Question about Toshiba Portege 2010 Notebook
Have a problem with my portege
I have toshiba portege 2010
when i open every program, i look in windows task manager the usage memory is 100% and make my laptop very slow,
can someone help me please??
  • 73 Answers
Which version of windows please? In 98 and ME your Hard drives are NOT set to use DMA.. In Xp the power management has toggled the cpu speed down..
These ar the 2 easiest solutions..
More info needed
Posted on Feb 16, 2008
I have a computer [AMD athlon(tm)]xp 1800+ 1.50 GHz]. My problem is when I switch on the system,the OS will open and i don't open any application then if i see in 'Task Manager - performance' there the...
Type "msconfig" on search bar there will be bar "startup apps" click that and click on disable all and restart your system...hope it works... Regards: imran
Sep 19, 2014 | Computers & Internet
Constant 100% CPU usage
you have to get safe mode if you have win xp /7 .also need to check malware and remove unwanted start up programs.
Apr 04, 2014 | Toshiba Tecra 9100 Laptops
High cpu useage
Open the Windows Task Manager - you should be able to right-click on the bottom task bar to do this or else, you can use Ctrl + Alt + Delete keys to invoke it too.
In the Task Manager window, select the Process page tab, then click on the CPU column header and sort the list of running processes by the amount of CPU being used - this should help you understand what is consuming high CPU on your computer.
Jan 03, 2012 | Compaq Computers & Internet
Slow running of window vista
There are many things that might cause your PC to run slowly or restart at time and then. It could be a fragmented disk; fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. Here is a few good virus scanners that you can run to check your PC:
http://c74b6qq6lbo8zlievtv2q810g1.hop.clickbank.net/?tid=DMWDH6W3
Nov 24, 2011 | HP Pavilion dv9000z Notebook
Acer aspire one D250-0BK keeps freezing
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. No anti-virus software is 100% perfect at catching everything. Here are a few good free online virus scanners that you can run to check your PC:
http://security.symantec.com/sscv6/home.asp?langid=ie&venid=sym&plfid= 23&pkj=RRJEDTKJBTVISBYWWYP
Nov 05, 2011 | Acer Aspire One PC Notebook
Pc hang while loading opening web or any aplication
check your start-up items & ms config, there's possibility, a lot of program running or check your RAM or go to TASK MANAGER, then go to PERFORMANCE TAB & check the memory usage & if it is eating up 90-100% of the memory, you need to add memory on your pc. Or worst scenario, you might have a virus in your computer.
May 12, 2011 | Computers & Internet
My computer is being hanging
Goto Strart and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'Sys config utility' window click on 'startup' tab then uncheck all the applications except your current antivirus and press apply then 'ok' and then 'exit without restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
goto 'Advanced' click on 'change' and increase your virtual memory to 2048 in both spaces.
now restart windows.
To quickly restart windows press CNTRL+ALt+DEL
inside task manager you will find all the open applications .
right click on each applicaion and click on end process tree then ok
Close all your apps like this and you will find your windows a lot faster and now you can reboot or turn off your windows as usual from start button.
There are many things that might cause your PC to run slowly. It could be a fragmented disk; fragmented registry; a virus, trojan, or spyware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, google the name and you should find what the process is for.
http://onecare.live.com/site/en-us/default.htm
http://www.eset.com/us/online-scanner
http://www.pandasecurity.com/homeusers/solutions/activescan/
If you feel that my answers has helped you in any way then please give a vote.
Thanks.
Apr 08, 2011 | Computers & Internet
My Toshiba satellite pro M10 very slow.
check your system performance thru task manager. check for CPU usage. usually COU usage is 1% to 10%. if your CPU usage would peak from 10% to 100% there is a huge possibility that there is program running on your computer that eats up your memory. Or it could be spyware/malware
Mar 27, 2010 | Toshiba Satellite Pro M10-S405 Notebook
Toshiba Satellite Pro L300 keeps locking up for no reason. After turning it on for awhile the mouse won't scroll anything or select anything and the only thing I can do is turn off the power and take the...
Open the "Task Manager" by (right ) click in the Statusbar, located in the same (level as the start button). Next see how many Processes are running? If the (number) of processes running are between 75-80, the Computer is running very slow, this could be a ("Low") Memory problem, you can check the "memory usage" in the "Task Manager" as well. Try to "Shut-down Non-essential programs from "start-up."
Jan 22, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba Portege 2010 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
