Question about Sony ZS-S2IP Radio Boombox
Replacement parts cassette recorder
Suggestions on replacing cassette player belts..
  • 119 Answers
SOURCE: Cassette player belt shredded - need part number???
there are 2 belts the small belt # is 304583201 the longer,wider belt is # 304583102. good luck.
Posted on Nov 15, 2006
  • 3 Answers
SOURCE: A pinging sound whenever i try to record something or rewind the cassette
It sounds like there's a problem with the tape loading mechanism. The first thing you should try is seeing if the camcorder will allow you to run a head cleaner through it (probably not the problem, but something everyone should do regularly, but most people don't). If that's not the issue, then it's probably something that you can't fix yourself. You should have information in the box that tells you where to send it to for repair. Good Luck.
Posted on May 25, 2007
  • 298 Answers
SOURCE: Cassette Player Belt Shredded - part number question for RepairGuy
These spares can also be ordered from andrewselectronics.com
Sony PMC-DR50 Replacement Capstan Belt
Sony PMC-DR50 Replacement FR Belt
Sony PMC-DR50 Replacement Loading Belt
Posted on Jun 26, 2008
welcomejee
  • 10594 Answers
SOURCE: NEED THE PART NUMBER FOR SONY TC-WE435 DUEL CASSETTE PLAYER BELTS
Flat belt part number is..
301657001.. BELT (CAPSTAN)
and square belt part number is...
302440501.. BELT (FR2)
Above said info are taken from TC-WE435 cassette player s/m.
Thanks.
Posted on Dec 25, 2009
rommelalilin
  • 2178 Answers
SOURCE: I have a sony duel
The belts and idler rubber products in the tape deck need to be replaced. They are either dried out or broken. This is a common problem - mainly mechanical in nature.
Posted on Feb 19, 2011
I have a Boombox and the audio cassette player is not working
Cassette players use belts for the rew/ffw/play functions. The belts can be difficult to replace even in the relatively large space of a stereo component. Replacing the belts on a boombox is probably more difficult, but I have never tried. If everything else on the boombox is working, it is probably the belts. If you get some sound, but it's muddy, clean the tape heads with alcohol.
May 05, 2017 | The Audio Players & Recorders
Cassette player will not play. need a belt for the player.
Replacement belts figure large in the repairman's armoury so most supplier's catalogues contain a popular selection of types.
I suggest you google your requirements and you should find lots of results to investigate or ask a local repair shop.
Belts are usually supplied by size and cross section. Even when the old belt is available to help identify the requirement a certain amount of guesswork is needed as the old belt will have stretched. Some cassette belts will do the job stretched just a little and some need stretching quite a bit. If the length isn't known it can mean a certain amount of trial and error and the purchase of two or three belts before the correct one is found.
Feb 04, 2017 | The Audio Players & Recorders
GE 3-5027 portable cassette player/recorder belts
I have a GE Battery operated Cassette Recorder, model no. 3-5025A and the spinals that turn the the cassette will not turn. I believe I need the 3 tiny belts that make it work need to be replaced. The are different sizes, do you know where I can purchase these belts?
Mar 15, 2014 | General Electric Cassette Recorder &...
My cassette player does not work on my SONY CFD-50 boom box. The drive motor runs but does not forward or re-wind the tape. If the drive belt is off how do I replace it ?
If you can get the part from an electronics supply (we have a place here in my medium sized Canadian city). Once you obtain the part it just takes patience and a natural ability at puzzles to be able to replace it. Perhaps you should remove the old one first to be able to size it.
Oct 16, 2013 | GPX BCD2805 Radio/Cassette/CD Boombox
The rubber belts on my sony cassette deck(TC-W380) are worn out and i need replacements.Does anyone know where i can purchase them?
Ive used o-rings from home depot with no issues before....I did a little research and the part numbers match to
http://www.ebay.com/itm/SONY-TC-WR665-WR670-WR690-WR701ES-Double-Cassette-Belt-Kit-GTD-5-YEARS-/140828351357?pt=US_Home_Audio_Cassette_Decks&hash=item20ca061b7d
I would investigate on your own to make sure, but the parts cross referenced
Aug 20, 2012 | Sony Dual-Deck Cassette Player/Recorder...
I have a JVC, DVD recorder/video cassette recorder, model DR-MV7SU. When I try to rewind the tape, it will stop and try to eject the cassette, the tape gets commingled inside, What can I do or what website...
Hello
Check all the belts in the vcr mechanism. Replace them all at one time. You can get it is kit form, from most of the electronc spare part shops at your town. Give them the model number of your device. They will select it for you. The fault is with elongated driving belts. OK.
Jun 29, 2011 | JVC Televison & Video
The machine is damaging the pressure pad and or eating cassette tapes.
These units are just like cassette players and have rubber parts inside. This unit should be overhauled. A good cleaning along with replacement rubber parts should resolve the problem. Figure on $10-$20 for parts.
Dan
Aug 24, 2010 | Panasonic RR-930 Desktop Cassette...
VC recorder keeps on driving
I beleave your sensor that tells the player weather a tape is in there or not needs replaced ~ It sounds like it doesent know the tape is not there aand will not shut down! (replace tape sensor)
Please rate my answer and help keep this site free!
Dec 31, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Sony ZS-S2IP Radio Boombox Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
