Question about Hammering
Locking bolt on jack hammer
Does the locking bolt do anything because the bit still stays in place by retaining handle? mine is worn out ?
    Problem Solver:
  • 6 Answers
Yes it locks the steel in. nock the locking bolt down. and batter the bit side to side with a lump hammer it will drop out.
Posted on May 27, 2009
How do you separate the armature from the engine
Can be a bit fun to remove. Some use a jacking screw in place of the center retaining bolt and others it is to loosen the center bolt.
The loosening of the center bolt but not the removal prevent armature (rotor) from completely off as you loosed it. To loosen place a wooden 2x4 against the side of the rotor and give it good smack with a heavy hammer to jar the rotor off the tapered motor crankshaft. Once loosen then of course you remove the center bolt to remove the rotor.
DO NOT OPERATE the generator without the center retaining bolt in place as serious injuries can occur as the rotor goes fly off.
Apr 20, 2015 | Electrical Supplies
Hammer not Jacking
Mine stopped and I took it apart and found a badly worn piston gasket. I can't however find a new gasket. Anyone know where to get parts for the sky687 hammer drill then let me know. Copipeworks@gmail.com
Sep 18, 2012 | Heavy Duty 1240w Electric Demolition Jack...
Car makes lots on noise on right side. Bearings is gone. how do I replace them. Could you please give me step by step?
it would help to now year and model but i can get you close. first support vehicle on side with bearing out on a jack stand under frame. set parking brake to avoid any accidents or use safe wheel blocks. remove wheel . remove axle lcking nut. remove caliper retaining bolts and support caliper with something to avoid brake line damage. remove caliper bracket . remove brake rotor.
then remove the hub bearing retaining bolts on the hub assembly.some new bearing assemblys come with new abs sensor wire some do not. if yours doesnt be careful not to damage the wire for the abs sensor.then take a punch and a hammer place punch into indention on axle tap lightly with hammer to loosen axle from hub.then work hub bearing loose and remove be sure to put backing plate back on the way it came off . reverse steps and be sure you torque bolts properly .some require some thread lock on hub mounting bolts
Dec 23, 2010 | Chevrolet Malibu Cars & Trucks
I have an old hilti, model: te 12 s. it wont drill. when i press the botten it only hammers. i have tryed to open the machine but i can not find the problem.
IT could be one of two problems. 1 The Rollers are missing out of the chuck so that it is not turning the bit. 2 the clutch is worn out causing the gears to slip. The problem is there are no longer parts available for the 12S. You would have to find them on Ebay or some place like that.
If the bit seems to lock into the chuck then it is not the rollers. It is more than likely the clutch.
Aug 08, 2010 | Hilti 375847 TE-CX 3/4" x 12" Masonry...
How to remove routers for a for bronco 85 302 full sized
Removing rotors.
1. Jack up, put on jack stands and remove tire (obviously)
2. Remove caliper
3. Remove bolts holding locking hub body to hub
4. Remove snap ring from end of axle, Remove hub retainer ring from ID of wheel hub. Use a small screwdriver or pick to start it out of the groove. Remove the hub body
5. Remove the outer bearing lock nut, lock washer and the inner adjusting nut
You need the special socket for this OTC #7158 or similar
6. Remove the outer bearing and then the hub
7. To separate the rotor from the hub, use a soft faced hammer to drive the studs out
8. Turn the hub over and set the new rotor in place. Put the studs back in.
9. I will usually use an air hammer to drive the studs back in. Alternating in a circular pattern. If you don't have access, you can use a large diameter punch or another hammer on the back of the studs.
10. Now would be a good time to repack the bearings and replace the wheel seals. Pull the spindles and check the bearings and seals in the back of them. If they are not rusted, slab some grease on them and put back together.
11. Install the hub and rotor assy, and the outer bearing and bearing adjustment nut.
Apr 25, 2010 | 1985 Ford Bronco
2004 Mercury Monterey tail gate handle came completely off. The left side's guide is in place, but the right side is retracted - hence can't just put it back in. Any ideas?
Open tail gate. Use the access square inside - pull cable to open tail gate. Remove interier panel - 2 bolts plus 2 screws (2 bolts on handle and 1 screw each side), pull remainder out of guide clips. Now have full access to locking mechanism. Identified a retaining spring had come loose sending guides to shift left (exterior point of view). Place hand in tail gate and move guides over and put spring in place to retain. verify it works and put back together. Handle is the trickiest part as the bolts have to go through the interior panel and afix to the metal tail gate.
Sep 20, 2009 | 2004 Ford Freestar
Need to replace fuel filter on 2001 Dodge Caravan Sport
just lower tank a little bit to unclip filter line from pump and remove small bolt that holds filter in place then unclip from fuel line
Aug 09, 2009 | 2005 Dodge Caravan
2000 jeep wrangler
I had this same problem on my 99 wrangler. It sounded horriable! like something was going to fall off. Look at your sway bar links very closely. There is a ball joint at the top of the link, inside the rubber boot. If that comes out of its hole then this will allow the link to loosen up and travel with the suspenions movement (makes a loud clunk when the suspension goes down as the top of the link is a tapered thread and wants to stay put but cant). They were about $40.00 a piece. Only the left side one was broken but I changed out both anyway. Bad shock absorbers and New Jersey potholes are to blame for this parts failure. I replaced them in my driveway with out taking anything else off. You will need a jack, wrenches, socket wrench, needle nose locking pliers, a torx 55 bit (sears hardware), and a small but heavy hammer to get the tapered end out once you remove the other bolts. Really hit that ******, it will most likely take a couple wacks. Oh and do yourself a big favor and spray the bolts at the top and bottom with some penetrating oil. I sprayed mine twice a day for 3 days and they were still tought to loosen up. I can not inagine what it would have been with out the oil. Take a picture of the old ones before you remove them. When you put the new ones on, use the picture to make sure you get the hardware in the right place. Use the locking pliers to hold the top stud in place while you remove the bolt. Just push down the boot a bit and stick the nose of the pliers in there. DO NOT DAMAGE THE BOTTOM BOLT. New link parts do not include a replacement but this can be bought for about $15.00 if you do damage it. It will just make this project go from 30 min to a couple days.
Aug 27, 2008 | 2000 Jeep Wrangler
Door handle loud pop- won't open front driver door
hi yes there is a plastic clip that holds the the door handle rod to the handle and connects to the lock you should be able once the pad is off take the bolts out of the door lock it will drop down so far as you can get at the door handles retaining bolts and the clip itshelf you should be able to replace the clip without taking the handle out bit fiddley but not that difficult yates210456
Jun 27, 2008 | 1999 Honda Accord
Telescopic handle
sometimes the locking mechanism for the wand wears out, make sure u have it all the way in and look where it locks and see if it looks worn
Jan 21, 2008 | Fantom Vacums FM760 Twister 500DX Bagless...
Hammering Logo
188 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
