Flickering tv It has been flickering for several months when first turn on didn't last maybe a minute but now it's been flickering for 3 hrs is this a sigh nits going out
  • 1153 Answers
SOURCE: Picture flicker
You can get info at ctechnicians.com
Posted on Dec 22, 2007
  • 14 Answers
SOURCE: Tv flickers when first turned on
I have encountered this exact same problem with 2 Maxent MX-42X3 Plasma TV's. I found that C766, a 220uF, 16V surface-mount electrolytic capacitor on the main board is bad. This capacitor is located just to the left of the green multi-fin processor heat sink. This capacitor will test good using capacitor meter or an ESR meter, but if you spray it with Freeze-It with the power on, you will find out that this is the problem! To get it out, I found I had to remove the little 10uF 16V surface-mount capacitor just to the left of it. I then replaced these 2 capacitors with regular (radial), high-temperature, low-ESR capacitors. I cut the leads short, and bent the ends out just a little bit so you can solder them back onto the surface-mount pads. You can get these parts from Digi-Key Corp. I used Digi-Key part # P12383-ND ($0.32) for the 220uF capacitor, and P11212-ND ($0.30) for the 10uF capacitor. Both of these capacitors are rated for 25V and high temperature, so they won't go bad again. You can purchase surface mount capacitors there too, but I find them very difficult to solder back into those locations due to the tight placement of other capacitors in that area. Be careful, and good luck!
Posted on Nov 16, 2009
budmrtn
  • 11361 Answers
SOURCE: We bought this tv Dec 2007 and last month it
Look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find
Posted on Dec 09, 2009
SOURCE: I have a brand new Viera tv and after 4 hrs the
I have the same proble. Did you find a fix?
Posted on Sep 13, 2010
  • 1623 Answers
SOURCE: Currently the TV will not
i suspect it is capacitors on the power board that are failing on it. I am not familiar with this particular model. But i would say that is what it is, you can usually tell which ones are bad because they will be bulging at the top
good capacitors look like this below
Posted on Mar 10, 2011
Testimonial: "Thank you very much for the info. I really hope it is only a capacitor issue! Thanks again, Shad"
Vertical lines showing up after being on for awhile
Eh, I can't be too sure, but it sounds like it's either a heat issue, a signal issue, or a backlight issue. Either way, if it's still under warranty I'd send it in.
May 06, 2013 | Sharp LC60LE835U AQUOS Quattron 60" 3D...
Cannot set time @ date for Ohsen watch...AD0721...thanks
(A=LIGHT,B=MODE,C=START,D=RESET)
1.How to use the luminescence Any time indication,Press A the Luminescence will last for 3 seconds.
2.How to view date? Standar time indication, press C "month/ date" indication.
3.How to switch 12/24 hour systems In the normal mode, press B twice and press D twice ,then hold C until 24 hour system is actuated, then press B for recovering.
4.How to check alarm ring and alarm time? Standard time indication,press D alarm time indication.
5.How to set alarm time? Standard time indication,Press B twice. The hour area flickers,press C to set the hour. After setting hour ,press D,the minute area flickers, press C to set the minute. Last press B for recovering.
6.How to set alarm ring? In standard time indication mode ,Hold D then Press C this will toggle alarm symbol on & Off.
7.How to set Hourly Chime? In standard time indicationmode, Hold D then Press B DAY OF WEEK area toggle on and off.
8.How to use stopwatch(1/100 seconds) Press B,then Oress C for 1 timing; Press D for multiple timings. Press D once more to continue operation after multiple timing. Press D for 1 timing; press C once and press Dtwice for multiple timing. (1)Max range of the stopwatch is 23 hours 59 minutes 59 seconds. (2)When timing within 30 minutes, the watch indicates: minute/second/1/100 second (3)When timing beyond 30 minutes, the watch indicates:hour/minute/second
9.How to adjust time, date,day of week (1)Standard time indication,press B twice ,the second area flickers, pressC to adjust second. (2)Then press D the Minute area flickers,Press C to adjust minute. (3)Press D the hour flickers, press C to adjust hour. (4)Press D the Date flickers, press C to adjust date. (5)Press D the month area flickers, press C for adjustment. (6)Press D the Day of Week area flickers, press C for adjustment. Then press B for recovering.
Nov 30, 2010 | Watches
Samsung HLR5067W: Screen goes black - Audio Remains. Several months back my 5 years old HLR5067W started displaying the following behavior: - Launches OK - After running for a while (anywhere between...
When was last time you replaced Lamp? Ballast Board is what powers the lamp on.
Lamp Fan, if it is defective it will shut lamp off to protect it, if it is Not cooling the Lamp.
Mats has Lamps for $99.00 1-800-628-1118
Encompass Parts Distribution has 10 Ballast Boards in Stock for $68.96 they also list Service Manual Free for this Model# 1-800-638-3328
Nov 03, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HL-S5086W Television. 3 yr old. Never serviced. Last evening the TV started turning off by itself. It would turn back on easily and run for a few minutes. I unplugged a new Wii game that was...
Dont worry, the problem is coincidental to you installing the Wii. You need a new lamp.
What you are seeing is the lamp ballast/power supply attempting to start and restart your lamp. The resistance of your lamp to it's power source has increased to the point that it is shutting down, but has not blown out yet. You can find these at justlamps.com
Good luck
Jan 04, 2010 | Samsung HL-S5086W 50" HDTV
Problems transferring entire VHS tape contents
Just continue what your doing in previous just save the remaining minutes maybe the limits was approaches.
May 18, 2009 | Diamond Multimedia ( VC500) Video Capture
Screen is fine when I first turn on TV, then goes black
Sounds like you dlp lamp is going out. That's a pretty old TV and if you are still running on the stock lamp this is exactly the type of thing that will happen. The lamp model for this particular tv is the ty-la1001. You can find that over here:
http://dlplamps.com/products/panasonic-dlp-lamp/panasonic-ty-la1001.html
Mar 21, 2009 | Panasonic PT-52LCX66 Projection Television
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Samsung DLP HL-R-5667W lamp LED comes on solid, no picture, then turns off
DO you have the owners mannel if so read it and see what they would do ,have you removed the lamp and if so how did it look? some lamps only last for 5,000 hrs and others 8,000 hrs If lamp is bad TV will not come on.
Feb 20, 2008 | Samsung DLP HL-P5663W 56" TV
Picture flicker
Dec 22, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
