Question about Broderbund American Greetings Creatacard Platinum 8 for PC
Print Aignment out
I have Create Card Platinum4recentley purchased H>P> Photosmart Printer which seems to of thrown my print alignment out for Cards and Envelopes. Went to Print Aignment printed test page than adjusted settings as instructed printed again worse. Have tried this many times does not work out right. Can you help Please Pearl
    Scholar:
  • 65 Answers
Have you tried to re-install the photosmart printer? You may want to go to hp.com and see if there is a patch that you can download for your software Or try going to the broderbund site and see if they have a patch there thet you can download Hope this helps :)
Posted on May 22, 2009
Hp photosmart won't print in color
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Sep 10, 2012 | Cisco Photosmart C4780 Wireless AllInOne...
H P Photo smart C4280 Will not print color/; Prt cartridge just replaced
After replacing the cartridges, printer performs align print are you check this page? any color print in that? If you found colors in align page, no problem with printer.> check print command in color or not.. > If no color print in align page, perform clean cartridges > check with another cartridge.> check trailing cable,carriage PCB & Formatter..
Dec 06, 2011 | HP Photosmart C4280 All-in-One InkJet...
Printer has ink but wont print in color test page wont print in color, also aligned printer and it worked in color. cleaned printer head as well which printed all the colors. what else can i do? It seems...
Take color copy, test all colors are OK..Go to printer properties, printing preferences, finishing check is there any check mark on print in black cartridge only? mark on print color..apply..OK.. give print command..
Go to paint draw a color drawing, print it.> check colors if its not printing in color it might be drivers issue.. un install the drivers re install once again check..> if printed in color check the file which you are printed..take another file.. then test..
Oct 29, 2011 | HP Photosmart C6180 All-In-One InkJet...
My printer tells me that I have no ink in it. I have the six different inks required, and they are all originals or HP compatible. the printer is HP Photosmart C5180 All-in-one
Good day.
There are a few possible cause why you are encountering this issue. One of them is that the ink cartridge orange cap on the nozzle of the ink cartridge are not yet removed. Here are a few troubleshooting you could do.
Try to print a print status report, press Setup Menu softhardware_0.jpg >Tools > Print Test Page or Print Printer Status report and check the print outs. If it still the same message try aligning the print head.
Align Printhead: Setup Menu>Tools>Align Printhead You should get a message on the front panel Aligning Printhead After this step, turn off the printer and power it on after 30 seconds.
If it's still the same issue, you have to manually reseat the ink cartridge and check if the orange caps on the ink cartridges are removed. Make sure that they are securely in place, you should be able to hear a snapping sound once they are seated properly.
Try to align the print head again from the Tools Menu on the printer's front panel.
Tip: If the print out is fine and you are able to print without any issues, the front panel message you are getting is a false front panel error.
Jun 25, 2011 | HP Photosmart C5180 All-In-One InkJet...
HP photosmart C 3180 red light comes on, it scan, but not print
Hi! Have you tried to test print your device? You can do that by pressing the print button on the device if it would test print. You may also check the device manager (click Start > right click My Computer > Properties > hardware > device manager) if the HP printer driver is installed properly.. if not, then contct HP for further help. You may also remove and reinstall the toner (use manual for the instructions) so that the alignment in printing would be fine,,,
Sep 06, 2010 | HP Photosmart C3180 All-In-One InkJet...
Photosmart d5160 keeps printing a test page after i print anything
Please perform the following steps:
* Make sure the CD/DVD tray is closed.
* Double-click the HP Solution Center icon.
* In the HP Solution Center (for Windows OS, if you are using Mac please let me know), click the tab for the HP Photosmart 5100 series.
* Click the Settings button.
* Point to Print Settings.
* Highlight and click Printer Toolbox.
* After the Printer Toolbox opens, click the Align print cartridges button.
* Follow the on-screen prompts to align the cartridges and print an alignment page.
:) Dr Tony
Apr 17, 2010 | HP Photosmart D5160 InkJet Printer
The printer is not printing all letters clearly. I want to clean the printing heads to see if this will help.
To clean the print head from the control panel
1.
Load letter, A4, or legal unused plain white paper into the input tray.
2. Touch Setup on the display.
3. Touch Tools.
4. Touch Clean Print Head.
The HP Photosmart cleans the print head and prints a page that you can recycle or
discard.
To clean the print head from the HP Photosmart Software
1.
2. In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Services tab, and then click
Service this device.
The Printer Toolbox appears.
3. Click the Device Services tab.
4. Click Clean the Print Head.
5. Follow the prompts until you are satisfied with the quality of the output, and then click
Done.
If print quality still seems poor after you clean the print head, try aligning the printer.
If print quality problems persist after cleaning and aligning, contact HP support.
Mar 18, 2010 | HP Photosmart D7460 Printer
Printer will not print or make copies. Our alignment page got accidently thrown away. Can we align the printer without it? Can we get a new alignment page?
alignment page is done during the installation of new ink cartridges. you could re align the printer.
press setup > tools - ok > align cartridges - ok and then scan the aligned print out
Oct 31, 2009 | HP OfficeJet J4580 All-In-One Laser...
How do I realign my hp photosmart c4480 printer?
To align the print cartridges from the HP Photosmart Software
1. Load letter or A4 unused plain white paper into the input tray.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
2. In the HP Solution Center, click Settings.
3. In the Print Settings area, click Printer Toolbox.
box. In the Print Properties dialog box, click the Features tab, and then click
Printer Services.
box. In the Print Properties dialog box, click the Features tab, and then click the
Printer Services button.
4. Click the Device Services tab.
5. Click Align the Print Cartridges.
When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
press the button next to OK.
The product prints a print cartridge alignment sheet.
7. Load the page print side down on the right front corner of the glass, and then press
the button next to OK to scan the page.
When the On button stops flashing, the alignment is complete and the page can be
removed. Recycle or discard the page.
Jul 18, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Always starts up and does an alignment page.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
    after the alignment page prints then place the alignment sheet on the scanner glass and press the ok button
Jul 10, 2009 | HP Photosmart C5180 All-In-One InkJet...
Broderbund American Greetings Creatacard Platinum 8 for PC Logo
99 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
