Question about Toshiba CF27G50 27" TV
No image on a toshiba Cf27g50
When I turn on the tv set (Cf27g50) just apears a line. What is happening?
  • 111 Answers
If it is a vertical line, change the horizontal output transistor + capacitors. If it is a horizontal line, replace vertical output transistor + capacitors. Both cost around $10-20.
Posted on May 21, 2009
Diagrams for 1997 Toshiba TV model#CF27G50
write the model on the net and tv type u and type manual and schematic diagrams and download
Jul 16, 2013 | Televison & Video
Toshiba TP50G60 Convergence Problem ??
it was on the video output module, check bad resistor near the video output module..
let me know
Aug 07, 2008 | Toshiba TP50G60 50" Rear Projection...
The screen is Red.
YOUR PROBLEM IS VIDEO OUT PUT SECTION REPLECE VIDEO OUT TRANJESTOR BLUE & GREEN
Sep 06, 2009 | Toshiba CF27G50 27" TV
Picture often flickers and image distorts every few minutes
The trouble is most likely in the Video processor. If the trouble looks like its tearing the video only from side to side it may be the line doubler circuit. Some of these boards are no longer available but a good TV tech may be able to componnent level repair it for you.
Apr 15, 2009 | Toshiba TP50H95 50" Rear Projection...
Showing to of the same thing and colors
ghosting or convergance issue is what u have. if the image is in diff colors then deff a convergence issue. however, if the image isthe same color or shaded from the original then this is ghosting. this may be corrected through the menu settings(sinc settings).
Jan 15, 2009 | Toshiba TLP-380, TLP-780, TLP-781UF...
Laptop monitor have vertical lines apearing out of nowhere...
LCD needs to be replaced.
Common problem called "Tab separation".
Jan 10, 2009 | Toshiba 14" LCD Monitor
Rainbow line on the top of the screan
you most likely have a defective optical engine. these usually become defective around the time the lamp needs to be replaced but not in every case.
Jan 08, 2009 | Toshiba 56HM66 56" Projection HDTV
Toshiba 32AF43 problems
bright red with lines left to right? would be shorted crt. shutting off would be normal due to high beam current.
Nov 09, 2008 | Toshiba 32AF43 32" TV
No picture
Depending on the make and model of the TV, the problem can be a poor connection such as a dry-joint on the main board or a failed line-output stage or simply a physically damaged screen. The latter problem can crop up when the TV is dropped, for example. Please feel free to specify make/model and what happened prior to the problem.
Jan 18, 2008 | Toshiba CF32G40 32" TV
Toshiba 36A50 Horizontal Line in the middle
  • the problem is most common & simple to repair at your home only at minimum cost by skilled technician.
  • as per problem is concern it is due to electrolytic capacitor failure in vertical output stage.
  • hope this will help
  • good luck.
Oct 21, 2007 | Toshiba 36A50 36" TV
Televison & Video Logo
134 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
