Question about Microsoft Digital Image Suite 10
I have the pip files on another drive how can I access them from my win7 laptop
Am 81. Not computer savvy. Do e-mails and genealogy. Had XP, but now Windows 7. What laptop is best for an older, limited user. Have genealogy saved on 3.1 inch disks and FamilyTreeMaker progra
If you have Win7 Ultimate and access to an external floppy drive, it is possible, with some reconfiguration, to run Win7 Ultimate in XP mode. You need to employ the assistance of a computer savvy tech. It is not the easiest thing to set up and will not work on any other Win7 OS.
Jan 24, 2015 | Computers & Internet
I need to boot Win7 by USB flash Drive created by a 2.5"FF SATA drive.
If you can tell your BIOS to use USB as the first boot device and the USB is from an ISO of Win7, it should work but your laptop won't be happy as the drivers may be wrong.
Dec 07, 2014 | Computers & Internet
5508859r windows7
You do not have the best version of Win7... you have the cheap one. If you had the fancy Win7 version of even any version of WinXP you could see your files, if the HDD is good. Ask a friend for assistance and plug the USB adapter into another PC. (I have my diagnostics PC with WinXP to avoid the issue.)
Jun 27, 2014 | Gateway 5508859r - Hd 160gb Ata Ide
How to Install ssd on G75
* Connect the SSD
* Put the Win7 disk in dvd drive
* Restart
* Boot from Win7 disk
* Install to SSD
* Copy files from HDD to SSD
* Profit
God bless you
May 25, 2013 | Computers & Internet
Can i knw whether windows 7 os can be installed in XNOTE RD 400 laptop
Well, if you have a CD-ROM or a DVD-ROM drive, You can insert a Windows 7 installation disk and install it. If not, you can insert the disk in another computer and copy all files in a pen-drive. <You have to right click on the disc folder and select explore to do so.> Then, insert the pen-drive into your laptop and double click the setup file to install Win7 on your laptop!!
Jun 27, 2012 | Computers & Internet
BOOTMGR is missing
This may be due to the reason that your Compaq model is only Vista or Win7 Compatible.I didn't get your question properly but as you're having no windows or DOS in your machine.All you need is a Bootable Windows Disc and a working DVD rom to get this done.Cause commands or anything else will require that and even if you fix it with some tricks. Some Other file missing message may appear. But if you just want to push yourself. Normally are Booting files are in the root folder in my case it's in C:\ like NTLDR BOOT.ini BootSect.dos so try to access your root drive.
Dec 30, 2011 | HP Compaq nc6220 Notebook
I upgrade my laptop from xp to windows 7 and didnt find G drive not able to access g drive
First of all make sure the g drive isn't a removable drive(such as a gig stick or external drive). Next, the file system on the g drive may not be compatible with the win7 version that you have(either 32 or 64 bit version). If it is an external drive you may need to go to the manufacturers website to download the latest driver for your particular version of windows
Apr 27, 2011 | Computers & Internet
Cant reset to factory out the box i try the 0 key it freeze on black screen with cursor. i recently install a windows7 professional and cant access internet and all the software including toshiba software...
Is still there Win7 working with your laptop ? As i can get you that you have reinstalled your Laptop with Win7 and you cant access your old software and setting from the original as it was shipped to you am i right ? And you want it back to reset to the old setting ? For that you can use the CD/DVD you might have got with your laptop ?
Apr 14, 2011 | Toshiba Satellite Laptop / AMD Turion II...
Two toshiba laptops, one less than a year old running win7...the other 3 yrs old runnign xp. both worked fine connecting wireless to my router sat. sun the win7 machine said the dns server was not...
Did you press a button (or move a slider-switch) on the WIN7 laptop, to "disable" the wireless adapter?
Can you login to the web-server "inside" the wireless router, and look at the "log-files" that the router keeps of "recent" events (such as connection-attempts from wireless devices), to see if there is any useful information in those logs?
Does the WIN7 laptop connect to _any_ wireless network (Starbucks, university, shopping mall), or does it fail ONLY when connecting to your wireless router?
Have you tried a "factory-reset" on your router, just in case that it might be the problem?
Feb 21, 2011 | Toshiba (PA3212U) Wireless Adapter
Instaling windows 7 in vaio laptop have vista orginal windows how solving the problem in instaling windows 7?
if your system came with vista originally the issue would be is you would need to know what version of vista you have on your system, the version makes the difference if you have vista home premium then your windows 7 should be a win7 Home premium as well, because if you are upgrading vista using your win7 disc and your windows version are different for example you have vista Home premium and your win7 is win7 ultimate and you do an upgrade the problem will be your product key,
but if you have a retail version of win7 and you are installing it on your laptop Vaio insert the disc in the DVD-drive win7 needs a DVD reader to be able to install win7 if you have a cd-rom it wont work, then turn the laptop off power it back up keep on tapping f12 it should bring you a boot menu, select ODD or which ever is your dvd drive then press enter then enter again if it says on the screen press any key to boot to CD, this should begin win7 installation on the screen saying windows is loading files the so on ans so fort ^_^ this will over write everything in vista but in win7 it will still create a windows.old folder from vista only from the my documents folder my picture and my music and my video and desktop Items but remember application icons will not work on win7 you may need to reinstall the program again for it to work on win7 and yeah make sure that you choose custom/advance in the selection screen do no select upgrade unless you vista and win7 are the same version eg. Vista Home premium / Win7 Home premium ^_^
Jun 03, 2010 | Sony VAIO VGN-FW390JFB Notebook
Microsoft Digital Image Suite 10 Logo
12 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
