Question about Sony Playstation 3 (PS3) Console
PLAYSTATION 3 CAN I USE PLAYSTATION 3 W/OUT HARD DISK. 80 GB
  • DWDpcRepair May 11, 2010
    i dont think so. most games install game data then you have the game save data as well. if the game doesnt do either of those you might be able to play it. i've never tested it personally.
    Scholar:
  • 145 Answers
No. The hard disk is necessary for game saves and system data. It uses a "notebook" style hard drive that you can purchase at computer supply stores. Check www.playstation.com for details on which type you should get if you need one.
Posted on Jul 25, 2009
No you need a hard disk to run the ps3.
If you dont have one then look down at your local computer store for a 2.5 inch sata laptop HDD.
If you get it take the ps3, and on the bottom (if its standing up and you can read the PLAYSTATION 3 writing) there is a small panel that should say HDD on it or it could just have some random writing.
With a small screwdriver remove that plate by sticking the screwdriver under it from the right handside and slide the panel out to the right.
Undo the blue screw and ping up the little handle.
Slide the whole drive carrier to the right and carefully remove it there should be four screws either on the little metal tray that comes out or on the hdd you bought. slide in the new HDD and tighten all four screws (one in each corner) and slide the drive back in, push it to the left and redo the small blue screw.
Click the panel back on and turn the playstation on.
It should ask you to format the drive, accept it and that should be it.
I know its long but i hope it helps.
Posted on Jul 18, 2009
    Problem Solver:
  • 16 Answers
No because the HDD holds the OS (Operating System) that gives you your main menu, plus most ps3 games needs HDD space to install a partition of itself onto the HDD.
Posted on Aug 11, 2009
    Problem Solver:
  • 12 Answers
No. It needs a hd to operate.
Posted on Aug 05, 2009
  • slinemaster Aug 05, 2009
    Problem Solver:
  • 9 Answers
Yes but nothing will save and you will get a bunch of pop ups when the games try to save things on your hard drive
Posted on Jun 19, 2009
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Sr, i cant fine my driver in my sony vio vgn cr-353 my web cam is not working! wer can i get my driover. thnx
Bro i recommend Maxtor DiamondMax Plus 9 80 GB (6Y080M0)
Hard Disk specifications:
1.0. SATA cable hard disk.
1.1. include 80 GB model for test series.
2. includes 8MB of cache.
3. with fluid dynamic bearings it mean that it will runs nice and quiet and can do fast transfer of informations.
May 28, 2010 | Computers & Internet
My hdd is not working. which hdd model can i buy instead of mhv2080at?
May 28, 2010 | Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB...
Drivers
hi..there...maybe you mean the update firmware for your hard disk... but i think only the expart can update the firmware of hard disk 'cause it high risk and can make your hard disk doesn't work anymore.
so same like other if your hard disk works normally it doesn't any driver at all even you us XP or Vista operating system....
Feb 02, 2009 | Toshiba (HDD2D15) 80 GB Hard Drive
Slow speed+hard disk
problem not clear enough
Please Don't Forget To Rate "FIXYA" Me For The Help
Dec 21, 2008 | Intel D102GGC2 Motherboard
My hard disk goes hang when it boots the bios and cannot detect it. but my hard disk is still running.
I have a similar problem with an 80 gb drive in a Compaq. I've isolated it to the cable or the connector on either the motherboard or the drive. Try unplugging the cable at each end, then plugging it back in. Reboot. If it finds it and works normally, you have 1) a bad hard drive cable 2) a bad hard drive controller socket on the MB (bad MB :-( ) or 3) an intermittent connector on the hard drive. 1 is easy. 2 and 3 are problems. Try a different drive and see if it boots reliably every time - if so, suspect the drive. If its the MB, probably time to UPGRADE.
Dec 04, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Hard disk drive
If you using WinXP, right click on My Computer>
>Manage> Disk Management>Drives
Active another 80 GB Disk space
Nov 27, 2008 | Computers & Internet
Samsung 80 gb Hard Disk Un allocated
All ways best to used new cables (sata/Ide) I like to set jumpers on the HD's never cable select. Also try installing one harddrive at a time. Second make sure in bios is set to boot from main HD.
May 12, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
I have a ps3 with an 80 Gb, hard drive. I am having Trouble recording to the Hard Drive.
Are you refering to the HDD (hard drive) or a removable disk like a flash drive or SD card?
Jan 13, 2008 | Sony Playstation 3 (PS3) Console
Hard Disk formatting Problem
Get the hard drive replaced. It was probably damaged during shipping.
Aug 26, 2007 | Samsung (SP0822N) 80 GB Hard Drive
Sony Playstation 3 (PS3) Console Logo
105 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
