Watch will work then stop moving after a few hours. I have new battery in it. All hands turn when I move it to correct time then it stops again after a few hours
Hey, I am having the same issue. After a few hours, time stops but if i pull out the crown and push back in, I'm back in business, but after a few hours same thing. Make since the stop watch is on and i am having the worst time figuring out how to turn it off. The chronograph instructions for the Deco are not easy to understand.
SOURCE: michele ladies watch
Anyone who says they can't open your watch is NOT a repairman. Take it to a mom and pop repairman, NOT a big store, because most of the big stores send all their repairs out to someone like the mom and pop store. If you still have problems finding someone please feel free to get ahold of me and I will assist you. Good Luck!!
SOURCE: my michele watch chronograph is stuck
raebarb,
I had the same problem, you can fix it without an expensive watch maker. The online instructions are not perfect, but are better than the ones that come with the watch. Go to www.michele.com/.../Michele/.../instructions/michele_instructions.pdf
Refer to page # 10 "Adjusting the Chronograph Hands to Zero Position" even though these instructions refer to adjusting only 2 hands on a different model, with a little playing around you can reset all 4 hands. The trick is to pull out the stem, 2 clicks to position III and then using buttons A and B. You will have to do the 2 hands then push the stem back in. Repeat the process and reset the other 2 hands.
Good luck, YOU can do it, I just did.
Fingers Cramer
SOURCE: I just bought my wife a michele csx-36 watch. Its brand
that happened to me too...the watch repair man told me that I had the stop watch on. The stop watch should serve as a stop watch, not the second hand. The second time on your watch is the small dial at the bottom middle of the face. Once I turned off the stop watch feature, my battery life is fine...I have not had to change my battery in over 2 years now. HOpe this helps.
SOURCE: Had the battery replaced in
Loose cannon pinion or cannon driving wheel; the seconds hand represents the wheels in the back of the watch going around ok, but the power need to transfer through to the front of the watch somehow.
This is done by snapping/clicking two wheels together on either side of the main plate. The one on the dial side (cannon pinion) needs to slip to be able to set the time as the minute hand is set on this pinion. Im sorry, its time to see a repair guy.
Hope helps.
I am pretty 100 percent sure that Michele CSX 36 diamonds only comes with a swiss quartz movement not an automatic movement.
So the problem seems to be that the battery is dying and need to be replaced. Stopping and going is usually a sign of a battery dying in a swiss quartz movement.
So it should be nothing major and just a battery.
Testimonial: "thank you I will take it to have battery replaced I hope it is ok then. "
