Question about Spirit ® XT275 Folding Treadmill
Treadmill Digital heartrate screen burnt lights
How can I get my treadmill to stop knocking? I know it's not the motor.
Check the motor belt, more than likely has a burnt spot in it and can cause a knocking
Jun 29, 2014 | Treadmill Doctor Sportcraft TX 400 Walking...
Pacemaster treadmill will not start, no lights, nothing.
Is there a spot on the control board you can check for out going power? You might have a bad board. You can visually inspect your board for anything that looks burnt or one component that looks swolen or loose. Poor solder joints are a common problem with treadmills because of the constsant movement.
Feb 18, 2013 | PaceMaster Aerobics Pro Plus Walking Belt
Lost instrutions for exercise bike profom 760HR
go please to the next web : www.fitness.manualsonline.com or www. iconservice.com
God bless you
Jul 02, 2012 | Smoothfitness Smooth Fitness 76 HR Pro...
Conveyance belt over tighten
1) Lube the deck belt very well according with instruction manual maybe the deck is worn.
2) see the diagram how to do it.
3) Lube the rollers bearing in front and rear
May 14, 2012 | Endurance Cardio T10 Treadmill with...
Turn off sound when heartrate drops
On the screen just prior to work-out mode:
1. Select Settings using the right buttons and the OK button.
2. Select HR Alarm.
3. Select Off.
4. Press the OK button.
5. Press OK again to start exercise.
The same can be done during exercise by hold the OK button down to get to the menu. Very convenient when you use the alarm sometimes and have left it on.
Jul 01, 2010 | Polar F11 Heart Rate Monitor
Motor Controller Board Schematic
If you are the original owner the parts in residential settings is lifetime so call body-solid @ 1-800-556-3113 ext 520
Feb 04, 2010 | Endurance T10HRC Light Treadmill
No heartrate
Heart rate hand grips wiring bad or the Heart Rate board attached to the console board is bad.
Jul 03, 2009 | Life Fitness 91Ti Treadmill
Treadmill motor not coming on, belt not moving
most likely cause is a burnt out motor controller, you'll need to replace it.
Mar 16, 2009 | Exercise & Fitness
Seeing heart rate displayed on my polar compatible treadmill
i didnt knwo my treadmill was compatible i just hooked up like i wanted to read from my watch and then both started to read...although the treadmill had a bit of a different reading
Jan 02, 2009 | Polar S410 Heart Rate Monitor
Spirit ® XT275 Folding Treadmill Logo
16 people viewed this question
Top Spirit Exercise & Fitness Experts
MrJunk
Level 1 Expert
Electro Med Services...
Mister G
Mister G
Level 1 Expert
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
