
Have you tried sewing with the machine after setting feed dogs to up position. You may already realise but it takes a full revolution of the machine to engage and raise the feed dogs after setting the feed lift control to up (the feed dods will drop as soon as you adjust the feed lift control but will not raise until a full revolution of the stitching mechanism).
If you have already tried this unsuccessfully try removing the cover below the feed dogs and spray lubricant on the feed linkages and try freeing them.
Nov 04, 2009 | Janome Sewing Machines
Frabic won,t feed
have you checked that the feed dogs are raised? mine has a switch at the back -
May 13, 2009 | Janome 6019QC Mechanical Sewing Machine
good luck!
Feb 08, 2009 | Janome Memory Craft 4800QD
Sewing Machines Logo
27 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
