Question about Exeltech XP600 Sinewave Inverter 600W, 24V
Epson XP-610 printer error code OxF1 - Exeltech XP600 Sinewave Inverter 600W, 24V
Fix error code:OxF1
According to this site:
Printer Manual reset
the error means that the print head can't travel across the paper. When you turn the printer on, it should try to move the head across the paper. If it can't, you get this error. Open the front, and check that nothing is blocking the printhead from moving. If nothing is, it may move just a bit. Unplug the printer while it's trying to move the head, and manually (gently) move the head. If it's stiff, you may need to lubricate the shaft (1 drop sewing machine oil).
Nov 12, 2015 | Epson WorkForce WF-3540 All-in-One InkJet...
What is error OxF1
0xF1 means there is a paper jam. Are any of the lights on the machine flashing? Are any of them solid ? Epson WorkForce WF 3520 All in One Printer
Sep 15, 2014 | Epson WorkForce 600 All-In-One InkJet...
Installing epson xp-610 printer error code oxE5
What is your problem about installing? Are you using the correct driver? Do you have a CD or are you installing via the internet? Without knowing answers to these questions it is difficult to answer to your question.
May 18, 2014 | Epson Workforce 610 All-In-One InkJet...
Error code OxF1
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy Pull up older posts. Surf the site with patience.
Apr 16, 2014 | Epson Office Equipment & Supplies
Epson Error Code 0x9A
0x9A Circuit error (include blowout of a fuse F1 on mainboard). Main board failure.
Mar 18, 2014 | Epson WorkForce Pro GT-S50 Scanner, 600...
Epson 610 Workforce Printer Error; Light Bar won't reset
Sound like the scanner is the issue, is it under warranty? OR the Scanner may be locked, check for the scanner release device unlock it,.
Dec 17, 2012 | Epson Workforce 610 All-In-One InkJet...
Exeltech XP600 Sinewave Inverter 600W, 24V Logo
130 people viewed this question
Top Exeltech Electronics - Others Experts
Are you an Exeltech Electronics - Other Expert? Answer questions, earn points and help others
