Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
Pc entering power saver mde
My HP Pavilion f1503 has windows 2000 installed. It has run great for several years now. Today when switched on the screen showed the message pc entering power saver mode and then the screen switched off. Switched it on again and again and same thing, same message then screen switched off. Powered PC off and on - still the same meassage. How to fix this?
  • Patrick Kam May 11, 2010
    Check Screen Saver/Power settings. Change it to not "turn off monitor".
  • 192 Answers
This message apears when there is no input coming from your computer. There should be a bution you can puch on the monater that would cnahge it from digatail to analog this may be the problem that you are having problems with
Posted on May 21, 2009
What could be wrong with HP Pavilion f1503 screen?
This is usually faulty capacitors. They are in charge of regulating the power of your monitor, with time, they will go bad. The replacements of this capacitors is usually under $10 or $15 usd.
You will need to open the screen, identify, unsolder and buy the new ones to later on solder back and BOILA!
Aug 19, 2014 | HP Pavilion F1503 15" LCD Flat Panel...
Hp laptop has blinking red square above touch pad, comp. won't allow for reboot or restoring to factory conditions
If you do an illegal shut down which is power off by holding down the power switch for 8 seconds. The HP computer will then boot with the scandisk program, which will restore your hdd to perfection. Windows XP or later now use 'system restore' to rearrange registry from a previous calender date that the computer used to work perfectly.
Feb 09, 2012 | HP Pavilion dv2911us PC Notebook
I moved and I have not use my computer for almost 3 yrs. The computer turns fine, its being updated, but the monitor screen its bright at first and go into dark. How I can fix it? Can it be the power...
are you sure it is not something to do with the computer? perhaps some sort of screen saver?
secondly, there are "power saving modes" on the screen and on the computer, they could darken the screen to save power.
check to make sure these are not enabled.
Mar 28, 2011 | HP Pavilion F1503 15" LCD Flat Panel...
When I turn on the monitor, I get an error message: "Warning PC entering power saving mode", then it turns off.
Unplug your dekstop from the electricity then press and hold the power button on your desktop for couple minutes with out no power cable attached to it then let go of the power button then connect your desktop back to electrical outlet and press power button once that should give you display once it turns back on you can go into your power saving options and turn off power saver mode as its conflicting with your LCD sometimes this can occur if you have Norton antivirus installed
if after doing the power drain and still get same message then you can try using a different monitor if you have one for a test.
this issue is not with your monitor but with the PC has been stuck in sleep mode but the power drain should solve your problem.
Mar 01, 2011 | HP Pavilion F1503 15" LCD Flat Panel...
My Monitor enters power saver mode
install the driver for that monitor on the laptop
Jun 21, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
Screen goes black after booting up
amprich63, You should try to evaluate the state of the "switch-mode-power-supply" in the F1503 unit. Reconnect it to a FULLY booted KNOWN GOOD PC that is currently displaying the WIN-desktop screen! Then and only then push the "ON" button for the F1503. Did you see the desktop window?? if only for 1 second? What did you see next? Did you see a BLACK and BLANK screen? or Maybe just a BLACK screen? Do another post to this and tell me EXACTLY what you see or don't see when you shine a bright torch 2-3cm from lcd panel!!! I think you may have a BACKLIGHTING or POWER SUPPLY problem. I'm12fixlouie on fixya. if this was of some help rate this on fixya
Nov 02, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor warning pc enter power saving mode
Are you using usb keyboard and muse. if so your usb ports are dead
Jun 16, 2009 | HP Pavilion a450n PC Desktop
Power cord
the HP part number for the US power cord is
8121-0740the part number for the US power adapter is
5189-2852
Aug 07, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 1503 15in Flat. screen blanks out constantly
THis is a problem of the invertor board.If you are technically able you need to disasseble the monitor and resolder components around the red or yellow inverter transformers.
Samir
Mar 04, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
225 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
