Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman runs but will not move?/?
Was mowing and suddenly the mower came to a halt. I checked the gears and made sure nothing was in the way of anything and also the little hydrostatic ? bolt in the back. thought that might have popped out but not. Anyone have any suggestions? Really cannot afford a new mower right now..Thanks for any suggestions Emma
  • emmawilli0 May 22, 2009
    Do not know as have not had time since the answer from rjivaro, but will certainly check all those. I was pretty thorough the other day but could have missed something...I am pretty mechanical but this has me stumped. Will certainly check these out Friday...Thanks and it isn't easy being a widow..Trust me and thanks again..........emma
  • corcorankids May 22, 2009
    mower runs but will not go into gear. Doesl not move.
    Novelist:
  • 153 Answers
There is a long belt that connects to the pulley on the motor shaft (there are 2 belts there. The lower one is for the mower deck) and at the other end is connected to the pulley on the transmission. Is the belt in place? There is also a pulley on a spring loaded lever that keeps tension on your drive belt. If you move it away from the belt it should spin freely. Does it? If not, replace. If you lift both rear wheels off the ground at the same time, spinning one should cause the other to spin in the opposite direction. Both wheels should feel like they are controlled by the transmission and not just spinning freely. If not, check to see if the woodruff key on the axle that prevents the wheels from spinning freely has broken on one or both wheels. If all of this looks ok and the drive release bolt is positioned correctly, you very well might have a bad transmission.
Posted on May 21, 2009
How do I determine why the blades will not engage on my mower
With the mower turned off and the deck at its lowest setting, check the top of the deck for any debris like rocks or sticks. Then watch the top of the deck while you move the engage lever. If nothing is moving, you either need to adjust the cable, reattach the cable, or install a new cable. If you see the lever with the pulley on it moving, when the engage lever is locked on, check the tightness of the belt. If it's loose, that is your problem and it could be a stretched belt.
Sep 18, 2014 | Craftsman Garden
Won't move in any gear
did the belt let go?is it a auto trans and the lever on the rear is pulled out that allows you to push it?
May 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman riding mower that's 2 years old and it won't go into gear it's a 6 speed won't go in reverse either
Hi, did this happen when you went to use it or while mowing? Also will the lever go in but the mower won't move or won't the lever go in either gear at all? Regards Phil.
Aug 17, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
I have a 16hp Craftsman riding mower which I was using when it suddenly stopped. Now when I turn the key, nothing happens...it doesn't even click....Please Help ! Ray
Check the battery with a voltmeter to see if you have 12.5 volts....this voltage is critical for the solenoid and starter to operate properly...next...make sure you battery connections and the connections to the solenoid/starter are good and tight. Poor connections are a very common problem on mowing equipment...one thing you can try is to "jump " a 12 volt signal to the trigger lead on the solenoid...if this triggers the starter, then the keyswitch may be defective...also...before you go changing parts...make sure the fuse(s) is good...there should be a fuse from the keyswitch to the solenoid
Apr 25, 2011 | Craftsman Lawn Mower Ignition Switch Ayp ...
Mower stopped moving
If this is a manual transmission, check the drive belt from the engine back to the transmission. With the clutch pedal up (engaged) there should be no slack in the belt.
If it is a hydrostatic drive, check the drive belt and make sure it is tight. Check the transmission fluid level and make sure it is full. Refer to your owners manual as it will describe the fluid check proceedure.
Good luck, let me know.
Regards,
Jul 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Jun 06, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Suddenly stopped driving...
Check for a worn belt first.Then check the linkage. Next jack the unit up and try to run it forward and reverse with the engine running.If there is any movement at all in either direction then check the fluid level to see if it is up to the top.The worst case is the hydro. unit has a stuck check valve or something broken inside.Hope some of this helps. donnyb60
Mar 23, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
547 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
