Question about Select Jazzy Used Electric Wheelchair
Won't move and has a wrench light that blinks.
930M. Why does the wrench light blink and the blades won't turn?
Wrench calls for tech-help. The clutch engaging the blades works on solenoid. When any of the safety switches in the circuit is open it cannot engage.
Jul 25, 2015 | John Deere Garden
What does a yellow wrench indicator light mean on a Pronto M41 w/Sure Step?
The yellow wrench is a diagnostic tool. How many times does it blink between pauses. Example might be 3 blinks then pause then 3 blinks then pause, over and over. Hoe many does your chair blink?
May 07, 2014 | Electric Mobility Pronto M41 Power Chair...
Why are the lights blinking and it won't go
read manual,lights flash when in security mode,everyt model has a unlock procedure with the buttons on the joystick control.
Jan 23, 2013 | Pride Mobility Jazzy 1143 Power Chair -...
Tool; light blinks 9 times battery is charged pronto m51 tool light blinks 9 times chair won't move
Please download this manual and go to page 26:
http://search.aol.com/aol/search?&s_qt=sb&q=pronto+m51+error+code&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
Jan 22, 2013 | Health & Beauty
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Sonic pride scooter won't move led light flashes 3 blinks then 1 blink?
the slot in the pot stem has to be dead centre..
1. Misadjusted throttle.
2. Broken throttle pot or throttle mechanism
Regards
Sep 02, 2012 | Pride Sonic 3 Wheel Portable Scooter
Wrench light
Blinking is not good
Stop using it before you hurt the engine
Have a repair shop check for codes,diagnose & resolve
When a check light blinks,sometimes it is an indication of
a cylinder misfire so severe, it could damge the exhaust
converter, & may even go into fail safe, to protect it & you
won't be able to drive it
Just one possible reason for the light blinking
Each manufacturer has different strategies
Aug 01, 2012 | 2001 Chevrolet Impala
The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
Mar 12, 2009 | Jet Health & Beauty
Select Jazzy Used Electric Wheelchair Logo
99 people viewed this question
Top Select Health & Beauty Experts
wcdoc1953
wcdoc1953
Scooter Doctor
Scooter Doctor
Colin Taylor
Are you a Select Health and Beauty Expert? Answer questions, earn points and help others
